Issue with audio clipping / latency
jtrory
Recently I've been having problems, particularly in Google Chrome, with audio clipping. I think the report below might be suggesting that is something to do with my graphics card / DirectX?
I updated the Bios, graphics card drivers, and reinstalled the Realtek audio drivers, but none of that has fixed the issue. Any ideas?
CONCLUSION
LatencyMon has been analyzing your system for 0:00:32 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: JAMES
OS version: Windows 10, 10.0, version 2009, build: 19043 (x64)
Hardware: System Product Name, System manufacturer
CPU: GenuineIntel Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
Logical processors: 16
Processor groups: 1
RAM: 32698 MB total
CPU SPEED
Reported CPU speed: 360 MHz
Highest measured interrupt to process latency (µs): 157.10
Average measured interrupt to process latency (µs): 3.839605
Highest measured interrupt to DPC latency (µs): 152.50
Average measured interrupt to DPC latency (µs): 1.707583
REPORTED ISRs
Highest ISR routine execution time (µs): 399.571111
Highest reported total ISR routine time (%): 0.040365
Total time spent in ISRs (%) 0.048249
ISR count (execution time <250 µs): 22393
ISR count (execution time 500-1000 µs): 1
REPORTED DPCs
Highest DPC routine execution time (µs): 2641.107222
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 471.41 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.026069
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 471.41 , NVIDIA Corporation
Total time spent in DPCs (%) 0.064420
DPC count (execution time <250 µs): 33642
DPC count (execution time 500-10000 µs): 14
DPC count (execution time 1000-2000 µs): 1
DPC count (execution time 2000-4000 µs): 1
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 98
Hard pagefault count of hardest hit process: 57
Number of processes hit: 7
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1.054835
CPU 0 ISR highest execution time (µs): 399.571111
CPU 0 ISR total execution time (s): 0.247002
CPU 0 ISR count: 21065
CPU 0 DPC highest execution time (µs): 2641.107222
CPU 0 DPC total execution time (s): 0.318229
CPU 0 DPC count: 30339
CPU 1 Interrupt cycle time (s): 0.14240
CPU 1 ISR highest execution time (µs): 19.925556
CPU 1 ISR total execution time (s): 0.000439
CPU 1 ISR count: 265
CPU 1 DPC highest execution time (µs): 47.789444
CPU 1 DPC total execution time (s): 0.002508
CPU 1 DPC count: 278
CPU 2 Interrupt cycle time (s): 0.162485
CPU 2 ISR highest execution time (µs): 6.748889
CPU 2 ISR total execution time (s): 0.000047
CPU 2 ISR count: 18
CPU 2 DPC highest execution time (µs): 50.226667
CPU 2 DPC total execution time (s): 0.001297
CPU 2 DPC count: 407
CPU 3 Interrupt cycle time (s): 0.138827
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 12.202222
CPU 3 DPC total execution time (s): 0.000199
CPU 3 DPC count: 52
CPU 4 Interrupt cycle time (s): 0.126956
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 15.688889
CPU 4 DPC total execution time (s): 0.001113
CPU 4 DPC count: 400
CPU 5 Interrupt cycle time (s): 0.118656
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 11.627778
CPU 5 DPC total execution time (s): 0.000139
CPU 5 DPC count: 50
CPU 6 Interrupt cycle time (s): 0.129372
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 23.005556
CPU 6 DPC total execution time (s): 0.000659
CPU 6 DPC count: 212
CPU 7 Interrupt cycle time (s): 0.117077
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 16.084444
CPU 7 DPC total execution time (s): 0.000111
CPU 7 DPC count: 39
CPU 8 Interrupt cycle time (s): 0.119401
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 31.764444
CPU 8 DPC total execution time (s): 0.000375
CPU 8 DPC count: 128
CPU 9 Interrupt cycle time (s): 0.117240
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 36.10
CPU 9 DPC total execution time (s): 0.000117
CPU 9 DPC count: 15
CPU 10 Interrupt cycle time (s): 0.148595
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 126.8750
CPU 10 DPC total execution time (s): 0.000359
CPU 10 DPC count: 93
CPU 11 Interrupt cycle time (s): 0.135026
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 14.217778
CPU 11 DPC total execution time (s): 0.000041
CPU 11 DPC count: 10
CPU 12 Interrupt cycle time (s): 0.272957
CPU 12 ISR highest execution time (µs): 2.292222
CPU 12 ISR total execution time (s): 0.000189
CPU 12 ISR count: 507
CPU 12 DPC highest execution time (µs): 133.262778
CPU 12 DPC total execution time (s): 0.005163
CPU 12 DPC count: 1487
CPU 13 Interrupt cycle time (s): 0.162284
CPU 13 ISR highest execution time (µs): 1.257778
CPU 13 ISR total execution time (s): 0.000209
CPU 13 ISR count: 539
CPU 13 DPC highest execution time (µs): 12.017222
CPU 13 DPC total execution time (s): 0.000074
CPU 13 DPC count: 34
CPU 14 Interrupt cycle time (s): 0.143299
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 92.792778
CPU 14 DPC total execution time (s): 0.000330
CPU 14 DPC count: 65
CPU 15 Interrupt cycle time (s): 0.140819
CPU 15 ISR highest execution time (µs): 0.0
CPU 15 ISR total execution time (s): 0.0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 18.792778
CPU 15 DPC total execution time (s): 0.000251
CPU 15 DPC count: 49
