Issue running update. Component hive corrupt 0x800703f1
Bris
Hello.
I recently noticed my windows updates were failing and retried running it to no avail.
Upon following the posting instructions, I got the following:
sfc gets a "Windows Resource Protection could not perform the requested operation" message.
dism gets to 4.5% and gets error 1009 "The configuration registry database is corrupt"
SFCFix gets a similar "WARNING: Failed to check store directories with return code 1 and error code ERROR_FILE_NOT_FOUND. COMPONENTS hive may be corrupt."
I've attached the CBS zip as well.
I did do some searching on various topics and forums and can see the COMPONENTS file in system32/config has a datestamp of 9/18 and do not see any COMPONENTS when running REGEDIT under HKEY_LOCAL_MACHINE.
Thank you for the assistance. If possible, I would love to understand if the hive can be rebuilt and how that is done roughly out of curiosity.
Hello and welcome!
Please do the following:
Retrieve Components Hive
Step 1 - Replace Components Hive Manually
  1. Download COMPONENTS.ZIP and save to your desktop.
  2. Right-click on it and select Extract all.... Make sure the "Show extracted files when complete" is checked and click Extract.
  3. Now we have the COMPONENTS file that we will be using to replace your current one.
  4. Navigate to C:\Windows\System32\config
  5. Right-click on the current COMPONENTS file and select rename. Rename it to COMPONENTS.bad.
  6. Take the file from the Components folder on your desktop and paste it into C:\Windows\System32\config
