Is my machine corrupted? Does it need a fix?
cpk123
attached is today's log from sfc/scannow
I ran this because my machine frequently consumes a lot of memory of Service Host: Local System category on Task Manager - and machine freezes up.
Please let me know what can be done to fix this.
Appreciate the forum's help in this regard.
Thanks
CP
- Run the SFCfix tool and post the results in your next reply.
- Did you tell Windows to have a fixed maximum size for the pagefile ? If so, then let Windows manage the size of the pagefile.
Ran SFC Fix.
Once SFCFix completed - got this error
Error: 0x800f081f
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see MSN.com - Hotmail, Outlook, Skype, Bing, Latest News, Photos & Videos
243077.
Post run - here are the CBS Log and the DISM log.
CP
More info...
Start time: 2016-11-20 10:31:45.535
Microsoft Windows 10 Build 10586 (Updates Deferred) - amd64
WARNING: Failed to get store name from identity name with return code 2 for component Microsoft-Windows-iSCSI_Initiator_UI and file iSCSI Initiator.lnk. File is reported as corrupt by SFC.
CORRUPT: iSCSI Initiator.lnk of component Microsoft-Windows-iSCSI_Initiator_UI.
WARNING: Failed to get store name from identity name with return code 2 for component Microsoft-Windows-Microsoft-Data-Access-Components-(MDAC)-ODBC-Administrator and file ODBC Data Sources (64-bit).lnk. File is reported as corrupt by SFC.
CORRUPT: ODBC Data Sources (64-bit).lnk of component Microsoft-Windows-Microsoft-Data-Access-Components-(MDAC)-ODBC-Administrator.
WARNING: Failed to get store name from identity name with return code 2 for component Microsoft-Windows-Microsoft-Data-Access-Components-(MDAC)-ODBC-Administrator and file ODBC Data Sources (32-bit).lnk. File is reported as corrupt by SFC.
CORRUPT: ODBC Data Sources (32-bit).lnk of component Microsoft-Windows-Microsoft-Data-Access-Components-(MDAC)-ODBC-Administrator.
CBS & SFC total detected corruption count: 3
Finish time: 2016-11-20 14:49:50.684
Hi there, let's replace the three files that are reported as corrupt.
    View attachment SFCFix.zip
    DISM /RestoreHealth Scan
    1. Right-click on the Start
    3. When DISM finishes scanning your component store, zip up and attach your CBS log to your next post:
      C:\Windows\Logs\CBS\CBS.log
    If the zip file is larger than 8MB, please use a file sharing service such as OneDrive, DropBox, SendSpace, etc. and include the link with your reply.
