CONCLUSION
LatencyMon has been analyzing your system for 0:17:19 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-CBHSS6I
OS version: Windows 10 , 10.0, build: 18363 (x64)
Hardware: ASUS, ASUSTeK COMPUTER INC., ROG STRIX Z490-E GAMING
CPU: GenuineIntel Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz
Logical processors: 20
Processor groups: 1
RAM: 32666 MB total
CPU SPEED
Reported CPU speed: 3696 MHz
Highest measured interrupt to process latency (µs): 778.70
Average measured interrupt to process latency (µs): 1.754244
Highest measured interrupt to DPC latency (µs): 777.0
Average measured interrupt to DPC latency (µs): 0.704742
REPORTED ISRs
Highest ISR routine execution time (µs): 64.962662
Highest reported total ISR routine time (%): 0.001878
Total time spent in ISRs (%) 0.002073
ISR count (execution time <250 µs): 102507
REPORTED DPCs
Highest DPC routine execution time (µs): 324.232684
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0.005006
Total time spent in DPCs (%) 0.011745
DPC count (execution time <250 µs): 1825809
DPC count (execution time 500-999 µs): 1
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: latmon.exe
Total number of hard pagefaults 43
Hard pagefault count of hardest hit process: 15
Number of processes hit: 11
PER CPU DATA
CPU 0 Interrupt cycle time (s): 11.400702
CPU 0 ISR highest execution time (µs): 0.0
CPU 0 ISR total execution time (s): 0.0
CPU 0 ISR count: 0
CPU 0 DPC highest execution time (µs): 68.651515
CPU 0 DPC total execution time (s): 1.004158
CPU 0 DPC count: 1661866
CPU 1 Interrupt cycle time (s): 4.101705
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 1.707251
CPU 1 DPC total execution time (s): 0.000005
CPU 1 DPC count: 4
CPU 2 Interrupt cycle time (s): 4.338506
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 30.589286
CPU 2 DPC total execution time (s): 0.049013
CPU 2 DPC count: 25351
CPU 3 Interrupt cycle time (s): 4.138617
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 7.121212
CPU 3 DPC total execution time (s): 0.000014
CPU 3 DPC count: 6
CPU 4 Interrupt cycle time (s): 4.785434
CPU 4 ISR highest execution time (µs): 51.939394
CPU 4 ISR total execution time (s): 0.043526
CPU 4 ISR count: 2027
CPU 4 DPC highest execution time (µs): 71.207251
CPU 4 DPC total execution time (s): 0.013158
CPU 4 DPC count: 5105
CPU 5 Interrupt cycle time (s): 10.716171
CPU 5 ISR highest execution time (µs): 64.962662
CPU 5 ISR total execution time (s): 0.364230
CPU 5 ISR count: 26794
CPU 5 DPC highest execution time (µs): 68.288420
CPU 5 DPC total execution time (s): 0.310296
CPU 5 DPC count: 49713
CPU 6 Interrupt cycle time (s): 4.077699
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 324.232684
CPU 6 DPC total execution time (s): 0.003143
CPU 6 DPC count: 1375
CPU 7 Interrupt cycle time (s): 4.228926
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 6.379870
CPU 7 DPC total execution time (s): 0.000063
CPU 7 DPC count: 37
CPU 8 Interrupt cycle time (s): 4.147276
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 25.443182
CPU 8 DPC total execution time (s): 0.001973
CPU 8 DPC count: 936
CPU 9 Interrupt cycle time (s): 4.243493
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 19.477273
CPU 9 DPC total execution time (s): 0.000177
CPU 9 DPC count: 54
CPU 10 Interrupt cycle time (s): 4.199952
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 24.009740
CPU 10 DPC total execution time (s): 0.002042
CPU 10 DPC count: 1003
CPU 11 Interrupt cycle time (s): 4.196880
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 8.100108
CPU 11 DPC total execution time (s): 0.000099
CPU 11 DPC count: 67
CPU 12 Interrupt cycle time (s): 4.111315
CPU 12 ISR highest execution time (µs): 0.0
CPU 12 ISR total execution time (s): 0.0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 23.593615
CPU 12 DPC total execution time (s): 0.004474
CPU 12 DPC count: 2131
CPU 13 Interrupt cycle time (s): 4.146601
CPU 13 ISR highest execution time (µs): 0.0
CPU 13 ISR total execution time (s): 0.0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 9.773268
CPU 13 DPC total execution time (s): 0.000285
CPU 13 DPC count: 153
CPU 14 Interrupt cycle time (s): 4.196639
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 24.318723
CPU 14 DPC total execution time (s): 0.001696
CPU 14 DPC count: 720
CPU 15 Interrupt cycle time (s): 4.137630
CPU 15 ISR highest execution time (µs): 0.0
CPU 15 ISR total execution time (s): 0.0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 7.950758
CPU 15 DPC total execution time (s): 0.000035
CPU 15 DPC count: 15
CPU 16 Interrupt cycle time (s): 4.305692
CPU 16 ISR highest execution time (µs): 1.781926
CPU 16 ISR total execution time (s): 0.000349
CPU 16 ISR count: 634
CPU 16 DPC highest execution time (µs): 35.509199
CPU 16 DPC total execution time (s): 0.012108
CPU 16 DPC count: 2106
CPU 17 Interrupt cycle time (s): 12.116189
CPU 17 ISR highest execution time (µs): 19.808983
CPU 17 ISR total execution time (s): 0.022665
CPU 17 ISR count: 73052
CPU 17 DPC highest execution time (µs): 51.224567
CPU 17 DPC total execution time (s): 1.03670
CPU 17 DPC count: 74718
CPU 18 Interrupt cycle time (s): 4.009695
CPU 18 ISR highest execution time (µs): 0.0
CPU 18 ISR total execution time (s): 0.0
CPU 18 ISR count: 0
CPU 18 DPC highest execution time (µs): 10.632576
CPU 18 DPC total execution time (s): 0.000779
CPU 18 DPC count: 337
CPU 19 Interrupt cycle time (s): 4.240151
CPU 19 ISR highest execution time (µs): 0.0
CPU 19 ISR total execution time (s): 0.0
CPU 19 ISR count: 0
CPU 19 DPC highest execution time (µs): 9.830087
CPU 19 DPC total execution time (s): 0.000389
CPU 19 DPC count: 113
