I am a proud owner of corruptions beyond intention and control of mine
gyurika
New York
Start time: 2015-08-07 01:23:23.782
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-
client_31bf3856ad364e35_6.3.9600.17842_none_90da81a4dac50d54\utc.app.json
client_31bf3856ad364e35_6.3.9600.17842_none_90da81a4dac50d54\telemetry.ASM-
WindowsDefault.json
CORRUPT: C:\Windows\winsxs\wow64_adobe-flash-for-
windows_31bf3856ad364e35_6.3.9600.17933_none_26e7f25171bfbfb7\FlashPlayerApp.exe
rasapi_31bf3856ad364e35_6.3.9600.17485_none_5df6cadd237b690f\rasapi32.dll
CORRUPT: C:\Windows\winsxs\wow64_microsoft-windows-
rasapi_31bf3856ad364e35_6.3.9600.17485_none_684b752f57dc2b0a\rasapi32.dll
SUMMARY: Some corruptions could not be fixed automatically. Seek advice from helper or
sysnative.com.
CBS & SFC total detected corruption count: 5
Finish time: 2015-08-07 01:36:35.626
The CBS crashes Firefox, I have not figured yet how to up;oad in that big container you mention... Maybe little help woould go a long ways... sorry.
(Could not send in attachment and trying to zip it I got an error....???)
Even though I am happy so far that I have found you...
Sincerely,
George
Hello George, welcome to Sysnative!
SFCFix Script (.zip)
Warning: This fix is intended for use on this particular machine. Do not use this fix on any other machine; doing so may cause damage to your Operating System. If you are not the original poster and require assistance, please start your own topic.
  • Download View attachment SFCFix.zip and save this file to your Desktop.
  • Note: Ensure this file is named SFCFix.zip. Do not rename the file.
  • Close all open windows.
  • SFCFix.exe
    and SFCFix.zip
    should both be present on your Desktop.
  • Drag the file SFCFix.zip onto the file SFCFix.exe and release it.
  • SFCFix will now process the script. Upon completion, a file (SFCFix.txt) will be created on your Desktop.
  • Copy the contents of the file and paste in your next reply.
SFC /SCANNOW
  • Press the Windows Key
    + r on your keyboard at the same time. Type Notepad and click OK.
  • Copy the three bold lines below and paste into the Notepad document:
    copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\CBS.txt"
    del %0
  • Click Format. Ensure Wordwrap is unchecked.
  • Click File, Save As and name the file sfcscannow.bat.
  • Select All Files as the Save as type. Save the file to your Desktop.
  • Locate sfcscannow.bat
    on your Desktop. Right-click the file and click
    Run as administrator.
  • Upon completion, a file (CBS.txt) will be created on your Desktop. Attach this file in your next reply.
  • Note: If the file is too large to attach, upload to a service such as Dropbox, One Drive or SendSpace and provide a direct download link in your next reply.
  • Download View attachment 15224 and save this file to your Desktop.
  • SFCFix.exe
    and SFCFix.zip
SFC /SCANNOW
    del %0
This is reply part1 with the sfcfix.text file. Will work on the rest and thank you inm the mean time, George
Start time: 2015-08-07 16:12:00.701
Using .zip script file at C:\Users\Muki\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_684b752f57dc2b0a\rasapi32.dll
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.17933_none_26e7f25171bfbfb7\FlashPlayerApp.exe
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_5df6cadd237b690f\rasapi32.dll
Successfully copied file C:\Users\Muki\AppData\Local\niemiro\Archive\wow64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_684b752f57dc2b0a\rasapi32.dll to C:\Windows\winsxs\wow64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_684b752f57dc2b0a\rasapi32.dll.
Successfully copied file C:\Users\Muki\AppData\Local\niemiro\Archive\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.17933_none_26e7f25171bfbfb7\FlashPlayerApp.exe to C:\Windows\winsxs\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.17933_none_26e7f25171bfbfb7\FlashPlayerApp.exe.
The file \\?\C:\Windows\winsxs\amd64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_5df6cadd237b690f\rasapi32.dll is in use and must be replaced over a reboot.
Successfully pended file for replace over reboot: \\?\C:\Windows\winsxs\amd64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_5df6cadd237b690f\rasapi32.dll
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_684b752f57dc2b0a\rasapi32.dll
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_684b752f57dc2b0a\rasapi32.dll
Successfully restored ownership for C:\Windows\winsxs\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.17933_none_26e7f25171bfbfb7\FlashPlayerApp.exe
Successfully restored permissions on C:\Windows\winsxs\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.17933_none_26e7f25171bfbfb7\FlashPlayerApp.exe
Reboot:: directive completed successfully.
PostRebootCorruptionDetection::
No hash verification failures detected.
PostRebootCorruptionDetection:: directive completed successfully.
PostRebootRestorePermissions::
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_5df6cadd237b690f\rasapi32.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-rasapi_31bf3856ad364e35_6.3.9600.17485_none_5df6cadd237b690f\rasapi32.dll
PostRebootRestorePermissions:: directive completed successfully.
Finish time: 2015-08-07 16:13:56.077
Woww it looked much better....
My CBS managed to go up without a problem.
Thanks,
George
It happened again!
Originally I was chasing a Blue screen 0x00000609. Would usually come up when waking up from sleep, (or just sleeping?).
Therefor I got suspicious of Kernel-Power error 41, and sure enough I had one this time as well, the only one marked critical.
The properties says:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
What I did I disabled the quick startup/shutdown as somebody suggested on the Net. Apparently that did not solve the issue.
George
Hi George,
Your latest CBS.log looks good.
I suggest heading over to the BSOD, Crashes, Kernel Debugging section to receive assistance with your blue screens. Ensure you read the posting instructions prior to posting.
Best of luck. :dsmile:
Thank you. I greatly appreciated your help and it got rid of 5 ownership conflicts. Not that I can see a difference but I sleep better knowing it... Keep it up, thx, George
You're welcome, George. :dsmile:
FYI - two of the files referenced in your first post were incorrectly reported as corrupt; so we only repaired 3, not 5.
I will mark this topic as solved. Good luck resolving your other issues with the machine.
Hi Liquid, the Tention is on me.
I am wondering if this is normal, but all I have done since, was trying to send files to the BSOD folks, and then tonight I followed a Utube how to fix the f. Skype. (On shutdown it cannot load the referenced memory) In the past years - sometimes by disabling sign-off sound or by whatever trick I used to be able to overcome this error that occurred from time to rime with a Skype update. This times it is resisting my own knowledge-base, so I did a clean install. (Including wiping AppData). Ran a scannow as per YouTube. That again had errors it could not repair. So I looked in the CBS.log and it has a few new corruption, if you look backwards from the end of it. Not that I wanted to insult you, but I just finished, so it starts now... Since last time you got off easy with that 2 bogus error you did not have to repair, maybe I could make up for that with these new editions.
Appreciatively,
George
Hi George,
I am more than happy to take a look. However, as you still have an on-going topic in the BSOD section, it is best we wait for the work in that section to be concluded. Working on the same machine in two different places is not good practice, and can cause additional problems.
Let me know once you've finished in the BSOD section, and we can proceed here. :dsmile:
Adam
