I am a Dubstep Producer Facing latency issues please HELP!!
Shesh Narain Tewari
CONCLUSION
LatencyMon has been analyzing your system for 0:00:30 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-4LJ7B8U
OS version: Windows 10 , 10.0, version 1903, build: 18362 (x64)
Hardware: G3 3579, Dell Inc., 03TF0Y
CPU: GenuineIntel Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
Logical processors: 12
Processor groups: 1
RAM: 16243 MB total
CPU SPEED
Reported CPU speed: 2208 MHz
Highest measured interrupt to process latency (µs): 1246.90
Average measured interrupt to process latency (µs): 4.954838
Highest measured interrupt to DPC latency (µs): 1201.0
Average measured interrupt to DPC latency (µs): 2.224474
REPORTED ISRs
Highest ISR routine execution time (µs): 266.134964
Driver with highest ISR routine execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
Highest reported total ISR routine time (%): 0.037869
Driver with highest ISR total time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
Total time spent in ISRs (%) 0.040033
ISR count (execution time <250 µs): 1837
ISR count (execution time 500-999 µs): 1
REPORTED DPCs
Highest DPC routine execution time (µs): 1888.673913
Driver with highest DPC routine execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
Highest reported total DPC routine time (%): 0.07530
Driver with highest DPC total execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
Total time spent in DPCs (%) 0.171703
DPC count (execution time <250 µs): 110887
DPC count (execution time 500-999 µs): 816
DPC count (execution time 1000-1999 µs): 2
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: latmon.exe
Total number of hard pagefaults 56
Hard pagefault count of hardest hit process: 31
Number of processes hit: 4
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1.521935
CPU 0 ISR highest execution time (µs): 266.134964
CPU 0 ISR total execution time (s): 0.143855
CPU 0 ISR count: 1806
CPU 0 DPC highest execution time (µs): 1888.673913
CPU 0 DPC total execution time (s): 0.587657
CPU 0 DPC count: 109217
CPU 1 Interrupt cycle time (s): 1.056729
CPU 1 ISR highest execution time (µs): 90.649457
CPU 1 ISR total execution time (s): 0.000566
CPU 1 ISR count: 32
CPU 1 DPC highest execution time (µs): 262.891304
CPU 1 DPC total execution time (s): 0.005713
CPU 1 DPC count: 345
CPU 2 Interrupt cycle time (s): 0.884557
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 215.095109
CPU 2 DPC total execution time (s): 0.009398
CPU 2 DPC count: 578
CPU 3 Interrupt cycle time (s): 1.267276
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 7.033514
CPU 3 DPC total execution time (s): 0.000128
CPU 3 DPC count: 33
CPU 4 Interrupt cycle time (s): 0.728679
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 161.634058
CPU 4 DPC total execution time (s): 0.004081
CPU 4 DPC count: 299
CPU 5 Interrupt cycle time (s): 1.152390
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 4.049819
CPU 5 DPC total execution time (s): 0.000004
CPU 5 DPC count: 1
CPU 6 Interrupt cycle time (s): 0.698233
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 137.204710
CPU 6 DPC total execution time (s): 0.002094
CPU 6 DPC count: 188
CPU 7 Interrupt cycle time (s): 1.100397
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 27.759964
CPU 7 DPC total execution time (s): 0.000244
CPU 7 DPC count: 19
CPU 8 Interrupt cycle time (s): 0.712288
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 197.096014
CPU 8 DPC total execution time (s): 0.003672
CPU 8 DPC count: 310
CPU 9 Interrupt cycle time (s): 1.158776
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 15.970109
CPU 9 DPC total execution time (s): 0.000207
CPU 9 DPC count: 53
CPU 10 Interrupt cycle time (s): 0.697452
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 157.528080
CPU 10 DPC total execution time (s): 0.006222
CPU 10 DPC count: 659
CPU 11 Interrupt cycle time (s): 1.513097
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 5.928442
CPU 11 DPC total execution time (s): 0.000009
CPU 11 DPC count: 3
Hi Shesh Narain Tewari. 🖖
Try to update windows to the latest version.
There's an urgent bios update for your laptop: version 1.11.0 (6 gen 2020); check your laptop downloads in dell support for your laptop (and read CAREFULLY their instructions).
These two updates/upgrades could hopefully solve your problem.
hey guys,
the problem is still not resolved. Please Help.
CONCLUSION
LatencyMon has been analyzing your system for 0:02:38 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-F62OS0F
OS version: Windows 10 , 10.0, build: 18363 (x64)
Processor groups: 1
RAM: 16243 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 529.80
Average measured interrupt to process latency (µs): 3.775673
Highest measured interrupt to DPC latency (µs): 498.40
Average measured interrupt to DPC latency (µs): 1.191447
REPORTED ISRs
Highest ISR routine execution time (µs): 192.483696
Highest reported total ISR routine time (%): 0.001802
Total time spent in ISRs (%) 0.002603
ISR count (execution time <250 µs): 2659
REPORTED DPCs
Highest DPC routine execution time (µs): 1093.849638
Highest reported total DPC routine time (%): 0.010784
Driver with highest DPC total execution time: iaStorAC.sys - Intel(R) Rapid Storage Technology driver - x64, Intel Corporation
Total time spent in DPCs (%) 0.029944
DPC count (execution time <250 µs): 78159
DPC count (execution time 500-999 µs): 71
DPC count (execution time 1000-1999 µs): 4
Total number of hard pagefaults 15950
Hard pagefault count of hardest hit process: 2247
Number of processes hit: 81
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2.133182
CPU 0 ISR highest execution time (µs): 192.483696
CPU 0 ISR total execution time (s): 0.049381
CPU 0 ISR count: 2641
CPU 0 DPC highest execution time (µs): 1093.849638
CPU 0 DPC total execution time (s): 0.418567
CPU 0 DPC count: 53655
CPU 1 Interrupt cycle time (s): 0.708835
CPU 1 ISR highest execution time (µs): 1.851449
CPU 1 ISR total execution time (s): 0.000015
CPU 1 ISR count: 18
CPU 1 DPC highest execution time (µs): 189.167572
CPU 1 DPC total execution time (s): 0.004271
CPU 1 DPC count: 637
CPU 2 Interrupt cycle time (s): 0.699270
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 116.134058
CPU 2 DPC total execution time (s): 0.017893
CPU 2 DPC count: 3084
CPU 3 Interrupt cycle time (s): 0.815894
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 266.780797
CPU 3 DPC total execution time (s): 0.004863
CPU 3 DPC count: 639
CPU 4 Interrupt cycle time (s): 0.669349
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 226.356884
CPU 4 DPC total execution time (s): 0.008328
CPU 4 DPC count: 1493
CPU 5 Interrupt cycle time (s): 0.761206
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 62.122283
CPU 5 DPC total execution time (s): 0.005168
CPU 5 DPC count: 982
CPU 6 Interrupt cycle time (s): 0.724422
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 122.070652
CPU 6 DPC total execution time (s): 0.034725
CPU 6 DPC count: 5959
CPU 7 Interrupt cycle time (s): 0.750860
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 65.889493
CPU 7 DPC total execution time (s): 0.003650
CPU 7 DPC count: 760
CPU 8 Interrupt cycle time (s): 0.676149
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 204.732790
CPU 8 DPC total execution time (s): 0.028084
CPU 8 DPC count: 3774
CPU 9 Interrupt cycle time (s): 0.736313
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 65.646739
CPU 9 DPC total execution time (s): 0.002463
CPU 9 DPC count: 484
CPU 10 Interrupt cycle time (s): 0.667969
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 286.467391
CPU 10 DPC total execution time (s): 0.035666
CPU 10 DPC count: 5751
CPU 11 Interrupt cycle time (s): 0.744531
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 62.602355
CPU 11 DPC total execution time (s): 0.004577
CPU 11 DPC count: 1016
