CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:14:04 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-0PCG2QO
OS version: Windows 10, 10.0, version 2009, build: 22621 (x64)
Hardware: Z690 GAMING X, Gigabyte Technology Co., Ltd.
CPU: GenuineIntel 12th Gen Intel(R) Core(TM) i7-12700KF
Logical processors: 20
Processor groups: 1
RAM: 16223 MB total
CPU SPEED
Reported CPU speed: 3610 MHz
Highest measured interrupt to process latency (µs): 2693.70
Average measured interrupt to process latency (µs): 5.561401
Highest measured interrupt to DPC latency (µs): 748.20
Average measured interrupt to DPC latency (µs): 1.785181
REPORTED ISRs
Highest ISR routine execution time (µs): 511.489197
Highest reported total ISR routine time (%): 0.013229
Total time spent in ISRs (%) 0.020275
ISR count (execution time <250 µs): 232648
ISR count (execution time 500-1000 µs): 171
REPORTED DPCs
Highest DPC routine execution time (µs): 615.746260
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0.005911
Driver with highest DPC total execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Total time spent in DPCs (%) 0.034483
DPC count (execution time <250 µs): 662016
DPC count (execution time 500-10000 µs): 423
DPC count (execution time 1000-2000 µs): 0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 5774
Hard pagefault count of hardest hit process: 960
Number of processes hit: 117
PER CPU DATA
CPU 0 Interrupt cycle time (s): 22.693480
CPU 0 ISR highest execution time (µs): 210.277008
CPU 0 ISR total execution time (s): 1.077041
CPU 0 ISR count: 77855
CPU 0 DPC highest execution time (µs): 376.402216
CPU 0 DPC total execution time (s): 1.081099
CPU 0 DPC count: 178837
CPU 1 Interrupt cycle time (s): 14.793813
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 386.884765
CPU 1 DPC total execution time (s): 0.011974
CPU 1 DPC count: 1472
CPU 2 Interrupt cycle time (s): 13.802953
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 615.746260
CPU 2 DPC total execution time (s): 0.174640
CPU 2 DPC count: 17161
CPU 3 Interrupt cycle time (s): 14.259544
CPU 3 ISR highest execution time (µs): 311.752909
CPU 3 ISR total execution time (s): 0.381088
CPU 3 ISR count: 25426
CPU 3 DPC highest execution time (µs): 387.180609
CPU 3 DPC total execution time (s): 0.343059
CPU 3 DPC count: 41307
CPU 4 Interrupt cycle time (s): 26.899810
CPU 4 ISR highest execution time (µs): 511.489197
CPU 4 ISR total execution time (s): 1.810841
CPU 4 ISR count: 104567
CPU 4 DPC highest execution time (µs): 614.737950
CPU 4 DPC total execution time (s): 2.262785
CPU 4 DPC count: 221798
CPU 5 Interrupt cycle time (s): 19.767296
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 433.095291
CPU 5 DPC total execution time (s): 0.345827
CPU 5 DPC count: 30839
CPU 6 Interrupt cycle time (s): 23.113443
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 538.191136
CPU 6 DPC total execution time (s): 0.869062
CPU 6 DPC count: 74638
CPU 7 Interrupt cycle time (s): 19.733594
CPU 7 ISR highest execution time (µs): 301.495291
CPU 7 ISR total execution time (s): 0.013293
CPU 7 ISR count: 758
CPU 7 DPC highest execution time (µs): 559.258172
CPU 7 DPC total execution time (s): 0.221909
CPU 7 DPC count: 19771
CPU 8 Interrupt cycle time (s): 15.289030
CPU 8 ISR highest execution time (µs): 381.372299
CPU 8 ISR total execution time (s): 0.105071
CPU 8 ISR count: 6625
CPU 8 DPC highest execution time (µs): 540.380609
CPU 8 DPC total execution time (s): 0.153795
CPU 8 DPC count: 16091
CPU 9 Interrupt cycle time (s): 13.837007
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 323.250416
CPU 9 DPC total execution time (s): 0.017417
CPU 9 DPC count: 1739
CPU 10 Interrupt cycle time (s): 12.757979
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 324.745152
CPU 10 DPC total execution time (s): 0.054355
CPU 10 DPC count: 6300
CPU 11 Interrupt cycle time (s): 12.244924
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 415.192798
CPU 11 DPC total execution time (s): 0.020498
CPU 11 DPC count: 1538
CPU 12 Interrupt cycle time (s): 11.940635
CPU 12 ISR highest execution time (µs): 287.111357
CPU 12 ISR total execution time (s): 0.025011
CPU 12 ISR count: 1874
CPU 12 DPC highest execution time (µs): 376.382271
CPU 12 DPC total execution time (s): 0.061367
CPU 12 DPC count: 7079
CPU 13 Interrupt cycle time (s): 11.653079
CPU 13 ISR highest execution time (µs): 0.0
CPU 13 ISR total execution time (s): 0.0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 331.170637
CPU 13 DPC total execution time (s): 0.012145
CPU 13 DPC count: 1022
CPU 14 Interrupt cycle time (s): 10.219495
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 384.930194
CPU 14 DPC total execution time (s): 0.042387
CPU 14 DPC count: 5034
CPU 15 Interrupt cycle time (s): 12.597046
CPU 15 ISR highest execution time (µs): 25.154017
CPU 15 ISR total execution time (s): 0.000139
CPU 15 ISR count: 12
CPU 15 DPC highest execution time (µs): 134.690305
CPU 15 DPC total execution time (s): 0.014061
CPU 15 DPC count: 1205
CPU 16 Interrupt cycle time (s): 10.062930
CPU 16 ISR highest execution time (µs): 70.111357
CPU 16 ISR total execution time (s): 0.010277
CPU 16 ISR count: 15702
CPU 16 DPC highest execution time (µs): 404.296953
CPU 16 DPC total execution time (s): 0.040412
CPU 16 DPC count: 7604
CPU 17 Interrupt cycle time (s): 7.775882
CPU 17 ISR highest execution time (µs): 0.0
CPU 17 ISR total execution time (s): 0.0
CPU 17 ISR count: 0
CPU 17 DPC highest execution time (µs): 373.332410
CPU 17 DPC total execution time (s): 0.028822
CPU 17 DPC count: 10948
CPU 18 Interrupt cycle time (s): 7.458056
CPU 18 ISR highest execution time (µs): 0.0
CPU 18 ISR total execution time (s): 0.0
CPU 18 ISR count: 0
CPU 18 DPC highest execution time (µs): 379.010526
CPU 18 DPC total execution time (s): 0.033176
CPU 18 DPC count: 9204
CPU 19 Interrupt cycle time (s): 7.299913
CPU 19 ISR highest execution time (µs): 0.0
CPU 19 ISR total execution time (s): 0.0
CPU 19 ISR count: 0
CPU 19 DPC highest execution time (µs): 305.708587
CPU 19 DPC total execution time (s): 0.032546
CPU 19 DPC count: 8852
