I've noticed that you've been helping people a lot with their stuttering/latency issues and i found similar threads regarding that driver which unfortunately was unrelated to my issue or couldn't be applied to my issue.
For more than a year i've been struggling with latency issues on my pc and according to latencymon they to be related to ndis.sys spikes at random intervals whenever i refresh pages, download something or watch online videos.
I've been talking to both Asus and Intel support and they just keep pointing fingers at each other claiming that either this is a motherboard issue or intel's ethernet driver issue. There are pages and threads describing it on both of their forums but unfortunately no solutions has ever worked. I have tried disabling "large send offload" and "interrupt moderation" in ethernet driver's setting and it didn't do anything. I've even tried installing a separate ethernet card but remarkably the issue was still there which made me thing it could be related to something else entirely rather than to ethernet controller or driver alone.
The worst part is - couple of month's ago i've been able to fix or minimize the issue but then i've made a fresh installation of windows 10 with 1607 update and the issue returned with full force.
There are other oddities about it as well - it seems to occur more prominently if i have been downloading something heavy like torrents. It doesn't always occur right away and might take a couple of hours before latency spikes start to become noticeable.
The other problem is that i cannot install the older drivers like some people recommending on intel's, asus and even on this forum. My ethernet controller and windows version are newer than those drivers and they simply wont recognize my device. Even if i try to manually insert older driver - it just refuses to work. I've tried ALL of the newer drivers, each and every version starting from 20.1 but it didn't help and anything below that cannot be installed on my system. So im hoping you can find some other solution.
This is my CPU.etl:
CPU
This is my MsInfo:
MsInfo
And my system information:
This is my CPU.etl:
CPU
This is my MsInfo:
MsInfo
- System Manufacturer - built myself
- Laptop or Desktop - desktop
- Exact model number (if laptop, check label on bottom) - n/a
- OS ? (Windows 10, 8.1, 8, 7, Vista) - Windows 10 Pro
- x86 (32bit) or x64 (64bit)? - x64
- Service pack? - latest one 1607
- What was original installed OS on system? - n/a fresh installation
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? - purchased/free upgrade
- Age of system? (hardware) - one year old
- Age of OS installation? - 2 month's
- Have you re-installed the OS? - yes
- CPU - 6700k
- RAM (brand, model, which slots are you using?) - Corsair CMK32GX4M4A2400C14
- Video Card - Asus Strix 970 GTX
- MotherBoard - (if NOT a laptop) - Asus Maximus VIII Hero
- Power Supply - brand & wattage (if laptop, skip this one) - Seasonic xseris 780W gold
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) - Avast Premier
- Are you using proxy, vpn, ipfilters or similar software? - no
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) - no
- Are you currently under/overclocking? Are there overclocking software installed on your system? - im running RAM at EMP2 profile meaning 2666 Mhz and CPU is running at 4000-4200 turbo which is a default setting for it
