Hello, when i installed Windows 11 i have some problems with high DPC latency. I tried many solutions in Google, but nothing helped. I enclose raport of Latency Mon. I have a lot of interrupts in the system and sound. Anyone help me solve the problem?
Things I've tried:
-Updated to Latest BIOS
-Chosen High Performance at Power Options
-All drivers are updated to latest version
My computer specs:
i3-8100
Sapphire RX 580 Nitro 8 GB
8 GB RAM Ballistix
MSI H310M PRO-VDH
SanDisk SSD PLUS 480 GB
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:10:28 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-17D7B25
OS version: Windows 10, 10.0, version 2009, build: 22458 (x64)
Hardware: MS-7B29, Micro-Star International Co., Ltd.
CPU: GenuineIntel Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
Logical processors: 4
Processor groups: 1
RAM: 8126 MB total
CPU SPEED
Reported CPU speed: 360 MHz
Highest measured interrupt to process latency (µs): 2059.70
Average measured interrupt to process latency (µs): 22.837068
Highest measured interrupt to DPC latency (µs): 2034.40
Average measured interrupt to DPC latency (µs): 4.367022
REPORTED ISRs
Highest ISR routine execution time (µs): 60.661667
Driver with highest ISR routine execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Highest reported total ISR routine time (%): 0.008375
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.013132
ISR count (execution time <250 µs): 98387
REPORTED DPCs
Highest DPC routine execution time (µs): 234.069444
Highest reported total DPC routine time (%): 0.351057
Total time spent in DPCs (%) 0.583661
DPC count (execution time <250 µs): 1524677
DPC count (execution time 500-10000 µs): 0
DPC count (execution time 1000-2000 µs): 0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: officeclicktorun.exe
Total number of hard pagefaults 5747
Hard pagefault count of hardest hit process: 1955
Number of processes hit: 83
PER CPU DATA
CPU 0 Interrupt cycle time (s): 27.661544
CPU 0 ISR highest execution time (µs): 60.661667
CPU 0 ISR total execution time (s): 0.293281
CPU 0 ISR count: 86296
CPU 0 DPC highest execution time (µs): 234.069444
CPU 0 DPC total execution time (s): 13.399801
CPU 0 DPC count: 1412534
CPU 1 Interrupt cycle time (s): 4.341672
CPU 1 ISR highest execution time (µs): 22.722222
CPU 1 ISR total execution time (s): 0.036783
CPU 1 ISR count: 12091
CPU 1 DPC highest execution time (µs): 202.8050
CPU 1 DPC total execution time (s): 0.797469
CPU 1 DPC count: 51131
CPU 2 Interrupt cycle time (s): 3.407336
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 61.302778
CPU 2 DPC total execution time (s): 0.264948
CPU 2 DPC count: 34340
CPU 3 Interrupt cycle time (s): 3.221172
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 66.572778
CPU 3 DPC total execution time (s): 0.208091
CPU 3 DPC count: 26672
Things I've tried:
My computer specs:
i3-8100
8 GB RAM Ballistix
MSI H310M PRO-VDH
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 8126 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 0
CPU 3 ISR count: 0
