Hey so I'll run you through what I've done thus far for this issue. Out of the box I've had issues with audio latency and audio crackling and popping, with some slow video streaming maybe related. I Literally just opened a dell inspiron gaming 15. Specs here Imgur: The most awesome images on the Internet
I've uninstalled and reinstalled every audio and network drive from the device manager I could, updated BIOS, reset computer, did a clean install of windows, tried disabling audio enhancements, and ran hardware diagnostics through dell BIOS. Still the same issue. I looked at event viewer and I keep getting a DistributedCOM error if that is related. Here's the errors on my event viewer in just the last couple days. Imgur: The most awesome images on the Internet
Imgur: The most awesome images on the Internet, here are my most recent DPC latency tests.
CONCLUSION
LatencyMon has been analyzing your system for 0:58:26 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-9TLBMDN
OS version: Windows 10 , 10.0, build: 15063 (x64)
Hardware: Inspiron 15 7000 Gaming, Dell Inc., 065C71
CPU: GenuineIntel Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
Logical processors: 8
Processor groups: 1
RAM: 16250 MB total
CPU SPEED
Reported CPU speed: 2808 MHz
Highest measured interrupt to process latency (µs): 8657.314045
Average measured interrupt to process latency (µs): 9.710951
Highest measured interrupt to DPC latency (µs): 8640.174459
Average measured interrupt to DPC latency (µs): 3.151529
REPORTED ISRs
Highest ISR routine execution time (µs): 303.608618
Highest reported total ISR routine time (%): 0.051559
Total time spent in ISRs (%) 0.099580
ISR count (execution time <250 µs): 2983488
ISR count (execution time 500-999 µs): 13
REPORTED DPCs
Highest DPC routine execution time (µs): 4082.277422
Driver with highest DPC routine execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.050380
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0.235143
DPC count (execution time <250 µs): 12933252
DPC count (execution time 500-999 µs): 9235
DPC count (execution time 1000-1999 µs): 71
DPC count (execution time 2000-3999 µs): 6
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Highest hard pagefault resolution time (µs): 0.0
Total time spent in hard pagefaults (%): 0.0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 258.286669
CPU 0 ISR highest execution time (µs): 289.568732
CPU 0 ISR total execution time (s): 26.251478
CPU 0 ISR count: 2841138
CPU 0 DPC highest execution time (µs): 2658.370014
CPU 0 DPC total execution time (s): 43.164898
CPU 0 DPC count: 11393392
CPU 1 Interrupt cycle time (s): 176.846949
CPU 1 ISR highest execution time (µs): 303.608618
CPU 1 ISR total execution time (s): 1.568839
CPU 1 ISR count: 132030
CPU 1 DPC highest execution time (µs): 3480.796652
CPU 1 DPC total execution time (s): 2.763163
CPU 1 DPC count: 160149
CPU 2 Interrupt cycle time (s): 121.335504
CPU 2 ISR highest execution time (µs): 173.743590
CPU 2 ISR total execution time (s): 0.107933
CPU 2 ISR count: 9767
CPU 2 DPC highest execution time (µs): 800.752849
CPU 2 DPC total execution time (s): 4.385037
CPU 2 DPC count: 325794
CPU 3 Interrupt cycle time (s): 179.416298
CPU 3 ISR highest execution time (µs): 85.181980
CPU 3 ISR total execution time (s): 0.005293
CPU 3 ISR count: 566
CPU 3 DPC highest execution time (µs): 698.595442
CPU 3 DPC total execution time (s): 1.361091
CPU 3 DPC count: 88041
CPU 4 Interrupt cycle time (s): 111.209917
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 4082.277422
CPU 4 DPC total execution time (s): 5.259498
CPU 4 DPC count: 399698
CPU 5 Interrupt cycle time (s): 186.456057
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 3776.739316
CPU 5 DPC total execution time (s): 1.903856
CPU 5 DPC count: 122302
CPU 6 Interrupt cycle time (s): 143.796209
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 903.688034
CPU 6 DPC total execution time (s): 5.341283
CPU 6 DPC count: 355458
CPU 7 Interrupt cycle time (s): 181.32990
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 766.199786
CPU 7 DPC total execution time (s): 1.782215
CPU 7 DPC count: 97731
This issue is making me lose my mind and I would love any help I could possibly get. Thanks so much.
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 16250 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
