Hello, all! I'm here to supply you with yet another high DPC latency thread... I recently built this machine (see system info below), and began testing it on some games. Unfortunately I've been getting some issues where I will get framerate stuttering (small, random drops) and the audio will usually cut out as well when this occurs. I'm a bit at a loss as all the "solutions" I've found on the internet do not seem to solve the issue for me. Although, I will say, this does seem to be quite common. I have done zero messing about with configurations (i.e. no xmp profiles, no OC'ing). Any insight would be greatly appreciated! This is quite frustrating...
- Windows 10 Build 10.0.19043 Build 19043
- CPU: i7-11700K
- Mobo: ASUS ROG Strix z590-e gaming
- BIOS Version American Megatrends Inc. 0232, 1/6/2021
- GPU: 3080ti EVGA FTW3 Ultra
- Latest drivers as of 08/18/2021
- RAM: 32gb G.SKILL Ribjaws V Series (2 x 16 sticks)
- SSD: Seagate Firecuda 520 2TB
System Information
Operating System: Windows 10 Home 64-bit (10.0, Build 19043) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: ASUS
System Model: System Product Name
BIOS: 0232 (type: UEFI)
Processor: 11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz (16 CPUs), ~3.6GHz
Memory: 32768MB RAM
Available OS Memory: 32622MB RAM
Page File: 11388MB used, 26354MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.0928 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce RTX 3080 Ti
Manufacturer: NVIDIA
Chip type: NVIDIA GeForce RTX 3080 Ti
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_2208&SUBSYS_39673842&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 28419 MB
Dedicated Memory: 12108 MB
Shared Memory: 16311 MB
Current Mode: 2560 x 1440 (32 bit) (144Hz)
HDR Support: Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.685547,0.308594), Green(0.264648,0.667969), Blue(0.150391,0.057617), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.098400, Max Luminance = 400.000000, MaxFullFrameLuminance = 343.748291
Monitor Name: Generic PnP Monitor
Monitor Model: LG ULTRAGEAR
Monitor Id: GSM5B7F
Native Mode: 2560 x 1440(p) (143.973Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Supported (BT2020RGB BT2020YCC Eotf2084Supported )
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: AdvancedColorSupported
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll
Driver File Version: 30.00.0014.7168 (English)
Driver Version: 30.0.14.7168
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:True Enabled:False
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported by Graphics driver
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 8/4/2021 5:00:00 PM, 1056280 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71E3E-6148-11CF-F247-69190EC2D335}
Vendor ID: 0x10DE
Device ID: 0x2208
SubSys ID: 0x39673842
Revision ID: 0x00A1
Driver Strong Name: oem27.inf:0f066de3b91c4385:Section091:30.0.14.7168
ci\ven_10de&dev_2208
Rank Of Driver: 00CF2001
Video Accel:
DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeMPEG2_VLD {6F3EC719-3735-42CC-8063-65CC3CB36616} DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD {32FCFE3F-DE46-4A49-861B-AC71110649D5} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 {20BB8B0A-97AA-4571-8E99-64E60606C1A6} {15DF9B21-06C4-47F1-841E-A67C97D7F312} DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC {9947EC6F-689B-11DC-A320-0019DBBC4184} {33FCFE41-DE46-4A49-861B-AC71110649D5} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E} {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A} {6AFFD11E-1D96-42B1-A215-93A31F09A53D} {914C84A3-4078-4FA9-984C-E2F262CB5C9C} {8A1A1031-29BC-46D0-A007-E9B092CA6767}
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 4
MPO Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
MPO Stretch: 10.000X - 0.500X
MPO Media Hints: resizing, colorspace Conversion
MPO Formats: NV12,YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
PanelFitter Stretch: 10.000X - 0.500X
Sound Devices
Description: LG ULTRAGEAR (NVIDIA High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_009A&SUBSYS_38423967&REV_1001
Manufacturer ID: N/A
Product ID: N/A
Type: N/A
Driver Name: nvhda64v.sys
Driver Version: 1.3.38.60 (English)
WHQL Logo'd: n/a
Date and Size: 5/2/2021 5:00:00 PM, 136472 bytes
Other Files:
Driver Provider: NVIDIA Corporation
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek USB Audio)
Hardware ID: USB\VID_0B05&PID_1996&REV_0006&MI_00
Product ID: N/A
Type: N/A
Driver Name: RtUsbA64.2276.sys
Driver Version: 6.3.9600.2276 (English)
WHQL Logo'd: n/a
Date and Size: 12/21/2020 5:00:00 PM, 449840 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
Cap Flags: 0x0
HW Memory: 0
Description: Speakers (Realtek USB Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Product ID: N/A
Type: N/A
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Description: Microphone (Realtek USB Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB DEVICE
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0C45, 0x767D
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: HID-compliant consumer control device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0091
FF Driver: n/a
Device Name: AURA LED Controller
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x18F3
FF Driver: n/a
Device Name: Razer Viper 8KHz
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: USB Audio
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x1996
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x8086, 0x43ED
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 8/17/2021 18:14:12, 653136 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x174C, 0x2074
| | Matching Device ID: USB\USB20_HUB
| | Service: USBHUB3
| +-+ USB Composite Device
| | | Matching Device ID: USB\COMPOSITE
| | | Service: usbccgp
| | | Driver: usbccgp.sys, 4/9/2021 06:47:35, 185664 bytes
| | +-+ USB Input Device
| | | | Matching Device ID: USB\Class_03&SubClass_01
| | | | Service: HidUsb
| | | | Driver: hidusb.sys, 4/9/2021 06:47:35, 44032 bytes
| | | | Driver: hidclass.sys, 4/9/2021 06:47:35, 225792 bytes
| | | | Driver: hidparse.sys, 4/9/2021 06:47:35, 46080 bytes
| | | +-+ HID Keyboard Device
| | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | | Service: kbdhid
| | | | | Driver: kbdhid.sys, 12/7/2019 02:07:56, 46592 bytes
| | | | | Driver: kbdclass.sys, 12/7/2019 02:07:56, 71480 bytes
| | | | Service: HidUsb
| | | | | Service: kbdhid
| | | Service: usbccgp
| | +-+ Razer Viper 8KHz
| | | | Matching Device ID: usb\vid_1532&pid_0091&mi_00
| | | | Service: HidUsb
| | | | Driver: RzS3WizardPkgS3.exe, , 0 bytes
| | | | Driver: RazerS3Coinstaller.dll, 4/28/2021 21:25:04, 79832 bytes
| | | +-+ HID-compliant mouse
| | | | | Matching Device ID: HID\VID_1532&PID_0091&MI_00
| | | | | Upper Filters: RzDev_0091
| | | | | Service: mouhid
| | | | | Driver: RzDev_0091.sys, 10/4/2020 07:34:18, 55704 bytes
| | | | | Driver: mouhid.sys, 12/7/2019 02:07:56, 35328 bytes
| | | | | Driver: mouclass.sys, 12/7/2019 02:07:56, 67600 bytes
| | | | Matching Device ID: USB\VID_1532&PID_0091&MI_01
| | | | Lower Filters: RzDev_0091
| | | | Service: HidUsb
| | | | | Matching Device ID: HID\VID_1532&PID_0091&MI_01&Col01
| | | | | Service: kbdhid
| | | | Service: HidUsb
| | | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 1561.9 GB
Total Space: 1907.1 GB
File System: NTFS
Model: Seagate FireCuda 520 SSD ZP2000GM30002
System Devices
Name: SM Bus Controller
Device ID: PCI\VEN_8086&DEV_43A3&SUBSYS_86941043&REV_11\3&11583659&0&FC
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_43C8&SUBSYS_86941043&REV_11\3&11583659&0&FB
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 139776 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.19041.0746 (English), 4/9/2021 06:47:34, 97792 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.19041.0746 (English), 4/9/2021 06:47:34, 388608 bytes
Name: Intel(R) Wi-Fi 6E AX210 160MHz
Device ID: PCI\VEN_8086&DEV_2725&SUBSYS_00248086&REV_1A\4&13199003&0&00E7
Driver: C:\Windows\system32\DRIVERS\Netwtw10.sys, 22.70.0000.0006 (English), 7/12/2021 21:50:06, 5336144 bytes
Driver: C:\Windows\system32\DRIVERS\Netwfw10.dat, 7/12/2021 17:06:46, 45554408 bytes
Driver: C:\Windows\system32\IntelIHVRouter08.dll, 22.12070.0000.0001 (English), 7/12/2021 21:49:56, 1518160 bytes
Device ID: PCI\VEN_8086&DEV_43C0&SUBSYS_86941043&REV_11\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.19041.1151 (English), 8/17/2021 18:14:12, 474928 bytes
Device ID: PCI\VEN_8086&DEV_4C09&SUBSYS_00000000&REV_01\3&11583659&0&30
Name: Intel(R) Serial IO I2C Host Controller - 43E8
Device ID: PCI\VEN_8086&DEV_43E8&SUBSYS_86941043&REV_11\3&11583659&0&A8
Driver: C:\Windows\System32\DriverStore\FileRepository\ialpss2_i2c_tgl.inf_amd64_70d4531ccdd0c3c2\iaLPSS2_I2C_TGL.sys, 30.100.2042.0001 (English), 11/20/2020 03:29:40, 197288 bytes
Device ID: PCI\VEN_10DE&DEV_1AEF&SUBSYS_39673842&REV_A1\4&39FDDC03&0&0108
Name: Intel(R) Management Engine Interface #1
Device ID: PCI\VEN_8086&DEV_43E0&SUBSYS_86941043&REV_11\3&11583659&0&B0
Driver: C:\Windows\System32\DriverStore\FileRepository\heci.inf_amd64_6557ea4289534d04\x64\TeeDriverW10x64.sys, 2040.100.0000.1029 (English), 11/9/2020 08:13:26, 308656 bytes
Device ID: PCI\VEN_8086&DEV_43BE&SUBSYS_86941043&REV_11\3&11583659&0&E6
Name: NVIDIA GeForce RTX 3080 Ti
Device ID: PCI\VEN_10DE&DEV_2208&SUBSYS_39673842&REV_A1\4&39FDDC03&0&0008
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NVWMI\nvPerfProvider.man, 8/5/2021 14:12:52, 14175 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NVWMI\nvWmi.mof, 8/5/2021 14:12:52, 147910 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NVWMI\nvWmi64.exe, 2.36.0000.0000 (English), 8/6/2021 01:46:10, 4450944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\MessageBus.dll, 1.22.2758.1620 (English), 8/6/2021 01:45:20, 7532664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\NVDisplay.Container.exe, 1.33.2988.2648 (English), 8/6/2021 01:45:22, 911992 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\NvContainerRecovery.bat, 8/5/2021 14:12:52, 1951 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\dlsargs.xml, 8/5/2021 14:12:52, 396 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\dlsnetparams.csv, 8/5/2021 14:12:52, 60689 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\messagebus_client.conf, 8/5/2021 14:12:52, 57 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\nvgwls.exe, 8/6/2021 01:45:24, 33227896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\nvtopps.db3, 8/5/2021 14:12:52, 110592 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\NvXDCore.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:28, 1833104 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\NvcDispCorePlugin.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:24, 521336 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\NvcDispWatchdog.dll, 1.33.2988.2648 (English), 8/6/2021 01:45:28, 646288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\_DisplayDriverRAS.dll, 1.10.0000.0000 (English), 8/6/2021 01:45:30, 2616464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\_NvMsgBusBroadcast.dll, 1.33.2988.2648 (English), 8/6/2021 01:45:32, 3160208 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\messagebus.conf, 8/5/2021 14:12:52, 57 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\NvFBCPlugin.dll, 6.14.0014.7168 (English), 8/6/2021 01:45:32, 1372304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\_nvppo.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:42, 1607824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\_nvtopps.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:44, 12257936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\nvprofileupdaterplugin.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:34, 2189968 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\nvxdsyncplugin.dll, 8.17.0014.7168 (English), 8/6/2021 01:45:38, 1811088 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\wksServicePlugin.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:40, 609424 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 30.00.0014.7168 (English), 8/6/2021 01:39:16, 728208 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 8/5/2021 14:12:52, 1778856 bytes
Driver: C:\Windows\system32\nvcpl.dll, 8.17.0014.7168 (English), 8/6/2021 01:40:08, 5680768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nv3dappshext.dll, 6.14.0014.7168 (English), 8/6/2021 01:39:32, 1000080 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nv3dappshextr.dll, 6.14.0014.7168 (English), 8/6/2021 01:39:34, 91264 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcoproc.bin, 8/5/2021 14:12:52, 9650987 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcpl.dll, 8.17.0014.7168 (English), 8/6/2021 01:40:08, 5680768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdevtools.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:44, 4540024 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdevtoolsr.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:46, 232592 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdisps.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:50, 11597432 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdispsr.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:52, 11318904 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvgames.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:14, 12336272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvgamesr.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:16, 12541560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvlicensings.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:58, 4541056 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvlicensingsr.dll, 6.14.0014.7168 (English), 8/6/2021 01:42:00, 290944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvshext.dll, 1.02.0000.0001 (English), 8/6/2021 01:44:08, 129144 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsmartmax.dll, 6.14.0010.10003 (English), 8/6/2021 01:44:10, 203896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsmartmax64.dll, 6.14.0010.10003 (English), 8/6/2021 01:44:10, 243320 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsmartmaxapp.exe, 6.14.0010.10003 (English), 8/6/2021 01:44:12, 273528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsmartmaxapp64.exe, 6.14.0010.10003 (English), 8/6/2021 01:44:14, 283768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsvc64.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:16, 2648184 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsvcr.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:18, 1767040 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsvs.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:20, 5057656 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsvsr.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:22, 1946240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvui.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:26, 6628472 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvuir.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:30, 2572920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvvitvs.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:36, 7402616 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvvitvsr.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:36, 4112000 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwss.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:42, 12066944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwssr.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:44, 9345664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvxdapix.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:50, 9206400 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvxdbat.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:52, 1617536 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvxdplcy.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:56, 1870968 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so, 8/5/2021 14:12:52, 141464 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so.1, 8/5/2021 14:12:52, 141464 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so.1.1, 8/5/2021 14:12:52, 141464 bytes
Driver: C:\Windows\system32\lxss\lib\libnvcuvid.so.1, 8/5/2021 14:12:52, 6175952 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-encode.so.1, 8/5/2021 14:12:52, 424448 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-ml.so.1, 8/5/2021 14:12:52, 197528 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-opticalflow.so.1, 8/5/2021 14:12:52, 354816 bytes
Driver: C:\Windows\system32\lxss\lib\libnvwgf2umx.so, 8/5/2021 14:12:52, 49664192 bytes
Driver: C:\Windows\system32\lxss\lib\nvidia-smi, 8/5/2021 14:12:52, 678392 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\license.txt, 8/5/2021 14:12:52, 28827 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\_nvngx.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:20, 1537144 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\cudnn_infer64_7.dll, 8/6/2021 01:39:08, 22773136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvngx.dll, 30.00.0014.9516 (English), 8/6/2021 01:42:06, 487600 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvngx_update.exe, 30.00.0014.7168 (English), 8/6/2021 01:42:08, 1188480 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvngxdlss.dll, 8/6/2021 01:42:06, 26288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\FreqTransfer32.exe, 8/6/2021 01:45:50, 3700880 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\FreqTransfer64.exe, 8/6/2021 01:45:52, 4000912 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\GreenScreenBG01.jpg, 8/5/2021 14:12:52, 281528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\GreenScreenBG02.jpg, 8/5/2021 14:12:52, 499736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\HighresBlender32.exe, 8/6/2021 01:45:52, 3802256 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\HighresBlender64.exe, 8/6/2021 01:45:54, 4098704 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCamera32.dll, 7.01.0774.0783 (English), 8/6/2021 01:45:54, 8055936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCamera64.dll, 7.01.0774.0783 (English), 8/6/2021 01:45:56, 8699536 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCameraAllowlisting32.dll, 7.01.0774.0783 (English), 8/6/2021 01:45:56, 558208 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCameraAllowlisting64.dll, 7.01.0774.0783 (English), 8/6/2021 01:45:58, 702592 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCameraEnable.exe, 8/6/2021 01:45:58, 370816 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvImageConvert32.exe, 8/6/2021 01:46:00, 3705472 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvImageConvert64.exe, 8/6/2021 01:46:00, 3984512 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\ReShadeFXC32.exe, 2.00.0000.0000 (English), 8/6/2021 01:46:02, 772224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\ReShadeFXC64.exe, 2.00.0000.0000 (English), 8/6/2021 01:46:02, 887936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\ShotWithGeforce518x32.rgba, 8/5/2021 14:12:52, 66304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\SphericalEquirect32.exe, 8/6/2021 01:46:04, 3674240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\SphericalEquirect64.exe, 8/6/2021 01:46:04, 3921536 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker01.png, 8/5/2021 14:12:52, 49695 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker02.png, 8/5/2021 14:12:52, 474002 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker03.png, 8/5/2021 14:12:52, 380006 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker04.png, 8/5/2021 14:12:52, 86881 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker05.png, 8/5/2021 14:12:52, 59304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker06.png, 8/5/2021 14:12:52, 13547 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker07.png, 8/5/2021 14:12:52, 6342 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker08.png, 8/5/2021 14:12:52, 96493 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\YAMLFXC32.exe, 8/6/2021 01:46:08, 1764992 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\YAMLFXC64.exe, 8/6/2021 01:46:08, 1932928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\d3dcompiler_47_32.dll, 6.03.9600.16384 (English), 8/6/2021 01:45:48, 3466896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\d3dcompiler_47_64.dll, 6.03.9600.16384 (English), 8/6/2021 01:45:48, 4173968 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\filternames.cfg, 8/5/2021 14:12:52, 13976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\fxtools.cfg, 8/5/2021 14:12:52, 81 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\scratches.jpg, 8/5/2021 14:12:52, 346354 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\tools_licenses.txt, 8/5/2021 14:12:52, 17234 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\ui.tga, 8/5/2021 14:12:52, 120236 bytes
Driver: C:\Windows\system32\MCU.exe, 1.01.5204.20580 (English), 8/6/2021 01:39:30, 849024 bytes
Driver: C:\Windows\system32\nvdebugdump.exe, 6.14.0014.7168 (English), 8/6/2021 01:40:40, 447096 bytes
Driver: C:\Windows\system32\nvidia-smi.exe, 8.17.0014.7168 (English), 8/6/2021 01:41:24, 706168 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvopencl32.dll, 30.00.0014.7168 (English), 8/6/2021 01:42:36, 17666168 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvopencl64.dll, 30.00.0014.7168 (English), 8/6/2021 01:42:42, 20330128 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcompiler32.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:42, 41371792 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcompiler64.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:56, 46108792 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvlddmkm.sys, 30.00.0014.7168 (English), 8/6/2021 01:41:50, 37433984 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libcuda.so.1.1, 8/5/2021 14:12:52, 23834920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libcuda_loader.so, 8/5/2021 14:12:52, 141464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvcuvid.so.1, 8/5/2021 14:12:52, 6175952 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-encode.so.1, 8/5/2021 14:12:52, 424448 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-ml.so.1, 8/5/2021 14:12:52, 1824024 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-ml_loader.so, 8/5/2021 14:12:52, 197528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-opticalflow.so.1, 8/5/2021 14:12:52, 354816 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-ptxjitcompiler.so.1, 8/5/2021 14:12:52, 11144408 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvwgf2umx.so, 8/5/2021 14:12:52, 49664192 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nv-vk64.json, 8/5/2021 14:12:52, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvDecMFTMjpeg.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:42, 604280 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvDecMFTMjpegx.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:42, 747128 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvEncMFTH264.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:56, 1137296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvEncMFTH264x.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:58, 1449104 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvEncMFThevc.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:02, 1143440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvEncMFThevcx.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:04, 1458320 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcbl64.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:36, 688272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcuda32.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:10, 21752440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcuda64.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:16, 24863352 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvd3dumx.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:48, 26205296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvd3dumx_cfg.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:58, 26453120 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdlistx.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:14, 216136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvidia-smi, 8/5/2021 14:12:52, 678392 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:18, 1056280 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvml.dll, 8.17.0014.7168 (English), 8/6/2021 01:42:02, 1121920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvoglv64.dll, 30.00.0014.7168 (English), 8/6/2021 01:42:22, 44886160 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvoptix.dll, 7.04.0000.0000 (English), 8/6/2021 01:42:54, 233656464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvptxJitCompiler32.dll, 30.00.0014.7168 (English), 8/6/2021 01:43:36, 7745664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvptxJitCompiler64.dll, 30.00.0014.7168 (English), 8/6/2021 01:43:42, 8798848 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvrtum64.dll, 30.00.0014.7168 (English), 8/6/2021 01:43:46, 76673152 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvvm64_40_0.dll, 6.14.0011.9000 (English), 8/6/2021 01:44:40, 17700480 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwgf2umx.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:36, 77946024 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwgf2umx_cfg.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:56, 78356896 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:14, 2112144 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:44, 1520760 bytes
Driver: C:\Windows\system32\NvIFROpenGL.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:48, 676480 bytes
Driver: C:\Windows\system32\OpenCL.dll, 3.00.0001.0000 (English), 8/6/2021 01:45:08, 1474672 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:08, 919184 bytes
Driver: C:\Windows\system32\nvapi64.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:32, 7280848 bytes
Driver: C:\Windows\system32\nvcuda.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:30, 2925688 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0014.7168 (English), 8/6/2021 01:40:36, 8854136 bytes
Driver: C:\Windows\system32\nvinfo.pb, 8/5/2021 14:12:52, 83062 bytes
Driver: C:\Windows\system32\nvml.dll, 8.17.0014.7168 (English), 8/6/2021 01:42:04, 645248 bytes
Driver: C:\Windows\system32\nvofapi64.dll, 8/6/2021 01:42:10, 716928 bytes
Driver: C:\Windows\system32\vulkan-1-999-0-0-0.dll, 1.02.0170.0000 (English), 8/6/2021 01:45:10, 1097832 bytes
Driver: C:\Windows\system32\vulkan-1.dll, 1.02.0170.0000 (English), 8/6/2021 01:45:10, 1097832 bytes
Driver: C:\Windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.02.0170.0000 (English), 8/6/2021 01:45:16, 1858680 bytes
Driver: C:\Windows\system32\vulkaninfo.exe, 1.02.0170.0000 (English), 8/6/2021 01:45:16, 1858680 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nv-vk32.json, 8/5/2021 14:12:52, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvIccAdvancedColorIdentity.icm, 8/5/2021 14:12:52, 3288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvd3dum.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:38, 22410824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvd3dum_cfg.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:06, 22797256 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdispco64.exe, 1.00.0016.0000 (English), 8/6/2021 01:40:48, 1550456 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdlist.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:12, 181824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumd.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:18, 880664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvoglv32.dll, 30.00.0014.7168 (English), 8/6/2021 01:42:12, 33858688 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwgf2um.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:24, 33602920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwgf2um_cfg.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:14, 34216968 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:10, 1595536 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:42, 1171088 bytes
Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:46, 564352 bytes
Driver: C:\Windows\SysWow64\OpenCL.dll, 3.00.0001.0000 (English), 8/6/2021 01:45:04, 1212536 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:06, 750200 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:30, 6215808 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:24, 4987512 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0014.7168 (English), 8/6/2021 01:40:32, 7920760 bytes
Driver: C:\Windows\SysWow64\nvofapi.dll, 8/6/2021 01:42:10, 577152 bytes
Driver: C:\Windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.02.0170.0000 (English), 8/6/2021 01:45:14, 951928 bytes
Driver: C:\Windows\SysWow64\vulkan-1.dll, 1.02.0170.0000 (English), 8/6/2021 01:45:14, 951928 bytes
Driver: C:\Windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.02.0170.0000 (English), 8/6/2021 01:45:16, 1438840 bytes
Driver: C:\Windows\SysWow64\vulkaninfo.exe, 1.02.0170.0000 (English), 8/6/2021 01:45:16, 1438840 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvTelemetry64.dll, 14.03.0060.0000 (English), 8/6/2021 01:44:24, 4465048 bytes
Device ID: PCI\VEN_8086&DEV_43A4&SUBSYS_86941043&REV_11\3&11583659&0&FD
Driver: n/a
Name: PCI standard RAM Controller
Device ID: PCI\VEN_8086&DEV_43EF&SUBSYS_86941043&REV_11\3&11583659&0&A2
Driver: n/a
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_43D2&SUBSYS_86941043&REV_11\3&11583659&0&B8
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 186184 bytes
Device ID: PCI\VEN_8086&DEV_43B8&SUBSYS_86941043&REV_11\3&11583659&0&E0
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_4385&SUBSYS_86941043&REV_11\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 20296 bytes
Device ID: PCI\VEN_8086&DEV_43B0&SUBSYS_86941043&REV_11\3&11583659&0&E8
Name: Intel(R) Serial IO I2C Host Controller - 43E9
Device ID: PCI\VEN_8086&DEV_43E9&SUBSYS_86941043&REV_11\3&11583659&0&A9
Name: Intel(R) Ethernet Controller (3) I225-V #2
Device ID: PCI\VEN_8086&DEV_15F3&SUBSYS_87D21043&REV_03\4&255B870&0&00E6
Driver: C:\Windows\system32\DRIVERS\e2f68.sys, 1.00.0002.0006 (English), 9/29/2020 20:20:36, 520552 bytes
Driver: C:\Windows\system32\e2f68.din, 9/29/2020 20:09:10, 2996 bytes
Device ID: PCI\VEN_8086&DEV_43BF&SUBSYS_86941043&REV_11\3&11583659&0&E7
Name: Intel(R) USB 3.20 eXtensible Host Controller - 1.20 (Microsoft)
Device ID: PCI\VEN_8086&DEV_43ED&SUBSYS_86941043&REV_11\3&11583659&0&A0
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 608568 bytes
Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 146736 bytes
Device ID: PCI\VEN_8086&DEV_15F3&SUBSYS_87D21043&REV_03\4&356AA108&0&00E5
Name: Standard NVM Express Controller
Device ID: PCI\VEN_1BB1&DEV_5016&SUBSYS_50161BB1&REV_01\4&12FB7CC4&0&0030
Driver: C:\Windows\system32\DRIVERS\stornvme.sys, 10.00.19041.0844 (English), 4/9/2021 06:47:35, 155960 bytes
Device ID: PCI\VEN_8086&DEV_4C01&SUBSYS_86941043&REV_01\3&11583659&0&08
Device ID: PCI\VEN_8086&DEV_43BD&SUBSYS_86941043&REV_11\3&11583659&0&E5
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_8086&DEV_4C43&SUBSYS_86941043&REV_01\3&11583659&0&00
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.19041.0508
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.19041.0508
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.19041.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.19041.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.19041.0450
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.19041.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.19041.1110
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.19041.1165
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.19041.1165
DV Muxer,0x00400000,0,0,qdv.dll,10.00.19041.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.19041.0746
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.19041.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.19041.0746
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.19041.0746
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.19041.1151
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.19041.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.19041.0746
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.19041.0746
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.19041.0329
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.19041.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.19041.0746
DV Splitter,0x00600000,1,2,qdv.dll,10.00.19041.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.19041.0746
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.19041.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.19041.0746
Video Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.19041.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.19041.0746
Video Renderer,0x00400000,1,0,quartz.dll,10.00.19041.0746
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.19041.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.19041.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.19041.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.19041.0746
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.19041.0746
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.19041.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.19041.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.19041.0746
Null Renderer,0x00200000,1,0,qedit.dll,10.00.19041.0746
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.19041.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.19041.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.19041.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.19041.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.19041.0746
Wave Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
File stream renderer,0x00400000,1,1,quartz.dll,10.00.19041.0746
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.19041.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.19041.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.19041.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.19041.0746
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.19041.0746
File Source (URL),0x00400000,0,1,quartz.dll,10.00.19041.0746
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.19041.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.19041.0546
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.19041.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.19041.0746
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.19041.0867
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.19041.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.19041.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.19041.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.19041.0746
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.19041.0508
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.19041.0508
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.19041.0746
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.19041.0746
Audio Capture Sources:
Microphone (Realtek USB Audio),0x00200000,0,0,qcap.dll,10.00.19041.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.19041.1052
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.1052
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.1052
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.19041.0746
WDM Streaming Capture Devices:
Realtek USB Audio,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
SONICSTUDIOVAD Wave Speaker,0x00200000,2,2,ksproxy.ax,10.00.19041.0746
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.19041.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.19041.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.19041.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek USB Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: Realtek Digital Output (Realtek USB Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: LG ULTRAGEAR (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: Speakers (Realtek USB Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.19041.1165
mfreadwrite.dll, 10.00.19041.0746
mfcaptureengine.dll, 10.00.19041.0906
mfsensorgroup.dll, 10.00.19041.1151
windows.media.dll, 10.00.19041.1023
frameserver.dll, 10.00.19041.1151
frameserverclient.dll, 10.00.19041.1151
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 30.00.0014.7168
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.19041.1151
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.19041.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.19041.0450
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.19041.1151
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.19041.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.19041.1110
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.19041.0329
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.19041.1165
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.19041.1165
WebpImageExtension
HEIFImageExtension
VP9VideoExtensionDecoder
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 30.00.0014.7168
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 30.00.0014.7168
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.19041.0964
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.19041.0867
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.19041.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.19041.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.19041.0001
HEIFImageExtension
VP9VideoExtensionEncoder
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.19041.0867
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.19041.0746
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.19041.1110
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.19041.0789
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.19041.1165
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.19041.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.19041.0508
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.19041.1165
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.19041.1165
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.19041.1165
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.19041.0508
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.19041.0746
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.19041.1023
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.19041.1165
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.19041.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.19041.1165
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.19041.1165
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.19041.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.19041.0746
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.19041.1165
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
DTSXDecoder
DTSHDDecoder
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.19041.1165
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.19041.0746
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.19041.0508
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.19041.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.19041.0001
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.19041.0508
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.19041.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.19041.0746
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.19041.0001
DTS Headphone:X
DTS:X Ultra
DTS:X for home theater
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.19041.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.19041.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.19041.1081
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.19041.1151
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket , type 0
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: HorizonZeroDawn.exe
P2: 1.0.10.5
P3: 6014986d
P4: 2ed6
P5: 134217728
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 1361664313210578765, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P2: 1.0.10.5
P3: 10.0.19043.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 1349405470884464173, type 5
Cab Id: 0
Problem signature:
P1: Craftopia.exe
P2: 2020.3.8.31001
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER3 +++:
Fault bucket 2136258113090108188, type 5
Cab Id: 0
Problem signature:
P1: Wow.exe
P2: 9.1.0.39653
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER4 +++:
Fault bucket 1968021804718729116, type 5
Cab Id: 0
Problem signature:
P1: WowClassic.exe
P2: 2.5.1.39603
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER5 +++:
Fault bucket 1784904111423362780, type 5
Event Name: WindowsWcpOtherFailure3
Cab Id: 0
Problem signature:
P1: 10.0.19041.1161:1
P2: wcp\componentstore\storelayout.cpp
P3: ComponentStore::CRawStoreLayout::HydrateFileUsingForwardAndReverseDeltas
P4: 1682
P5: 800f0984
P6: 0x734f02fe
P7:
P8:
P9:
P10:
+++ WER6 +++:
Cab Id: 0
Problem signature:
P4: 1682
P5: 800f0984
P6: 0x734f02fe
P7:
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P4: 1682
P5: 800f0984
P6: 0x734f02fe
P7:
P8:
P9:
P10:
+++ WER8 +++:
Fault bucket 1154352724820394255, type 5
Event Name: BEX
Cab Id: 0
Problem signature:
P1: NahimicSvc32.exe
P2: 2.6.3.0
P3: 5efaf438
P4: DeviceRoutingDaemonModule.dll
P5: 2.2.9.64544
P6: 5f34e0f9
P7: 0004c047
P8: c0000409
P9: 00000007
P10:
+++ WER9 +++:
Fault bucket 1816425235566691406, type 5
Event Name: MoAppCrash
Cab Id: 0
Problem signature:
P1: Microsoft.Windows.Search_1.14.0.19041_neutral_neutral_cw5n1h2txyewy
P2: praid:CortanaUI
P3: 10.0.19041.844
P4: 69441820
P5: KERNELBASE.dll
P6: 10.0.19041.906
P7: 2f2f77bf
P8: c0000602
P9: 000000000010b2dc
P10:
System Information
Operating System: Windows 10 Home 64-bit (10.0, Build 19043) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: ASUS
System Model: System Product Name
BIOS: 0232 (type: UEFI)
Processor: 11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz (16 CPUs), ~3.6GHz
Memory: 32768MB RAM
Available OS Memory: 32622MB RAM
Page File: 11388MB used, 26354MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.0928 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce RTX 3080 Ti
Manufacturer: NVIDIA
Chip type: NVIDIA GeForce RTX 3080 Ti
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_2208&SUBSYS_39673842&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 28419 MB
Dedicated Memory: 12108 MB
Shared Memory: 16311 MB
Current Mode: 2560 x 1440 (32 bit) (144Hz)
HDR Support: Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.685547,0.308594), Green(0.264648,0.667969), Blue(0.150391,0.057617), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.098400, Max Luminance = 400.000000, MaxFullFrameLuminance = 343.748291
Monitor Name: Generic PnP Monitor
Monitor Model: LG ULTRAGEAR
Monitor Id: GSM5B7F
Native Mode: 2560 x 1440(p) (143.973Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Supported (BT2020RGB BT2020YCC Eotf2084Supported )
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: AdvancedColorSupported
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll
Driver File Version: 30.00.0014.7168 (English)
Driver Version: 30.0.14.7168
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:True Enabled:False
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported by Graphics driver
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 8/4/2021 5:00:00 PM, 1056280 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71E3E-6148-11CF-F247-69190EC2D335}
Vendor ID: 0x10DE
Device ID: 0x2208
SubSys ID: 0x39673842
Revision ID: 0x00A1
Driver Strong Name: oem27.inf:0f066de3b91c4385:Section091:30.0.14.7168
Rank Of Driver: 00CF2001
Video Accel:
DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeMPEG2_VLD {6F3EC719-3735-42CC-8063-65CC3CB36616} DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD {32FCFE3F-DE46-4A49-861B-AC71110649D5} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 {20BB8B0A-97AA-4571-8E99-64E60606C1A6} {15DF9B21-06C4-47F1-841E-A67C97D7F312} DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC {9947EC6F-689B-11DC-A320-0019DBBC4184} {33FCFE41-DE46-4A49-861B-AC71110649D5} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E} {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A} {6AFFD11E-1D96-42B1-A215-93A31F09A53D} {914C84A3-4078-4FA9-984C-E2F262CB5C9C} {8A1A1031-29BC-46D0-A007-E9B092CA6767}
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 4
MPO Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
MPO Stretch: 10.000X - 0.500X
MPO Media Hints: resizing, colorspace Conversion
MPO Formats: NV12,YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
PanelFitter Stretch: 10.000X - 0.500X
Sound Devices
Description: LG ULTRAGEAR (NVIDIA High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_009A&SUBSYS_38423967&REV_1001
Manufacturer ID: N/A
Product ID: N/A
Type: N/A
Driver Name: nvhda64v.sys
Driver Version: 1.3.38.60 (English)
WHQL Logo'd: n/a
Date and Size: 5/2/2021 5:00:00 PM, 136472 bytes
Other Files:
Driver Provider: NVIDIA Corporation
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek USB Audio)
Hardware ID: USB\VID_0B05&PID_1996&REV_0006&MI_00
Product ID: N/A
Type: N/A
Driver Name: RtUsbA64.2276.sys
Driver Version: 6.3.9600.2276 (English)
WHQL Logo'd: n/a
Date and Size: 12/21/2020 5:00:00 PM, 449840 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
Cap Flags: 0x0
HW Memory: 0
Description: Speakers (Realtek USB Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Product ID: N/A
Type: N/A
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Description: Microphone (Realtek USB Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB DEVICE
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0C45, 0x767D
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: HID-compliant consumer control device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0091
FF Driver: n/a
Device Name: AURA LED Controller
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x18F3
FF Driver: n/a
Device Name: Razer Viper 8KHz
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: USB Audio
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x1996
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x8086, 0x43ED
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 8/17/2021 18:14:12, 653136 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x174C, 0x2074
| | Matching Device ID: USB\USB20_HUB
| | Service: USBHUB3
| +-+ USB Composite Device
| | | Matching Device ID: USB\COMPOSITE
| | | Service: usbccgp
| | | Driver: usbccgp.sys, 4/9/2021 06:47:35, 185664 bytes
| | +-+ USB Input Device
| | | | Matching Device ID: USB\Class_03&SubClass_01
| | | | Service: HidUsb
| | | | Driver: hidusb.sys, 4/9/2021 06:47:35, 44032 bytes
| | | | Driver: hidclass.sys, 4/9/2021 06:47:35, 225792 bytes
| | | | Driver: hidparse.sys, 4/9/2021 06:47:35, 46080 bytes
| | | +-+ HID Keyboard Device
| | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | | Service: kbdhid
| | | | | Driver: kbdhid.sys, 12/7/2019 02:07:56, 46592 bytes
| | | | | Driver: kbdclass.sys, 12/7/2019 02:07:56, 71480 bytes
| | | | Service: HidUsb
| | | | | Service: kbdhid
| | | Service: usbccgp
| | +-+ Razer Viper 8KHz
| | | | Matching Device ID: usb\vid_1532&pid_0091&mi_00
| | | | Service: HidUsb
| | | | Driver: RzS3WizardPkgS3.exe, , 0 bytes
| | | | Driver: RazerS3Coinstaller.dll, 4/28/2021 21:25:04, 79832 bytes
| | | +-+ HID-compliant mouse
| | | | | Matching Device ID: HID\VID_1532&PID_0091&MI_00
| | | | | Upper Filters: RzDev_0091
| | | | | Service: mouhid
| | | | | Driver: RzDev_0091.sys, 10/4/2020 07:34:18, 55704 bytes
| | | | | Driver: mouhid.sys, 12/7/2019 02:07:56, 35328 bytes
| | | | | Driver: mouclass.sys, 12/7/2019 02:07:56, 67600 bytes
| | | | Matching Device ID: USB\VID_1532&PID_0091&MI_01
| | | | Lower Filters: RzDev_0091
| | | | Service: HidUsb
| | | | | Matching Device ID: HID\VID_1532&PID_0091&MI_01&Col01
| | | | | Service: kbdhid
| | | | Service: HidUsb
| | | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 1561.9 GB
Total Space: 1907.1 GB
File System: NTFS
Model: Seagate FireCuda 520 SSD ZP2000GM30002
System Devices
Name: SM Bus Controller
Device ID: PCI\VEN_8086&DEV_43A3&SUBSYS_86941043&REV_11\3&11583659&0&FC
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_43C8&SUBSYS_86941043&REV_11\3&11583659&0&FB
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 139776 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.19041.0746 (English), 4/9/2021 06:47:34, 97792 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.19041.0746 (English), 4/9/2021 06:47:34, 388608 bytes
Name: Intel(R) Wi-Fi 6E AX210 160MHz
Device ID: PCI\VEN_8086&DEV_2725&SUBSYS_00248086&REV_1A\4&13199003&0&00E7
Driver: C:\Windows\system32\DRIVERS\Netwtw10.sys, 22.70.0000.0006 (English), 7/12/2021 21:50:06, 5336144 bytes
Driver: C:\Windows\system32\DRIVERS\Netwfw10.dat, 7/12/2021 17:06:46, 45554408 bytes
Driver: C:\Windows\system32\IntelIHVRouter08.dll, 22.12070.0000.0001 (English), 7/12/2021 21:49:56, 1518160 bytes
Device ID: PCI\VEN_8086&DEV_43C0&SUBSYS_86941043&REV_11\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.19041.1151 (English), 8/17/2021 18:14:12, 474928 bytes
Device ID: PCI\VEN_8086&DEV_4C09&SUBSYS_00000000&REV_01\3&11583659&0&30
Name: Intel(R) Serial IO I2C Host Controller - 43E8
Device ID: PCI\VEN_8086&DEV_43E8&SUBSYS_86941043&REV_11\3&11583659&0&A8
Driver: C:\Windows\System32\DriverStore\FileRepository\ialpss2_i2c_tgl.inf_amd64_70d4531ccdd0c3c2\iaLPSS2_I2C_TGL.sys, 30.100.2042.0001 (English), 11/20/2020 03:29:40, 197288 bytes
Device ID: PCI\VEN_10DE&DEV_1AEF&SUBSYS_39673842&REV_A1\4&39FDDC03&0&0108
Name: Intel(R) Management Engine Interface #1
Device ID: PCI\VEN_8086&DEV_43E0&SUBSYS_86941043&REV_11\3&11583659&0&B0
Driver: C:\Windows\System32\DriverStore\FileRepository\heci.inf_amd64_6557ea4289534d04\x64\TeeDriverW10x64.sys, 2040.100.0000.1029 (English), 11/9/2020 08:13:26, 308656 bytes
Device ID: PCI\VEN_8086&DEV_43BE&SUBSYS_86941043&REV_11\3&11583659&0&E6
Name: NVIDIA GeForce RTX 3080 Ti
Device ID: PCI\VEN_10DE&DEV_2208&SUBSYS_39673842&REV_A1\4&39FDDC03&0&0008
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NVWMI\nvPerfProvider.man, 8/5/2021 14:12:52, 14175 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NVWMI\nvWmi.mof, 8/5/2021 14:12:52, 147910 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NVWMI\nvWmi64.exe, 2.36.0000.0000 (English), 8/6/2021 01:46:10, 4450944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\MessageBus.dll, 1.22.2758.1620 (English), 8/6/2021 01:45:20, 7532664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\NVDisplay.Container.exe, 1.33.2988.2648 (English), 8/6/2021 01:45:22, 911992 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\NvContainerRecovery.bat, 8/5/2021 14:12:52, 1951 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\dlsargs.xml, 8/5/2021 14:12:52, 396 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\dlsnetparams.csv, 8/5/2021 14:12:52, 60689 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\messagebus_client.conf, 8/5/2021 14:12:52, 57 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\nvgwls.exe, 8/6/2021 01:45:24, 33227896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\nvtopps.db3, 8/5/2021 14:12:52, 110592 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\NvXDCore.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:28, 1833104 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\NvcDispCorePlugin.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:24, 521336 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\NvcDispWatchdog.dll, 1.33.2988.2648 (English), 8/6/2021 01:45:28, 646288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\_DisplayDriverRAS.dll, 1.10.0000.0000 (English), 8/6/2021 01:45:30, 2616464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\_NvMsgBusBroadcast.dll, 1.33.2988.2648 (English), 8/6/2021 01:45:32, 3160208 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\LocalSystem\messagebus.conf, 8/5/2021 14:12:52, 57 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\NvFBCPlugin.dll, 6.14.0014.7168 (English), 8/6/2021 01:45:32, 1372304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\_nvppo.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:42, 1607824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\_nvtopps.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:44, 12257936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\nvprofileupdaterplugin.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:34, 2189968 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\nvxdsyncplugin.dll, 8.17.0014.7168 (English), 8/6/2021 01:45:38, 1811088 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\Display.NvContainer\plugins\Session\wksServicePlugin.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:40, 609424 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 30.00.0014.7168 (English), 8/6/2021 01:39:16, 728208 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 8/5/2021 14:12:52, 1778856 bytes
Driver: C:\Windows\system32\nvcpl.dll, 8.17.0014.7168 (English), 8/6/2021 01:40:08, 5680768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nv3dappshext.dll, 6.14.0014.7168 (English), 8/6/2021 01:39:32, 1000080 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nv3dappshextr.dll, 6.14.0014.7168 (English), 8/6/2021 01:39:34, 91264 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcoproc.bin, 8/5/2021 14:12:52, 9650987 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcpl.dll, 8.17.0014.7168 (English), 8/6/2021 01:40:08, 5680768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdevtools.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:44, 4540024 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdevtoolsr.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:46, 232592 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdisps.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:50, 11597432 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdispsr.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:52, 11318904 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvgames.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:14, 12336272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvgamesr.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:16, 12541560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvlicensings.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:58, 4541056 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvlicensingsr.dll, 6.14.0014.7168 (English), 8/6/2021 01:42:00, 290944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvshext.dll, 1.02.0000.0001 (English), 8/6/2021 01:44:08, 129144 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsmartmax.dll, 6.14.0010.10003 (English), 8/6/2021 01:44:10, 203896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsmartmax64.dll, 6.14.0010.10003 (English), 8/6/2021 01:44:10, 243320 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsmartmaxapp.exe, 6.14.0010.10003 (English), 8/6/2021 01:44:12, 273528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsmartmaxapp64.exe, 6.14.0010.10003 (English), 8/6/2021 01:44:14, 283768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsvc64.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:16, 2648184 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsvcr.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:18, 1767040 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsvs.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:20, 5057656 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvsvsr.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:22, 1946240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvui.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:26, 6628472 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvuir.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:30, 2572920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvvitvs.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:36, 7402616 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvvitvsr.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:36, 4112000 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwss.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:42, 12066944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwssr.dll, 30.00.0014.7168 (English), 8/6/2021 01:44:44, 9345664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvxdapix.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:50, 9206400 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvxdbat.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:52, 1617536 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvxdplcy.dll, 8.17.0014.7168 (English), 8/6/2021 01:44:56, 1870968 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so, 8/5/2021 14:12:52, 141464 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so.1, 8/5/2021 14:12:52, 141464 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so.1.1, 8/5/2021 14:12:52, 141464 bytes
Driver: C:\Windows\system32\lxss\lib\libnvcuvid.so.1, 8/5/2021 14:12:52, 6175952 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-encode.so.1, 8/5/2021 14:12:52, 424448 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-ml.so.1, 8/5/2021 14:12:52, 197528 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-opticalflow.so.1, 8/5/2021 14:12:52, 354816 bytes
Driver: C:\Windows\system32\lxss\lib\libnvwgf2umx.so, 8/5/2021 14:12:52, 49664192 bytes
Driver: C:\Windows\system32\lxss\lib\nvidia-smi, 8/5/2021 14:12:52, 678392 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\license.txt, 8/5/2021 14:12:52, 28827 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\_nvngx.dll, 30.00.0014.7168 (English), 8/6/2021 01:45:20, 1537144 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\cudnn_infer64_7.dll, 8/6/2021 01:39:08, 22773136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvngx.dll, 30.00.0014.9516 (English), 8/6/2021 01:42:06, 487600 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvngx_update.exe, 30.00.0014.7168 (English), 8/6/2021 01:42:08, 1188480 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvngxdlss.dll, 8/6/2021 01:42:06, 26288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\FreqTransfer32.exe, 8/6/2021 01:45:50, 3700880 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\FreqTransfer64.exe, 8/6/2021 01:45:52, 4000912 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\GreenScreenBG01.jpg, 8/5/2021 14:12:52, 281528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\GreenScreenBG02.jpg, 8/5/2021 14:12:52, 499736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\HighresBlender32.exe, 8/6/2021 01:45:52, 3802256 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\HighresBlender64.exe, 8/6/2021 01:45:54, 4098704 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCamera32.dll, 7.01.0774.0783 (English), 8/6/2021 01:45:54, 8055936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCamera64.dll, 7.01.0774.0783 (English), 8/6/2021 01:45:56, 8699536 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCameraAllowlisting32.dll, 7.01.0774.0783 (English), 8/6/2021 01:45:56, 558208 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCameraAllowlisting64.dll, 7.01.0774.0783 (English), 8/6/2021 01:45:58, 702592 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvCameraEnable.exe, 8/6/2021 01:45:58, 370816 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvImageConvert32.exe, 8/6/2021 01:46:00, 3705472 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\NvImageConvert64.exe, 8/6/2021 01:46:00, 3984512 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\ReShadeFXC32.exe, 2.00.0000.0000 (English), 8/6/2021 01:46:02, 772224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\ReShadeFXC64.exe, 2.00.0000.0000 (English), 8/6/2021 01:46:02, 887936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\ShotWithGeforce518x32.rgba, 8/5/2021 14:12:52, 66304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\SphericalEquirect32.exe, 8/6/2021 01:46:04, 3674240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\SphericalEquirect64.exe, 8/6/2021 01:46:04, 3921536 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker01.png, 8/5/2021 14:12:52, 49695 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker02.png, 8/5/2021 14:12:52, 474002 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker03.png, 8/5/2021 14:12:52, 380006 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker04.png, 8/5/2021 14:12:52, 86881 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker05.png, 8/5/2021 14:12:52, 59304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker06.png, 8/5/2021 14:12:52, 13547 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker07.png, 8/5/2021 14:12:52, 6342 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\Sticker08.png, 8/5/2021 14:12:52, 96493 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\YAMLFXC32.exe, 8/6/2021 01:46:08, 1764992 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\YAMLFXC64.exe, 8/6/2021 01:46:08, 1932928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\d3dcompiler_47_32.dll, 6.03.9600.16384 (English), 8/6/2021 01:45:48, 3466896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\d3dcompiler_47_64.dll, 6.03.9600.16384 (English), 8/6/2021 01:45:48, 4173968 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\filternames.cfg, 8/5/2021 14:12:52, 13976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\fxtools.cfg, 8/5/2021 14:12:52, 81 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\scratches.jpg, 8/5/2021 14:12:52, 346354 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\tools_licenses.txt, 8/5/2021 14:12:52, 17234 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvCamera\ui.tga, 8/5/2021 14:12:52, 120236 bytes
Driver: C:\Windows\system32\MCU.exe, 1.01.5204.20580 (English), 8/6/2021 01:39:30, 849024 bytes
Driver: C:\Windows\system32\nvdebugdump.exe, 6.14.0014.7168 (English), 8/6/2021 01:40:40, 447096 bytes
Driver: C:\Windows\system32\nvidia-smi.exe, 8.17.0014.7168 (English), 8/6/2021 01:41:24, 706168 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvopencl32.dll, 30.00.0014.7168 (English), 8/6/2021 01:42:36, 17666168 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvopencl64.dll, 30.00.0014.7168 (English), 8/6/2021 01:42:42, 20330128 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcompiler32.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:42, 41371792 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcompiler64.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:56, 46108792 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvlddmkm.sys, 30.00.0014.7168 (English), 8/6/2021 01:41:50, 37433984 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libcuda.so.1.1, 8/5/2021 14:12:52, 23834920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libcuda_loader.so, 8/5/2021 14:12:52, 141464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvcuvid.so.1, 8/5/2021 14:12:52, 6175952 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-encode.so.1, 8/5/2021 14:12:52, 424448 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-ml.so.1, 8/5/2021 14:12:52, 1824024 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-ml_loader.so, 8/5/2021 14:12:52, 197528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-opticalflow.so.1, 8/5/2021 14:12:52, 354816 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvidia-ptxjitcompiler.so.1, 8/5/2021 14:12:52, 11144408 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\libnvwgf2umx.so, 8/5/2021 14:12:52, 49664192 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nv-vk64.json, 8/5/2021 14:12:52, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvDecMFTMjpeg.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:42, 604280 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvDecMFTMjpegx.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:42, 747128 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvEncMFTH264.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:56, 1137296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvEncMFTH264x.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:58, 1449104 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvEncMFThevc.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:02, 1143440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvEncMFThevcx.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:04, 1458320 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcbl64.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:36, 688272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcuda32.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:10, 21752440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvcuda64.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:16, 24863352 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvd3dumx.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:48, 26205296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvd3dumx_cfg.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:58, 26453120 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdlistx.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:14, 216136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvidia-smi, 8/5/2021 14:12:52, 678392 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumdx.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:18, 1056280 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvml.dll, 8.17.0014.7168 (English), 8/6/2021 01:42:02, 1121920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvoglv64.dll, 30.00.0014.7168 (English), 8/6/2021 01:42:22, 44886160 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvoptix.dll, 7.04.0000.0000 (English), 8/6/2021 01:42:54, 233656464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvptxJitCompiler32.dll, 30.00.0014.7168 (English), 8/6/2021 01:43:36, 7745664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvptxJitCompiler64.dll, 30.00.0014.7168 (English), 8/6/2021 01:43:42, 8798848 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvrtum64.dll, 30.00.0014.7168 (English), 8/6/2021 01:43:46, 76673152 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvvm64_40_0.dll, 6.14.0011.9000 (English), 8/6/2021 01:44:40, 17700480 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwgf2umx.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:36, 77946024 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwgf2umx_cfg.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:56, 78356896 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:14, 2112144 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:44, 1520760 bytes
Driver: C:\Windows\system32\NvIFROpenGL.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:48, 676480 bytes
Driver: C:\Windows\system32\OpenCL.dll, 3.00.0001.0000 (English), 8/6/2021 01:45:08, 1474672 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:08, 919184 bytes
Driver: C:\Windows\system32\nvapi64.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:32, 7280848 bytes
Driver: C:\Windows\system32\nvcuda.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:30, 2925688 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0014.7168 (English), 8/6/2021 01:40:36, 8854136 bytes
Driver: C:\Windows\system32\nvinfo.pb, 8/5/2021 14:12:52, 83062 bytes
Driver: C:\Windows\system32\nvml.dll, 8.17.0014.7168 (English), 8/6/2021 01:42:04, 645248 bytes
Driver: C:\Windows\system32\nvofapi64.dll, 8/6/2021 01:42:10, 716928 bytes
Driver: C:\Windows\system32\vulkan-1-999-0-0-0.dll, 1.02.0170.0000 (English), 8/6/2021 01:45:10, 1097832 bytes
Driver: C:\Windows\system32\vulkan-1.dll, 1.02.0170.0000 (English), 8/6/2021 01:45:10, 1097832 bytes
Driver: C:\Windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.02.0170.0000 (English), 8/6/2021 01:45:16, 1858680 bytes
Driver: C:\Windows\system32\vulkaninfo.exe, 1.02.0170.0000 (English), 8/6/2021 01:45:16, 1858680 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nv-vk32.json, 8/5/2021 14:12:52, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvIccAdvancedColorIdentity.icm, 8/5/2021 14:12:52, 3288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvd3dum.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:38, 22410824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvd3dum_cfg.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:06, 22797256 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdispco64.exe, 1.00.0016.0000 (English), 8/6/2021 01:40:48, 1550456 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvdlist.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:12, 181824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvldumd.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:18, 880664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvoglv32.dll, 30.00.0014.7168 (English), 8/6/2021 01:42:12, 33858688 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwgf2um.dll, 30.00.0014.7168 (English), 8/6/2021 01:39:24, 33602920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\nvwgf2um_cfg.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:14, 34216968 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:10, 1595536 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0014.7168 (English), 8/6/2021 01:41:42, 1171088 bytes
Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:46, 564352 bytes
Driver: C:\Windows\SysWow64\OpenCL.dll, 3.00.0001.0000 (English), 8/6/2021 01:45:04, 1212536 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 30.00.0014.7168 (English), 8/6/2021 01:41:06, 750200 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 30.00.0014.7168 (English), 8/6/2021 01:38:30, 6215808 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 30.00.0014.7168 (English), 8/6/2021 01:40:24, 4987512 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0014.7168 (English), 8/6/2021 01:40:32, 7920760 bytes
Driver: C:\Windows\SysWow64\nvofapi.dll, 8/6/2021 01:42:10, 577152 bytes
Driver: C:\Windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.02.0170.0000 (English), 8/6/2021 01:45:14, 951928 bytes
Driver: C:\Windows\SysWow64\vulkan-1.dll, 1.02.0170.0000 (English), 8/6/2021 01:45:14, 951928 bytes
Driver: C:\Windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.02.0170.0000 (English), 8/6/2021 01:45:16, 1438840 bytes
Driver: C:\Windows\SysWow64\vulkaninfo.exe, 1.02.0170.0000 (English), 8/6/2021 01:45:16, 1438840 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_253e24b785ea60ca\NvTelemetry64.dll, 14.03.0060.0000 (English), 8/6/2021 01:44:24, 4465048 bytes
Device ID: PCI\VEN_8086&DEV_43A4&SUBSYS_86941043&REV_11\3&11583659&0&FD
Driver: n/a
Name: PCI standard RAM Controller
Device ID: PCI\VEN_8086&DEV_43EF&SUBSYS_86941043&REV_11\3&11583659&0&A2
Driver: n/a
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_43D2&SUBSYS_86941043&REV_11\3&11583659&0&B8
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 186184 bytes
Device ID: PCI\VEN_8086&DEV_43B8&SUBSYS_86941043&REV_11\3&11583659&0&E0
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_4385&SUBSYS_86941043&REV_11\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 20296 bytes
Device ID: PCI\VEN_8086&DEV_43B0&SUBSYS_86941043&REV_11\3&11583659&0&E8
Name: Intel(R) Serial IO I2C Host Controller - 43E9
Device ID: PCI\VEN_8086&DEV_43E9&SUBSYS_86941043&REV_11\3&11583659&0&A9
Name: Intel(R) Ethernet Controller (3) I225-V #2
Device ID: PCI\VEN_8086&DEV_15F3&SUBSYS_87D21043&REV_03\4&255B870&0&00E6
Driver: C:\Windows\system32\DRIVERS\e2f68.sys, 1.00.0002.0006 (English), 9/29/2020 20:20:36, 520552 bytes
Driver: C:\Windows\system32\e2f68.din, 9/29/2020 20:09:10, 2996 bytes
Device ID: PCI\VEN_8086&DEV_43BF&SUBSYS_86941043&REV_11\3&11583659&0&E7
Name: Intel(R) USB 3.20 eXtensible Host Controller - 1.20 (Microsoft)
Device ID: PCI\VEN_8086&DEV_43ED&SUBSYS_86941043&REV_11\3&11583659&0&A0
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 608568 bytes
Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.19041.1081 (English), 8/17/2021 18:14:12, 146736 bytes
Device ID: PCI\VEN_8086&DEV_15F3&SUBSYS_87D21043&REV_03\4&356AA108&0&00E5
Name: Standard NVM Express Controller
Device ID: PCI\VEN_1BB1&DEV_5016&SUBSYS_50161BB1&REV_01\4&12FB7CC4&0&0030
Driver: C:\Windows\system32\DRIVERS\stornvme.sys, 10.00.19041.0844 (English), 4/9/2021 06:47:35, 155960 bytes
Device ID: PCI\VEN_8086&DEV_4C01&SUBSYS_86941043&REV_01\3&11583659&0&08
Device ID: PCI\VEN_8086&DEV_43BD&SUBSYS_86941043&REV_11\3&11583659&0&E5
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_8086&DEV_4C43&SUBSYS_86941043&REV_01\3&11583659&0&00
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.19041.0508
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.19041.0508
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.19041.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.19041.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.19041.0450
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.19041.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.19041.1110
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.19041.1165
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.19041.1165
DV Muxer,0x00400000,0,0,qdv.dll,10.00.19041.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.19041.0746
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.19041.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.19041.0746
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.19041.0746
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.19041.1151
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.19041.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.19041.0746
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.19041.0746
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.19041.0329
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.19041.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.19041.0746
DV Splitter,0x00600000,1,2,qdv.dll,10.00.19041.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.19041.0746
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.19041.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.19041.0746
Video Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.19041.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.19041.0746
Video Renderer,0x00400000,1,0,quartz.dll,10.00.19041.0746
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.19041.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.19041.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.19041.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.19041.0746
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.19041.0746
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.19041.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.19041.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.19041.0746
Null Renderer,0x00200000,1,0,qedit.dll,10.00.19041.0746
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.19041.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.19041.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.19041.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.19041.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.19041.0746
Wave Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
File stream renderer,0x00400000,1,1,quartz.dll,10.00.19041.0746
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.19041.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.19041.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.19041.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.19041.0746
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.19041.0746
File Source (URL),0x00400000,0,1,quartz.dll,10.00.19041.0746
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.19041.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.19041.0546
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.19041.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.19041.0746
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.19041.0867
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.19041.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.19041.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.19041.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.19041.0746
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.19041.0508
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.19041.0508
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.19041.0746
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.19041.0746
Audio Capture Sources:
Microphone (Realtek USB Audio),0x00200000,0,0,qcap.dll,10.00.19041.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.19041.1052
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.1052
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.1052
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.19041.0746
WDM Streaming Capture Devices:
Realtek USB Audio,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
SONICSTUDIOVAD Wave Speaker,0x00200000,2,2,ksproxy.ax,10.00.19041.0746
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.19041.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.19041.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.19041.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek USB Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: Realtek Digital Output (Realtek USB Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: LG ULTRAGEAR (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: Speakers (Realtek USB Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.19041.1165
mfreadwrite.dll, 10.00.19041.0746
mfcaptureengine.dll, 10.00.19041.0906
mfsensorgroup.dll, 10.00.19041.1151
windows.media.dll, 10.00.19041.1023
frameserver.dll, 10.00.19041.1151
frameserverclient.dll, 10.00.19041.1151
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 30.00.0014.7168
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.19041.1151
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.19041.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.19041.0450
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.19041.1151
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.19041.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.19041.1110
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.19041.0329
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.19041.1165
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.19041.1165
WebpImageExtension
HEIFImageExtension
VP9VideoExtensionDecoder
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 30.00.0014.7168
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 30.00.0014.7168
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.19041.0964
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.19041.0867
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.19041.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.19041.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.19041.0001
HEIFImageExtension
VP9VideoExtensionEncoder
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.19041.0867
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.19041.0746
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.19041.1110
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.19041.0789
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.19041.1165
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.19041.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.19041.0508
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.19041.1165
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.19041.1165
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.19041.1165
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.19041.0508
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.19041.0746
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.19041.1023
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.19041.1165
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.19041.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.19041.1165
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.19041.1165
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.19041.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.19041.0746
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.19041.1165
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
DTSXDecoder
DTSHDDecoder
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.19041.1165
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.19041.0746
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.19041.0508
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.19041.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.19041.0001
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.19041.0508
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.19041.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.19041.0746
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.19041.0001
DTS Headphone:X
DTS:X Ultra
DTS:X for home theater
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.19041.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.19041.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.19041.1081
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.19041.1151
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket , type 0
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: HorizonZeroDawn.exe
P2: 1.0.10.5
P3: 6014986d
P4: 2ed6
P5: 134217728
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 1361664313210578765, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P2: 1.0.10.5
P3: 10.0.19043.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 1349405470884464173, type 5
Cab Id: 0
Problem signature:
P1: Craftopia.exe
P2: 2020.3.8.31001
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER3 +++:
Fault bucket 2136258113090108188, type 5
Cab Id: 0
Problem signature:
P1: Wow.exe
P2: 9.1.0.39653
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER4 +++:
Fault bucket 1968021804718729116, type 5
Cab Id: 0
Problem signature:
P1: WowClassic.exe
P2: 2.5.1.39603
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER5 +++:
Fault bucket 1784904111423362780, type 5
Event Name: WindowsWcpOtherFailure3
Cab Id: 0
Problem signature:
P1: 10.0.19041.1161:1
P2: wcp\componentstore\storelayout.cpp
P3: ComponentStore::CRawStoreLayout::HydrateFileUsingForwardAndReverseDeltas
P4: 1682
P5: 800f0984
P6: 0x734f02fe
P7:
P8:
P9:
P10:
+++ WER6 +++:
Cab Id: 0
Problem signature:
P4: 1682
P5: 800f0984
P6: 0x734f02fe
P7:
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P4: 1682
P5: 800f0984
P6: 0x734f02fe
P7:
P8:
P9:
P10:
+++ WER8 +++:
Fault bucket 1154352724820394255, type 5
Event Name: BEX
Cab Id: 0
Problem signature:
P1: NahimicSvc32.exe
P2: 2.6.3.0
P3: 5efaf438
P4: DeviceRoutingDaemonModule.dll
P5: 2.2.9.64544
P6: 5f34e0f9
P7: 0004c047
P8: c0000409
P9: 00000007
P10:
+++ WER9 +++:
Fault bucket 1816425235566691406, type 5
Event Name: MoAppCrash
Cab Id: 0
Problem signature:
P1: Microsoft.Windows.Search_1.14.0.19041_neutral_neutral_cw5n1h2txyewy
P2: praid:CortanaUI
P3: 10.0.19041.844
P4: 69441820
P5: KERNELBASE.dll
P6: 10.0.19041.906
P7: 2f2f77bf
P8: c0000602
P9: 000000000010b2dc
P10:
