High DPC Issues + "Display Driver has stopped work"
pote2639
Hello, firstly my spec (my computer is about 4 years now, fyi.):
P7P55-LX
i3-540 3.07GHz (Never OC)
GTS 450 (Never OC)
4GB Kingstone DDR3
Western 500GB Blue
and 450W of PSU.
Well, lately I got 2 issues on my hands.
When I open any youtubes (chrome, firefox and IE) I got the distorted sound, also I did updated flash player tho. but the problems still occurs. I suspects that ndis.sys, USBPORT.sys and tcpip.sys are the causes of those things.
also another problem is, When I'm playing League of Legend or Team Fortress 2, I got the "Display driver has stopped work" and/or when I'm trying to play youtube with 4-5 videos together, its crashed. even though I tried to rollback my driver.
Here's the DPC report:
CONCLUSION
LatencyMon has been analyzing your system for 0:15:48 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: POTE-PC
Hardware: ASUSTeK Computer INC., P7P55 LX
CPU: GenuineIntel Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
Logical processors: 4
Processor groups: 1
RAM: 4087 MB total
CPU SPEED
Reported CPU speed: 3077.0 MHz
Measured CPU speed: 3369.0 MHz (approx.)
Highest measured interrupt to process latency (µs): 21310.210420
Average measured interrupt to process latency (µs): 3.078407
Highest measured interrupt to DPC latency (µs): 1729.959308
Average measured interrupt to DPC latency (µs): 0.961336
REPORTED ISRs
Highest ISR routine execution time (µs): 1600.977576
Highest reported total ISR routine time (%): 0.091089
Total time spent in ISRs (%) 0.144994
ISR count (execution time <250 µs): 1295238
ISR count (execution time 500-999 µs): 2
ISR count (execution time 1000-1999 µs): 2
REPORTED DPCs
Highest DPC routine execution time (µs): 1517.566136
Driver with highest DPC routine execution time: ndis.sys - NDIS 6.20 driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.197803
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0.475727
DPC count (execution time <250 µs): 5832803
DPC count (execution time 500-999 µs): 346
DPC count (execution time 1000-1999 µs): 3
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: firefox.exe
Total number of hard pagefaults 1331
Hard pagefault count of hardest hit process: 428
Highest hard pagefault resolution time (µs): 215676.082223
Total time spent in hard pagefaults (%): 0.219264
Number of processes hit: 23
PER CPU DATA
CPU 0 Interrupt cycle time (s): 16.942381
CPU 0 ISR highest execution time (µs): 1600.977576
CPU 0 ISR total execution time (s): 1.966242
CPU 0 ISR count: 1033340
CPU 0 DPC highest execution time (µs): 1517.566136
CPU 0 DPC total execution time (s): 8.537732
CPU 0 DPC count: 5064875
CPU 1 Interrupt cycle time (s): 7.497043
CPU 1 ISR highest execution time (µs): 174.069548
CPU 1 ISR total execution time (s): 1.193422
CPU 1 ISR count: 87187
CPU 1 DPC highest execution time (µs): 347.229119
CPU 1 DPC total execution time (s): 2.899233
CPU 1 DPC count: 215606
CPU 2 Interrupt cycle time (s): 8.305669
CPU 2 ISR highest execution time (µs): 1010.248944
CPU 2 ISR total execution time (s): 1.167468
CPU 2 ISR count: 87315
CPU 2 DPC highest execution time (µs): 1401.955151
CPU 2 DPC total execution time (s): 3.691932
CPU 2 DPC count: 314403
CPU 3 Interrupt cycle time (s): 7.219532
CPU 3 ISR highest execution time (µs): 174.407215
CPU 3 ISR total execution time (s): 1.171779
CPU 3 ISR count: 87400
CPU 3 DPC highest execution time (µs): 452.924927
CPU 3 DPC total execution time (s): 2.913076
CPU 3 DPC count: 238268
Also here's the reliability report for GPU problem:
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Files that help describe the problem
WD-20150305-1602.dmp
sysdata.xml
WERInternalMetadata.xml
View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Extra information about the problem
BCCode: 117
BCP1: FFFFFA80056D5010
BCP2: FFFFF8800742ABFC
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
And here's the DPC drivers most used report
Kindly Thanks you for your help. :hug:
