[SOLVED] help with sfcfix errors
ocs1013
system readiness tool installed
then sfc /scannow
then newest sfcfix
windows 7 pro 64bit with sp1
cannot get these errors fixed,please help
Start time: 2015-09-10 15:54:53.597
WARNING: Failed to get store name from identity name with return code 2 for component mdmpp.inf and file mdmpp.inf. File is reported as corrupt by SFC.
CORRUPT: mdmpp.inf of component mdmpp.inf.
WARNING: Failed to get store name from identity name with return code 2 for component mdmracal.inf and file mdmracal.inf. File is reported as corrupt by SFC.
CORRUPT: mdmracal.inf of component mdmracal.inf.
WARNING: Failed to get store name from identity name with return code 2 for component mdmpn1.inf and file mdmpn1.inf. File is reported as corrupt by SFC.
CORRUPT: mdmpn1.inf of component mdmpn1.inf.
WARNING: Failed to get store name from identity name with return code 2 for component mdmpin.inf and file MDMPIN.INF. File is reported as corrupt by SFC.
CORRUPT: MDMPIN.INF of component mdmpin.inf.
WARNING: Failed to get store name from identity name with return code 2 for component mdmpace.inf and file mdmpace.inf. File is reported as corrupt by SFC.
CORRUPT: mdmpace.inf of component mdmpace.inf.
WARNING: Failed to get store name from identity name with return code 2 for component mdmpsion.inf and file mdmpsion.inf. File is reported as corrupt by SFC.
CORRUPT: mdmpsion.inf of component mdmpsion.inf.
WARNING: Failed to get store name from identity name with return code 2 for component mdmpenr.inf and file mdmpenr.inf. File is reported as corrupt by SFC.
CORRUPT: mdmpenr.inf of component mdmpenr.inf.
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-dims-autoenroll_31bf3856ad364e35_6.1.7600.16385_none_5004a8665487390e\pautoenr.dll
CORRUPT: C:\Windows\winsxs\wow64_microsoft-windows-icm-base_31bf3856ad364e35_6.1.7601.17514_none_8b429a15d4638581\icm32.dll
CORRUPT: C:\Windows\winsxs\amd64_machine.inf_31bf3856ad364e35_6.1.7601.17514_none_1838f2aad55063bb\NV_AGP.SYS
CBS & SFC total detected corruption count: 11
Currently storing 17 datablocks.
Finish time: 2015-09-10 15:57:30.931
Hi ocs1013 :)
My name is Aura and I'll be assisting you with your issue. Follow the instructions below please.
System File Checker (SFC)
    Run as Administrator
Note: Please note that the CBS.log is volatile, which means that if you don't upload it after the SFC scan is completed, it won't contains the information from the scan anymore. So archive it and upload it as soon as you can.
Alright follow the instructions below please.
SFCFix - Fix Time
SFCFix.zip
ok ran it just like you said
told me to reboot
afterwards i ran sfc /scannow again
still errors
ran sfcfix
included is sfcfix fix report after sfxfix script
and new cbs log attached in link
new cbs log: https://drive.google.com/file/d/0B21jkBKF0iDqWW4zdndTWGk3alE/view?usp=sharing
and new sfxfix log after sfcscript fix
Start time: 2015-09-15 10:47:22.423
WARNING: Failed to get store name from identity name with return code 2 for component prnhp002.inf and file Amd64\hpf69000.icc. File is reported as corrupt by SFC.
CORRUPT: Amd64\hpf69000.icc of component prnhp002.inf.
WARNING: Failed to get store name from identity name with return code 2 for component prnca00b.inf and file Amd64\CNB9BHBA.ICM. File is reported as corrupt by SFC.
CORRUPT: Amd64\CNB9BHBA.ICM of component prnca00b.inf.
WARNING: Failed to get store name from identity name with return code 2 for component prnep00l.inf and file Amd64\EP0LVP1Q.GPD. File is reported as corrupt by SFC.
CORRUPT: Amd64\EP0LVP1Q.GPD of component prnep00l.inf.
FIXED: Corruption at C:\Windows\winsxs\amd64_microsoft-windows-gadgets-currency_31bf3856ad364e35_6.1.7600.16385_none_c3b9072b536514f6\base-undocked-3.png has been successfully repaired from C:\Windows\winsxs\x86_microsoft-windows-gadgets-currency_31bf3856ad364e35_6.1.7600.16385_none_679a6ba79b07a3c0\base-undocked-3.png.
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-icm-base_31bf3856ad364e35_6.1.7601.17514_none_80edefc3a002c386\WcsPlugInService.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-efsadu_31bf3856ad364e35_6.1.7600.16385_none_f406cbebeaa0432b\efsadu.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-m..nents-mdac-sqlunirl_31bf3856ad364e35_6.1.7600.16385_none_3bed0e7fdd8193ca\sqlunirl.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-wintrust-dll_31bf3856ad364e35_6.1.7601.18839_none_f1a4f434f85ec5b9\wintrust.dll
CBS & SFC total detected corruption count: 16
CBS & SFC total fixed corruption count: 2
Currently storing 37 datablocks.
Finish time: 2015-09-15 10:52:10.245
More corrupt files were detected by SFC, so we'll have to fix these ones as well. It seems that your Google Drive URL doesn't work, can you grab it and post it here again please?
Start time: 2015-09-15 10:20:24.177
Using .zip script file at C:\Users\owner\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-icm-base_31bf3856ad364e35_6.1.7601.17514_none_8b429a15d4638581\icm32.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-registry-editor_31bf3856ad364e35_6.1.7600.16385_none_5023a70bf589ad3e\regedt32.exe
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-dims-autoenroll_31bf3856ad364e35_6.1.7600.16385_none_5004a8665487390e\pautoenr.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-deviceux.resources_31bf3856ad364e35_6.1.7600.16385_en-us_cb71053ac6d732b5\DeviceUxRes.dll.mui
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-cttune_31bf3856ad364e35_6.1.7600.16385_none_0f797e18d8361ef2\cttune.exe
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-com-base-qfe-ole32_31bf3856ad364e35_6.1.7601.18915_none_0a449de508f01259\ole32.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_mdmracal.inf_31bf3856ad364e35_6.1.7600.16385_none_94654f616d035e4d\mdmracal.inf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_mdmpsion.inf_31bf3856ad364e35_6.1.7600.16385_none_5f62ca049c3c9107\mdmpsion.inf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_mdmpp.inf_31bf3856ad364e35_6.1.7600.16385_none_a9d2002feb81fa56\mdmpp.inf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_mdmpn1.inf_31bf3856ad364e35_6.1.7600.16385_none_bc4acdcb7ef2250b\mdmpn1.inf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_mdmpin.inf_31bf3856ad364e35_6.1.7600.16385_none_cd27d545ef083ea5\MDMPIN.INF
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_mdmpenr.inf_31bf3856ad364e35_6.1.7600.16385_none_14e411db1f1fd8ef\mdmpenr.inf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_mdmpace.inf_31bf3856ad364e35_6.1.7600.16385_none_1fe2fc8d4a1d4f7d\mdmpace.inf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\b1.t4
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_atiilhag.inf.resources_31bf3856ad364e35_6.1.7600.16385_en-us_a84b3670179ab5eb\atikmdag.sys.mui
WARNING: File C:\Windows\winsxs\wow64_microsoft-windows-icm-base_31bf3856ad364e35_6.1.7601.17514_none_8b429a15d4638581\icm32.dll was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-icm-base_31bf3856ad364e35_6.1.7601.17514_none_8b429a15d4638581\icm32.dll to C:\Windows\winsxs\wow64_microsoft-windows-icm-base_31bf3856ad364e35_6.1.7601.17514_none_8b429a15d4638581\icm32.dll.
WARNING: File C:\Windows\winsxs\amd64_microsoft-windows-registry-editor_31bf3856ad364e35_6.1.7600.16385_none_5023a70bf589ad3e\regedt32.exe was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-registry-editor_31bf3856ad364e35_6.1.7600.16385_none_5023a70bf589ad3e\regedt32.exe to C:\Windows\winsxs\amd64_microsoft-windows-registry-editor_31bf3856ad364e35_6.1.7600.16385_none_5023a70bf589ad3e\regedt32.exe.
WARNING: File C:\Windows\winsxs\amd64_microsoft-windows-dims-autoenroll_31bf3856ad364e35_6.1.7600.16385_none_5004a8665487390e\pautoenr.dll was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-dims-autoenroll_31bf3856ad364e35_6.1.7600.16385_none_5004a8665487390e\pautoenr.dll to C:\Windows\winsxs\amd64_microsoft-windows-dims-autoenroll_31bf3856ad364e35_6.1.7600.16385_none_5004a8665487390e\pautoenr.dll.
WARNING: File C:\Windows\winsxs\amd64_microsoft-windows-deviceux.resources_31bf3856ad364e35_6.1.7600.16385_en-us_cb71053ac6d732b5\DeviceUxRes.dll.mui was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-deviceux.resources_31bf3856ad364e35_6.1.7600.16385_en-us_cb71053ac6d732b5\DeviceUxRes.dll.mui to C:\Windows\winsxs\amd64_microsoft-windows-deviceux.resources_31bf3856ad364e35_6.1.7600.16385_en-us_cb71053ac6d732b5\DeviceUxRes.dll.mui.
WARNING: File C:\Windows\winsxs\amd64_microsoft-windows-cttune_31bf3856ad364e35_6.1.7600.16385_none_0f797e18d8361ef2\cttune.exe was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-cttune_31bf3856ad364e35_6.1.7600.16385_none_0f797e18d8361ef2\cttune.exe to C:\Windows\winsxs\amd64_microsoft-windows-cttune_31bf3856ad364e35_6.1.7600.16385_none_0f797e18d8361ef2\cttune.exe.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG to C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG.
WARNING: File C:\Windows\winsxs\amd64_microsoft-windows-com-base-qfe-ole32_31bf3856ad364e35_6.1.7601.18915_none_0a449de508f01259\ole32.dll was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-com-base-qfe-ole32_31bf3856ad364e35_6.1.7601.18915_none_0a449de508f01259\ole32.dll to C:\Windows\winsxs\amd64_microsoft-windows-com-base-qfe-ole32_31bf3856ad364e35_6.1.7601.18915_none_0a449de508f01259\ole32.dll.
WARNING: File C:\Windows\winsxs\amd64_mdmracal.inf_31bf3856ad364e35_6.1.7600.16385_none_94654f616d035e4d\mdmracal.inf was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_mdmracal.inf_31bf3856ad364e35_6.1.7600.16385_none_94654f616d035e4d\mdmracal.inf to C:\Windows\winsxs\amd64_mdmracal.inf_31bf3856ad364e35_6.1.7600.16385_none_94654f616d035e4d\mdmracal.inf.
WARNING: File C:\Windows\winsxs\amd64_mdmpsion.inf_31bf3856ad364e35_6.1.7600.16385_none_5f62ca049c3c9107\mdmpsion.inf was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_mdmpsion.inf_31bf3856ad364e35_6.1.7600.16385_none_5f62ca049c3c9107\mdmpsion.inf to C:\Windows\winsxs\amd64_mdmpsion.inf_31bf3856ad364e35_6.1.7600.16385_none_5f62ca049c3c9107\mdmpsion.inf.
WARNING: File C:\Windows\winsxs\amd64_mdmpp.inf_31bf3856ad364e35_6.1.7600.16385_none_a9d2002feb81fa56\mdmpp.inf was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_mdmpp.inf_31bf3856ad364e35_6.1.7600.16385_none_a9d2002feb81fa56\mdmpp.inf to C:\Windows\winsxs\amd64_mdmpp.inf_31bf3856ad364e35_6.1.7600.16385_none_a9d2002feb81fa56\mdmpp.inf.
WARNING: File C:\Windows\winsxs\amd64_mdmpn1.inf_31bf3856ad364e35_6.1.7600.16385_none_bc4acdcb7ef2250b\mdmpn1.inf was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_mdmpn1.inf_31bf3856ad364e35_6.1.7600.16385_none_bc4acdcb7ef2250b\mdmpn1.inf to C:\Windows\winsxs\amd64_mdmpn1.inf_31bf3856ad364e35_6.1.7600.16385_none_bc4acdcb7ef2250b\mdmpn1.inf.
WARNING: File C:\Windows\winsxs\amd64_mdmpin.inf_31bf3856ad364e35_6.1.7600.16385_none_cd27d545ef083ea5\MDMPIN.INF was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_mdmpin.inf_31bf3856ad364e35_6.1.7600.16385_none_cd27d545ef083ea5\MDMPIN.INF to C:\Windows\winsxs\amd64_mdmpin.inf_31bf3856ad364e35_6.1.7600.16385_none_cd27d545ef083ea5\MDMPIN.INF.
WARNING: File C:\Windows\winsxs\amd64_mdmpenr.inf_31bf3856ad364e35_6.1.7600.16385_none_14e411db1f1fd8ef\mdmpenr.inf was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_mdmpenr.inf_31bf3856ad364e35_6.1.7600.16385_none_14e411db1f1fd8ef\mdmpenr.inf to C:\Windows\winsxs\amd64_mdmpenr.inf_31bf3856ad364e35_6.1.7600.16385_none_14e411db1f1fd8ef\mdmpenr.inf.
WARNING: File C:\Windows\winsxs\amd64_mdmpace.inf_31bf3856ad364e35_6.1.7600.16385_none_1fe2fc8d4a1d4f7d\mdmpace.inf was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_mdmpace.inf_31bf3856ad364e35_6.1.7600.16385_none_1fe2fc8d4a1d4f7d\mdmpace.inf to C:\Windows\winsxs\amd64_mdmpace.inf_31bf3856ad364e35_6.1.7600.16385_none_1fe2fc8d4a1d4f7d\mdmpace.inf.
WARNING: File C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\b1.t4 was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\b1.t4 to C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\b1.t4.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_atiilhag.inf.resources_31bf3856ad364e35_6.1.7600.16385_en-us_a84b3670179ab5eb\atikmdag.sys.mui to C:\Windows\winsxs\amd64_atiilhag.inf.resources_31bf3856ad364e35_6.1.7600.16385_en-us_a84b3670179ab5eb\atikmdag.sys.mui.
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-icm-base_31bf3856ad364e35_6.1.7601.17514_none_8b429a15d4638581\icm32.dll
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-icm-base_31bf3856ad364e35_6.1.7601.17514_none_8b429a15d4638581\icm32.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-registry-editor_31bf3856ad364e35_6.1.7600.16385_none_5023a70bf589ad3e\regedt32.exe
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-registry-editor_31bf3856ad364e35_6.1.7600.16385_none_5023a70bf589ad3e\regedt32.exe
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-dims-autoenroll_31bf3856ad364e35_6.1.7600.16385_none_5004a8665487390e\pautoenr.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-dims-autoenroll_31bf3856ad364e35_6.1.7600.16385_none_5004a8665487390e\pautoenr.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-deviceux.resources_31bf3856ad364e35_6.1.7600.16385_en-us_cb71053ac6d732b5\DeviceUxRes.dll.mui
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-deviceux.resources_31bf3856ad364e35_6.1.7600.16385_en-us_cb71053ac6d732b5\DeviceUxRes.dll.mui
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-cttune_31bf3856ad364e35_6.1.7600.16385_none_0f797e18d8361ef2\cttune.exe
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-cttune_31bf3856ad364e35_6.1.7600.16385_none_0f797e18d8361ef2\cttune.exe
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-com-base-qfe-ole32_31bf3856ad364e35_6.1.7601.18915_none_0a449de508f01259\ole32.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-com-base-qfe-ole32_31bf3856ad364e35_6.1.7601.18915_none_0a449de508f01259\ole32.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_mdmracal.inf_31bf3856ad364e35_6.1.7600.16385_none_94654f616d035e4d\mdmracal.inf
Successfully restored permissions on C:\Windows\winsxs\amd64_mdmracal.inf_31bf3856ad364e35_6.1.7600.16385_none_94654f616d035e4d\mdmracal.inf
Successfully restored ownership for C:\Windows\winsxs\amd64_mdmpsion.inf_31bf3856ad364e35_6.1.7600.16385_none_5f62ca049c3c9107\mdmpsion.inf
Successfully restored permissions on C:\Windows\winsxs\amd64_mdmpsion.inf_31bf3856ad364e35_6.1.7600.16385_none_5f62ca049c3c9107\mdmpsion.inf
Successfully restored ownership for C:\Windows\winsxs\amd64_mdmpp.inf_31bf3856ad364e35_6.1.7600.16385_none_a9d2002feb81fa56\mdmpp.inf
Successfully restored permissions on C:\Windows\winsxs\amd64_mdmpp.inf_31bf3856ad364e35_6.1.7600.16385_none_a9d2002feb81fa56\mdmpp.inf
Successfully restored ownership for C:\Windows\winsxs\amd64_mdmpn1.inf_31bf3856ad364e35_6.1.7600.16385_none_bc4acdcb7ef2250b\mdmpn1.inf
Successfully restored permissions on C:\Windows\winsxs\amd64_mdmpn1.inf_31bf3856ad364e35_6.1.7600.16385_none_bc4acdcb7ef2250b\mdmpn1.inf
Successfully restored ownership for C:\Windows\winsxs\amd64_mdmpin.inf_31bf3856ad364e35_6.1.7600.16385_none_cd27d545ef083ea5\MDMPIN.INF
Successfully restored permissions on C:\Windows\winsxs\amd64_mdmpin.inf_31bf3856ad364e35_6.1.7600.16385_none_cd27d545ef083ea5\MDMPIN.INF
Successfully restored ownership for C:\Windows\winsxs\amd64_mdmpenr.inf_31bf3856ad364e35_6.1.7600.16385_none_14e411db1f1fd8ef\mdmpenr.inf
Successfully restored permissions on C:\Windows\winsxs\amd64_mdmpenr.inf_31bf3856ad364e35_6.1.7600.16385_none_14e411db1f1fd8ef\mdmpenr.inf
Successfully restored ownership for C:\Windows\winsxs\amd64_mdmpace.inf_31bf3856ad364e35_6.1.7600.16385_none_1fe2fc8d4a1d4f7d\mdmpace.inf
Successfully restored permissions on C:\Windows\winsxs\amd64_mdmpace.inf_31bf3856ad364e35_6.1.7600.16385_none_1fe2fc8d4a1d4f7d\mdmpace.inf
Successfully restored ownership for C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\b1.t4
Successfully restored permissions on C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\b1.t4
Successfully restored ownership for C:\Windows\winsxs\amd64_atiilhag.inf.resources_31bf3856ad364e35_6.1.7600.16385_en-us_a84b3670179ab5eb\atikmdag.sys.mui
Successfully restored permissions on C:\Windows\winsxs\amd64_atiilhag.inf.resources_31bf3856ad364e35_6.1.7600.16385_en-us_a84b3670179ab5eb\atikmdag.sys.mui
Currently storing 35 datablocks.
Finish time: 2015-09-15 10:20:25.705
Script hash: M4M3/tD48JGuCNYJ5bg3X+iW7+EmDF86Ol9z1lJkpdo=
Alright, now let's get a fresh CBS.log to make sure I have up to date information to work with and prepare a fix.
Alright follow the instructions below please (and only these, do not run SFC after).
SFCFix - Fix Time
View attachment SFCFix.zip
Start time: 2015-09-16 14:12:54.639
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-s..erexperience-common_31bf3856ad364e35_6.1.7600.16385_none_8eae698ab7e8d4d5\sapi.cpl
Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638.manifest
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-usp_31bf3856ad364e35_6.1.7601.18454_none_0af5261f6f3c76ad\usp10.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-security-vault_31bf3856ad364e35_6.1.7600.16385_none_4d5e025e54ba15f8\VaultSysUi.exe
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-m..ttheme-us-component_31bf3856ad364e35_6.1.7601.17514_none_b52573ad8e4c2d89\US-wp4.jpg
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\iphlpsvc.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\IphlpsvcMigPlugin.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-help-speech.resources_31bf3856ad364e35_6.1.7600.16385_en-us_c031aba6988a59f8\speech.h1s
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-s..erexperience-common_31bf3856ad364e35_6.1.7600.16385_none_8eae698ab7e8d4d5\sapi.cpl to C:\Windows\winsxs\x86_microsoft-windows-s..erexperience-common_31bf3856ad364e35_6.1.7600.16385_none_8eae698ab7e8d4d5\sapi.cpl.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638.manifest to C:\Windows\winsxs\Manifests\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638.manifest.
The file \\?\C:\Windows\winsxs\amd64_microsoft-windows-usp_31bf3856ad364e35_6.1.7601.18454_none_0af5261f6f3c76ad\usp10.dll is in use and must be replaced over a reboot.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-security-vault_31bf3856ad364e35_6.1.7600.16385_none_4d5e025e54ba15f8\VaultSysUi.exe to C:\Windows\winsxs\amd64_microsoft-windows-security-vault_31bf3856ad364e35_6.1.7600.16385_none_4d5e025e54ba15f8\VaultSysUi.exe.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-m..ttheme-us-component_31bf3856ad364e35_6.1.7601.17514_none_b52573ad8e4c2d89\US-wp4.jpg to C:\Windows\winsxs\amd64_microsoft-windows-m..ttheme-us-component_31bf3856ad364e35_6.1.7601.17514_none_b52573ad8e4c2d89\US-wp4.jpg.
The file \\?\C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\iphlpsvc.dll is in use and must be replaced over a reboot.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\IphlpsvcMigPlugin.dll to C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\IphlpsvcMigPlugin.dll.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-help-speech.resources_31bf3856ad364e35_6.1.7600.16385_en-us_c031aba6988a59f8\speech.h1s to C:\Windows\winsxs\amd64_microsoft-windows-help-speech.resources_31bf3856ad364e35_6.1.7600.16385_en-us_c031aba6988a59f8\speech.h1s.
Successfully pended file for replace over reboot: \\?\C:\Windows\winsxs\amd64_microsoft-windows-usp_31bf3856ad364e35_6.1.7601.18454_none_0af5261f6f3c76ad\usp10.dll
Successfully pended file for replace over reboot: \\?\C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\iphlpsvc.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-s..erexperience-common_31bf3856ad364e35_6.1.7600.16385_none_8eae698ab7e8d4d5\sapi.cpl
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-s..erexperience-common_31bf3856ad364e35_6.1.7600.16385_none_8eae698ab7e8d4d5\sapi.cpl
Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638.manifest
Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638.manifest
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-security-vault_31bf3856ad364e35_6.1.7600.16385_none_4d5e025e54ba15f8\VaultSysUi.exe
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-security-vault_31bf3856ad364e35_6.1.7600.16385_none_4d5e025e54ba15f8\VaultSysUi.exe
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-m..ttheme-us-component_31bf3856ad364e35_6.1.7601.17514_none_b52573ad8e4c2d89\US-wp4.jpg
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-m..ttheme-us-component_31bf3856ad364e35_6.1.7601.17514_none_b52573ad8e4c2d89\US-wp4.jpg
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\IphlpsvcMigPlugin.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\IphlpsvcMigPlugin.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-help-speech.resources_31bf3856ad364e35_6.1.7600.16385_en-us_c031aba6988a59f8\speech.h1s
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-help-speech.resources_31bf3856ad364e35_6.1.7600.16385_en-us_c031aba6988a59f8\speech.h1s
Reboot:: directive completed successfully.
PostRebootCorruptionDetection::
No hash verification failures detected.
PostRebootCorruptionDetection:: directive completed successfully.
PostRebootRestorePermissions::
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-usp_31bf3856ad364e35_6.1.7601.18454_none_0af5261f6f3c76ad\usp10.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-usp_31bf3856ad364e35_6.1.7601.18454_none_0af5261f6f3c76ad\usp10.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\iphlpsvc.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-i..oexistencemigration_31bf3856ad364e35_6.1.7601.17964_none_6fd3103d93227638\iphlpsvc.dll
PostRebootRestorePermissions:: directive completed successfully.
Currently storing 45 datablocks.
Finish time: 2015-09-16 14:30:07.514
and the new cbs log file after fix
https://drive.google.com/file/d/0B21jkBKF0iDqWkppcklEZmpDREU/view?usp=sharing
or
Each time we replace corrupt files, SFC finds more of them. We'll get to the bottom of it :)
SFCFix - Fix Time
SFCFix.zip
new filesSFCFix version 2.4.5.0 by niemiro.
Start time: 2015-09-17 10:02:27.551
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-mobsyncexe_31bf3856ad364e35_6.1.7601.17514_none_f1584379b2973708\mobsync.exe
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-mfdvdec_31bf3856ad364e35_6.1.7600.16385_none_6efb973595ddbd6f\mfdvdec.dll
Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_microsoft-windows-ndis_31bf3856ad364e35_6.1.7601.17939_none_05dc9a6832ba428a.manifest
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-diskmanagement_31bf3856ad364e35_6.1.7600.16385_none_5d8ca75e896e4607\dmdskres.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_zh-cn_a8a29e186daf4d2f\comdlg32.dll.mui
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-charmap_31bf3856ad364e35_6.1.7601.18648_none_50633f4fbb0f8120\korean.uce
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-axinstallservice_31bf3856ad364e35_6.1.7601.17514_none_352b5454878cd498\axinstsv.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_ipmidrv.inf_31bf3856ad364e35_6.1.7601.17514_none_59cef7610231e41b\ipmidrv.sys
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\avmcoxp.dll
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-mobsyncexe_31bf3856ad364e35_6.1.7601.17514_none_f1584379b2973708\mobsync.exe to C:\Windows\winsxs\x86_microsoft-windows-mobsyncexe_31bf3856ad364e35_6.1.7601.17514_none_f1584379b2973708\mobsync.exe.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-mfdvdec_31bf3856ad364e35_6.1.7600.16385_none_6efb973595ddbd6f\mfdvdec.dll to C:\Windows\winsxs\wow64_microsoft-windows-mfdvdec_31bf3856ad364e35_6.1.7600.16385_none_6efb973595ddbd6f\mfdvdec.dll.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_microsoft-windows-ndis_31bf3856ad364e35_6.1.7601.17939_none_05dc9a6832ba428a.manifest to C:\Windows\winsxs\Manifests\amd64_microsoft-windows-ndis_31bf3856ad364e35_6.1.7601.17939_none_05dc9a6832ba428a.manifest.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-diskmanagement_31bf3856ad364e35_6.1.7600.16385_none_5d8ca75e896e4607\dmdskres.dll to C:\Windows\winsxs\amd64_microsoft-windows-diskmanagement_31bf3856ad364e35_6.1.7600.16385_none_5d8ca75e896e4607\dmdskres.dll.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_zh-cn_a8a29e186daf4d2f\comdlg32.dll.mui to C:\Windows\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_zh-cn_a8a29e186daf4d2f\comdlg32.dll.mui.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-charmap_31bf3856ad364e35_6.1.7601.18648_none_50633f4fbb0f8120\korean.uce to C:\Windows\winsxs\amd64_microsoft-windows-charmap_31bf3856ad364e35_6.1.7601.18648_none_50633f4fbb0f8120\korean.uce.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-axinstallservice_31bf3856ad364e35_6.1.7601.17514_none_352b5454878cd498\axinstsv.dll to C:\Windows\winsxs\amd64_microsoft-windows-axinstallservice_31bf3856ad364e35_6.1.7601.17514_none_352b5454878cd498\axinstsv.dll.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_ipmidrv.inf_31bf3856ad364e35_6.1.7601.17514_none_59cef7610231e41b\ipmidrv.sys to C:\Windows\winsxs\amd64_ipmidrv.inf_31bf3856ad364e35_6.1.7601.17514_none_59cef7610231e41b\ipmidrv.sys.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\avmcoxp.dll to C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\avmcoxp.dll.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-mobsyncexe_31bf3856ad364e35_6.1.7601.17514_none_f1584379b2973708\mobsync.exe
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-mobsyncexe_31bf3856ad364e35_6.1.7601.17514_none_f1584379b2973708\mobsync.exe
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-mfdvdec_31bf3856ad364e35_6.1.7600.16385_none_6efb973595ddbd6f\mfdvdec.dll
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-mfdvdec_31bf3856ad364e35_6.1.7600.16385_none_6efb973595ddbd6f\mfdvdec.dll
Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_microsoft-windows-ndis_31bf3856ad364e35_6.1.7601.17939_none_05dc9a6832ba428a.manifest
Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_microsoft-windows-ndis_31bf3856ad364e35_6.1.7601.17939_none_05dc9a6832ba428a.manifest
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-diskmanagement_31bf3856ad364e35_6.1.7600.16385_none_5d8ca75e896e4607\dmdskres.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-diskmanagement_31bf3856ad364e35_6.1.7600.16385_none_5d8ca75e896e4607\dmdskres.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_zh-cn_a8a29e186daf4d2f\comdlg32.dll.mui
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_zh-cn_a8a29e186daf4d2f\comdlg32.dll.mui
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-charmap_31bf3856ad364e35_6.1.7601.18648_none_50633f4fbb0f8120\korean.uce
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-charmap_31bf3856ad364e35_6.1.7601.18648_none_50633f4fbb0f8120\korean.uce
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-axinstallservice_31bf3856ad364e35_6.1.7601.17514_none_352b5454878cd498\axinstsv.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-axinstallservice_31bf3856ad364e35_6.1.7601.17514_none_352b5454878cd498\axinstsv.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_ipmidrv.inf_31bf3856ad364e35_6.1.7601.17514_none_59cef7610231e41b\ipmidrv.sys
Successfully restored permissions on C:\Windows\winsxs\amd64_ipmidrv.inf_31bf3856ad364e35_6.1.7601.17514_none_59cef7610231e41b\ipmidrv.sys
Successfully restored ownership for C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\avmcoxp.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_avmx64c.inf_31bf3856ad364e35_6.1.7600.16385_none_1b289ccdd9a4634d\avmcoxp.dll
Currently storing 54 datablocks.
Finish time: 2015-09-17 10:02:28.924
Script hash: KaHtfyIr4qr8GfRqws1P6EDpUm6aKUKdsQtTMU8Xdoc=
new cbs file after sfcfix script
https://drive.google.com/file/d/0B21jkBKF0iDqTC1BN1VZUGN6aUE/view?usp=sharing
or
Alright let's do this again.
SFCFix - Fix Time
Start time: 2015-09-18 10:34:01.739
Using .zip script file at C:\Users\owner\Desktop\SFCFix.zip [1]
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-gadgets-currency_31bf3856ad364e35_6.1.7600.16385_none_679a6ba79b07a3c0\base-undocked-3.png
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-e..ortingcompatibility_31bf3856ad364e35_6.1.7600.16385_none_fe75fb7856d846d5\DWWIN.EXE
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_netg664.inf_31bf3856ad364e35_6.1.7600.16385_none_3e838f62f7e92ab2\SiSG664.sys
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\firstuxres.wim
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-p..-gameratingssystems_31bf3856ad364e35_6.1.7601.18020_none_87fc392d0509276e\csrr.rs
WARNING: File C:\Windows\winsxs\x86_microsoft-windows-gadgets-currency_31bf3856ad364e35_6.1.7600.16385_none_679a6ba79b07a3c0\base-undocked-3.png was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-gadgets-currency_31bf3856ad364e35_6.1.7600.16385_none_679a6ba79b07a3c0\base-undocked-3.png to C:\Windows\winsxs\x86_microsoft-windows-gadgets-currency_31bf3856ad364e35_6.1.7600.16385_none_679a6ba79b07a3c0\base-undocked-3.png.
WARNING: File C:\Windows\winsxs\x86_microsoft-windows-e..ortingcompatibility_31bf3856ad364e35_6.1.7600.16385_none_fe75fb7856d846d5\DWWIN.EXE was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-e..ortingcompatibility_31bf3856ad364e35_6.1.7600.16385_none_fe75fb7856d846d5\DWWIN.EXE to C:\Windows\winsxs\x86_microsoft-windows-e..ortingcompatibility_31bf3856ad364e35_6.1.7600.16385_none_fe75fb7856d846d5\DWWIN.EXE.
WARNING: File C:\Windows\winsxs\amd64_netg664.inf_31bf3856ad364e35_6.1.7600.16385_none_3e838f62f7e92ab2\SiSG664.sys was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_netg664.inf_31bf3856ad364e35_6.1.7600.16385_none_3e838f62f7e92ab2\SiSG664.sys to C:\Windows\winsxs\amd64_netg664.inf_31bf3856ad364e35_6.1.7600.16385_none_3e838f62f7e92ab2\SiSG664.sys.
WARNING: File C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\firstuxres.wim was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\firstuxres.wim to C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\firstuxres.wim.
WARNING: File C:\Windows\winsxs\amd64_microsoft-windows-p..-gameratingssystems_31bf3856ad364e35_6.1.7601.18020_none_87fc392d0509276e\csrr.rs was not backed up as that would replace the current backup.
Successfully copied file C:\Users\owner\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-p..-gameratingssystems_31bf3856ad364e35_6.1.7601.18020_none_87fc392d0509276e\csrr.rs to C:\Windows\winsxs\amd64_microsoft-windows-p..-gameratingssystems_31bf3856ad364e35_6.1.7601.18020_none_87fc392d0509276e\csrr.rs.
WARNING: File C:\Windows\winsxs\amd64_microsoft-windows-diskmanagement_31bf3856ad364e35_6.1.7600.16385_none_5d8ca75e896e4607\dmdskres.dll was not backed up as that would replace the current backup.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-gadgets-currency_31bf3856ad364e35_6.1.7600.16385_none_679a6ba79b07a3c0\base-undocked-3.png
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-gadgets-currency_31bf3856ad364e35_6.1.7600.16385_none_679a6ba79b07a3c0\base-undocked-3.png
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-e..ortingcompatibility_31bf3856ad364e35_6.1.7600.16385_none_fe75fb7856d846d5\DWWIN.EXE
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-e..ortingcompatibility_31bf3856ad364e35_6.1.7600.16385_none_fe75fb7856d846d5\DWWIN.EXE
Successfully restored ownership for C:\Windows\winsxs\amd64_netg664.inf_31bf3856ad364e35_6.1.7600.16385_none_3e838f62f7e92ab2\SiSG664.sys
Successfully restored permissions on C:\Windows\winsxs\amd64_netg664.inf_31bf3856ad364e35_6.1.7600.16385_none_3e838f62f7e92ab2\SiSG664.sys
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\firstuxres.wim
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\firstuxres.wim
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-p..-gameratingssystems_31bf3856ad364e35_6.1.7601.18020_none_87fc392d0509276e\csrr.rs
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-p..-gameratingssystems_31bf3856ad364e35_6.1.7601.18020_none_87fc392d0509276e\csrr.rs
Currently storing 61 datablocks.
Finish time: 2015-09-18 10:34:02.987
Script hash: yne6/OSNrwi7bEtusq+IH7Xxs3PxpQS4U0NK9VYl+/I=
new cbs file after script
https://drive.google.com/file/d/0B21jkBKF0iDqUmJqU2RoNlNTSEE/view?usp=sharing
or
We are getting there! I expect it to be the last replacement.
SFCFix - Fix Time
Start time: 2015-09-18 12:57:08.582
Finish time: 2015-09-18 12:57:09.409
Script hash: zsxoGdx54VwkpAJCYDTSeys++7IyS6Ed3SWzl0hQOwg=
new cbs file
https://drive.google.com/file/d/0B21jkBKF0iDqN1NXQ1R6cW1ZNlk/view?usp=sharing
or
