[SOLVED] [HELP] SFC /scannow found corrupt files but was unable to fix
theboyz99
7
I ran sfc /scannow and found some files that were not able to be repaired here's the log idk where to find the correct dll's
for your info i'm running Windows 7 x64 enterprise
i appreciate all help that i will get, thank you
Hi and welcome to Sysnative. Thanks for the info. Please do the following which will provide me the necessary info to provide a fix.
Step#1 - Gather Info
1. Download SFCFix.exe and save this to your Desktop.
2. Save any open documents and close all open windows.
3. Double click on SFCFix.exe to open it.
4. Follow all on screen instructions and upon completion, a file should be created on your Desktop named SFCFix.txt.
5. Please post the contents of this log in your next post. Thank you.
Hello, thank you for welcoming me and helping me.
i have followed your instructions and uploaded the file you requested.
Start time: 2016-04-28 22:13:29.141
FIXED: Corruption at C:\Windows\winsxs\x86_microsoft-windows-g..policy-admin-gpedit_31bf3856ad364e35_6.1.7600.16385_none_ce0882b8c63afdf6\gpedit.dll has been successfully repaired from C:\Windows\SysWOW64\GPBAK\gpedit.dll.
FIXED: Corruption at C:\Windows\winsxs\x86_microsoft-windows-fde_31bf3856ad364e35_6.1.7601.17514_none_aa136561b9ed4ae4\fde.dll has been successfully repaired from C:\Windows\SysWOW64\GPBAK\fde.dll.
FIXED: Corruption at C:\Windows\winsxs\x86_microsoft-windows-grouppolicy-gptext_31bf3856ad364e35_6.1.7600.16385_none_372622adf05a6587\gptext.dll has been successfully repaired from C:\Windows\SysWOW64\GPBAK\gptext.dll.
FIXED: Corruption at C:\Windows\winsxs\x86_microsoft-windows-g..policy-admin-appmgr_31bf3856ad364e35_6.1.7601.17514_none_fcc0c5ed143b8eb0\appmgr.dll has been successfully repaired from C:\Windows\SysWOW64\GPBAK\appmgr.dll.
FIXED: Corruption at C:\Windows\winsxs\x86_microsoft-windows-fdeploy_31bf3856ad364e35_6.1.7601.17514_none_e1bcfc28af006dea\fdeploy.dll has been successfully repaired from C:\Windows\SysWOW64\GPBAK\fdeploy.dll.
SUMMARY: All detected corruptions were successfully repaired.
Finish time: 2016-04-28 22:26:21.374
Thank you. Now please do the following again.
SFC Scan
  1. Click on the Start
Excellent. Looks much better. Please do the following.
i have run the system update readiness tool but it's stuck on ''searching for updates on this computer'' it has been like this for 3 hours now and still going, and i don't believe that it's supposed to take this long or?
