Help on DISM and SFC corruption error
uria046
Good day experts!
I would like to seek help on this forum regarding this issue. I'm trying to diagnose the problem on my Windows 8.1 installation because I believe some system files were damaged and/or corrupted and I seem to deduced the symptoms based on the errors I encounter and still encountering while using my PC. For instance, one recurring errors I see on my system is that Notepad is showing wrong fonts and missing typefaces, Adobe Acrobat randomly gives errors because of "Bad Windows Image" and some Microsoft Office applications does not simply run, specifically MS Excel which gives an error "Not enough memory to run Microsoft Excel. Please reinstall." For these reasons, I tried to run the command sfc /scannow to check for file integrity and returned this:
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\system32>sfc /scannow
Verification 100% complete.
From this, I know now that there are system files that were corrupted and needed repair. I then used DISM to try to restore the system files using my Windows 8.1 installation disc and used /limitaccess flag to prevent it from using Windows Update since it is on a domain environment. However, it returns an error like this:
C:\Windows\system32>dism /online /cleanup-image /restorehealth /source:v:\sources\install.wim:1 /limitaccess
Version: 6.3.9600.19408
Image Version: 6.3.9600.19397
Error: 0x800f081f
Use the "Source" option to specify the location of the files that are required to restore the feature. For more inf
ormation on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
What other options should I take to fix this problem? I have uploaded my CBS and DISM log files here for your reference. Any help will be greatly appreciated. Thank you.
Hi!
Please start with the following:
GSmartControl
Hi!
GSmartControl
Hello!
I followed your instructions and used GSmartControl to check my HDD attributes and condition. Using the tests specified, the application returned these results:
These are the values given on the attributes tab:
In hindsight, these results seem to show that the HDD is working properly.
Fortunately, the IT of our office has granted administrative access on the machine I'm using to be able to troubleshoot things like this. I'm doing this out of concern because they've already advised me that they cannot prioritize my issues right now because of limited manpower at their end.
I would like to know what should be done next after this.
Thank you.
Hi!
Thank you for the information.
Please do the following and run DISM /RestoreHealth afterwards and provide CBS.log.
Hello.
Thank you for the instructions. Here is the resulting SFCFix.txt file after running the program:
Start time: 2020-07-04 09:08:27.416
Using .zip script file at C:\Users\marcelopm\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\latha.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\lathab.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUI.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUIb.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUI.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUIb.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartika.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartikab.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalinga.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalingab.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautami.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautamib.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugi.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugib.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-euphemia_31bf3856ad364e35_6.3.9600.16384_none_a8e28d632cef8c21\euphemia.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrima.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrimabd.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..uetype-leelawadeeui_31bf3856ad364e35_6.3.9600.16384_none_defb49de5fe90c10\LeelaUIb.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..uetype-javanesetext_31bf3856ad364e35_6.3.9600.16384_none_ee249ff51e68b14b\javatext.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..type-leelawadeebold_31bf3856ad364e35_6.3.9600.16384_none_e050674a5d6d9a9d\leelawdb.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-leelawadee_31bf3856ad364e35_6.3.9600.16384_none_f94f6cefb2344bb6\leelawad.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\cour.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbd.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbi.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpota.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpotab.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..pe-estrangeloedessa_31bf3856ad364e35_6.3.9600.16384_none_ed6d207e4dec00fa\estre.ttf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-f..e-microsofthimalaya_31bf3856ad364e35_6.3.9600.16384_none_f8f11ff50f9f2435\himalaya.ttf
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\latha.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\latha.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\lathab.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\lathab.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUI.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUI.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUIb.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUIb.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUI.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUI.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUIb.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUIb.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartika.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartika.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartikab.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartikab.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalinga.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalinga.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalingab.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalingab.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautami.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautami.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautamib.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautamib.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugi.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugi.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugib.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugib.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-euphemia_31bf3856ad364e35_6.3.9600.16384_none_a8e28d632cef8c21\euphemia.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-euphemia_31bf3856ad364e35_6.3.9600.16384_none_a8e28d632cef8c21\euphemia.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrima.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrima.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrimabd.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrimabd.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..uetype-leelawadeeui_31bf3856ad364e35_6.3.9600.16384_none_defb49de5fe90c10\LeelaUIb.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..uetype-leelawadeeui_31bf3856ad364e35_6.3.9600.16384_none_defb49de5fe90c10\LeelaUIb.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..uetype-javanesetext_31bf3856ad364e35_6.3.9600.16384_none_ee249ff51e68b14b\javatext.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..uetype-javanesetext_31bf3856ad364e35_6.3.9600.16384_none_ee249ff51e68b14b\javatext.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..type-leelawadeebold_31bf3856ad364e35_6.3.9600.16384_none_e050674a5d6d9a9d\leelawdb.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..type-leelawadeebold_31bf3856ad364e35_6.3.9600.16384_none_e050674a5d6d9a9d\leelawdb.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..truetype-leelawadee_31bf3856ad364e35_6.3.9600.16384_none_f94f6cefb2344bb6\leelawad.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-leelawadee_31bf3856ad364e35_6.3.9600.16384_none_f94f6cefb2344bb6\leelawad.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\cour.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\cour.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbd.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbd.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbi.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbi.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpota.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpota.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpotab.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpotab.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..pe-estrangeloedessa_31bf3856ad364e35_6.3.9600.16384_none_ed6d207e4dec00fa\estre.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..pe-estrangeloedessa_31bf3856ad364e35_6.3.9600.16384_none_ed6d207e4dec00fa\estre.ttf.
Successfully copied file C:\Users\marcelopm\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..e-microsofthimalaya_31bf3856ad364e35_6.3.9600.16384_none_f8f11ff50f9f2435\himalaya.ttf to C:\Windows\WinSxS\amd64_microsoft-windows-f..e-microsofthimalaya_31bf3856ad364e35_6.3.9600.16384_none_f8f11ff50f9f2435\himalaya.ttf.
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\latha.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\latha.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\lathab.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-latha_31bf3856ad364e35_6.3.9600.16384_none_61702004f01e1929\lathab.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUI.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUI.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUIb.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-laoui_31bf3856ad364e35_6.3.9600.16384_none_64f62fdaeddc0bdb\LaoUIb.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUI.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUI.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUIb.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-khmerui_31bf3856ad364e35_6.3.9600.16384_none_39c3f0bd3e7a1108\KhmerUIb.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartika.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartika.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartikab.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kartika_31bf3856ad364e35_6.3.9600.16384_none_faea7fabecca927a\kartikab.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalinga.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalinga.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalingab.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-kalinga_31bf3856ad364e35_6.3.9600.16384_none_fa17f09b5486b4f8\kalingab.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautami.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautami.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautamib.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gautami_31bf3856ad364e35_6.3.9600.16384_none_6c72cf2f7031b133\gautamib.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugi.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugi.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugib.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-gadugi_31bf3856ad364e35_6.3.9600.16384_none_d4fd21f6f936fad0\gadugib.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-euphemia_31bf3856ad364e35_6.3.9600.16384_none_a8e28d632cef8c21\euphemia.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-euphemia_31bf3856ad364e35_6.3.9600.16384_none_a8e28d632cef8c21\euphemia.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrima.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrima.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrimabd.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-font-truetype-ebrima_31bf3856ad364e35_6.3.9600.16384_none_bf3a2eb930000b85\ebrimabd.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..uetype-leelawadeeui_31bf3856ad364e35_6.3.9600.16384_none_defb49de5fe90c10\LeelaUIb.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..uetype-leelawadeeui_31bf3856ad364e35_6.3.9600.16384_none_defb49de5fe90c10\LeelaUIb.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..uetype-javanesetext_31bf3856ad364e35_6.3.9600.16384_none_ee249ff51e68b14b\javatext.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..uetype-javanesetext_31bf3856ad364e35_6.3.9600.16384_none_ee249ff51e68b14b\javatext.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..type-leelawadeebold_31bf3856ad364e35_6.3.9600.16384_none_e050674a5d6d9a9d\leelawdb.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..type-leelawadeebold_31bf3856ad364e35_6.3.9600.16384_none_e050674a5d6d9a9d\leelawdb.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-leelawadee_31bf3856ad364e35_6.3.9600.16384_none_f94f6cefb2344bb6\leelawad.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-leelawadee_31bf3856ad364e35_6.3.9600.16384_none_f94f6cefb2344bb6\leelawad.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\cour.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\cour.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbd.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbd.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbi.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..truetype-couriernew_31bf3856ad364e35_6.3.9600.16384_none_c701ad1b8131fd68\courbi.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpota.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpota.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpotab.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..ruetype-iskoolapota_31bf3856ad364e35_6.3.9600.16384_none_bf2ffb5834350355\iskpotab.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..pe-estrangeloedessa_31bf3856ad364e35_6.3.9600.16384_none_ed6d207e4dec00fa\estre.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..pe-estrangeloedessa_31bf3856ad364e35_6.3.9600.16384_none_ed6d207e4dec00fa\estre.ttf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-f..e-microsofthimalaya_31bf3856ad364e35_6.3.9600.16384_none_f8f11ff50f9f2435\himalaya.ttf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-f..e-microsofthimalaya_31bf3856ad364e35_6.3.9600.16384_none_f8f11ff50f9f2435\himalaya.ttf
Currently storing 31 datablocks.
Finish time: 2020-07-04 09:08:30.806
Script hash: zAUcFrOvlpQi79r+lsTau+w4x1aghYn/FZPnjt2JgrU=
Also, here are the updated CBS and DISM log files after running DISM /RestoreHealth command for your analysis.
Thank you once again!
