[SOLVED] Help me please !! 16 problems discovered via SFCFIX
Akuma18
Hello everyone,
I apologize for my English because i am french.
My problem i don't know where it comes from.
I did a scan using SFCFix software.
I am attaching the files to you.
Thanks in advance.
Sincerely
Akuma18
Bonjour à tous,
Je m'excuse pour mon anglais car je suis français.
Mon problème, je ne sais pas d'où ça vient.
J'ai fait un scan à l'aide du logiciel SFCFix.
Je vous joins les fichiers.
Merci d'avance.
Cordialement
Akuma18
Akuma18
Step 1. Download the
  • Note: Your antivirus program may report FRST incorrectly as an infection. If so, disable the real-time protection when downloading and running FRST.
  • Right-click to run the tool as administrator. When the tool opens click Yes to disclaimer.
  • Note: Ensure that the Addition.txt check box is checked at the bottom of the form within the Optional Scan area.
  • Press the Scan button.
  • Please wait for the tool to finish. It will produce two logfiles called FRST.txt and Addition.txt in the same directory the tool is run from (which should be the desktop)
  • Post the logfiles FRST.txt and Addition.txt as attachment in your next reply.
Step 2. Upload your COMPONENTS hive.
Step 1. Start the
  • Press the Fix button.
Step 2. Run the System File Checker and post the result. If it fails attach a new copy of the CBS log.
SFC /Scannow
Hello Maxstar,
thank you for your interest in my problem.
You will find the files you requested.
Best regards
Akuma18
Step 1. Start the
SFC /Scannow
If it is another system and different problem, please start a new thread.
