[SOLVED] Help me! I get Error 0x800f081f when run DISM.exe and BDOS System Crash
doktajohn
Hello,
I upgraded from Windows 8.1 to Windows 10. ( Laptop )
Just today my system crashed hard playing Witcher 3. It continued to crash after that too on regular programmes.
The blue screen was titled "Unexpected Store Exception" and later "critical system process died" ( something like that )
Error : 0x800f081f comes up when i run the DISM.exe
also my sfc /scannow CBS.Log contains some Errors.
both logs attached.
ALSO: do you know the W7F Diagnostic Tool? I could upload the crashdump data using that tool here too.
Please help me
Hi John :)
My name is Aura and I'll be assisting you with your issue. Follow the instructions below please.
SFCFix - Fix Time
SFCFix.zip
Here it is:
Start time: 2015-10-12 21:24:48.838
Microsoft Windows 8.1 - amd64
Using .zip script file at C:\Users\John Braun\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_systemresource-wind..-ui-accountscontrol_31bf3856ad364e35_10.0.10240.16384_none_da155365ee6f0fb5\Advanced.Theme-Dark_Scale-100.png
Successfully copied file C:\Users\John Braun\AppData\Local\niemiro\Archive\winsxs\amd64_systemresource-wind..-ui-accountscontrol_31bf3856ad364e35_10.0.10240.16384_none_da155365ee6f0fb5\Advanced.Theme-Dark_Scale-100.png to C:\WINDOWS\winsxs\amd64_systemresource-wind..-ui-accountscontrol_31bf3856ad364e35_10.0.10240.16384_none_da155365ee6f0fb5\Advanced.Theme-Dark_Scale-100.png.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_systemresource-wind..-ui-accountscontrol_31bf3856ad364e35_10.0.10240.16384_none_da155365ee6f0fb5\Advanced.Theme-Dark_Scale-100.png
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_systemresource-wind..-ui-accountscontrol_31bf3856ad364e35_10.0.10240.16384_none_da155365ee6f0fb5\Advanced.Theme-Dark_Scale-100.png
Finish time: 2015-10-12 21:24:48.994
Script hash: PRYAprS5V8XxpeRoQGL3gAScMpI2z0L52ZKlJNMGf1g=
Good, let's see if the replacement is accepted by SFC.
System File Checker (SFC)
    Run as Administrator
It seems like the replacement was accepted :) Now DISM should return you a success message.
DISM - Fixing Component Store Corruption
Follow the instructions below to run a DISM operation on your system.
  • Let the scan run until the end (100%). Depending on your system, it can take some time;
  • Copy the C:\Windows\Logs\DISM folder and C:\Windows\Logs\CBS\CBS.log file on your Desktop, then right-click on it, go to Send to... and select Compressed .zip archive;
  • Upload the file on Dropbox, Google Drive or OneDrive and post the download URL for it here;
Note: Please note that the CBS.log is volatile, which means that if you don't upload it after the DISM scan is completed, it won't contains the information from the scan anymore. So archive it and upload it as soon as you can.
Complete!
Do you think the Blue Screen Dumps will stop now too?
Thank you so much for your quick response!
J
No problem John you're welcome :)
Good luck!
