- Download SFCFix.exe (by niemiro) and save this to your Desktop.
- Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
- Save any open documents and close all open windows.
- On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip.
- Drag the file SFCFix.zip onto the file SFCFix.exe and release it.
- SFCFix will now process the script.
- Upon completion, a file should be created on your Desktop: SFCFix.txt.
- Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
SFC Scan
- Click on the Start button and in the search box, type Command Prompt
- When you see Command Prompt on the list, right-click on it and select Run as administrator
- When command prompt opens, copy and paste the following commands into it, press enter after each
- This will create a file, cbs.txt on your Desktop. Please attach this to your next post.
[CODE]SFCFix version 3.0.2.1 by niemiro.
Start time: 2020-02-04 13:50:29.409
Microsoft Windows 10 Build 18363 - amd64
Using .zip script file at C:\Users\fuchs\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\Defender.psd1
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpComputerStatus.cdxml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpPreference.cdxml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpScan.cdxml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpSignature.cdxml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreat.cdxml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatCatalog.cdxml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatDetection.cdxml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpWDOScan.cdxml
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\Defender.psd1 to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\Defender.psd1.
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpComputerStatus.cdxml to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpComputerStatus.cdxml.
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpPreference.cdxml to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpPreference.cdxml.
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpScan.cdxml to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpScan.cdxml.
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpSignature.cdxml to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpSignature.cdxml.
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreat.cdxml to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreat.cdxml.
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatCatalog.cdxml to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatCatalog.cdxml.
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatDetection.cdxml to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatDetection.cdxml.
Successfully copied file C:\Users\fuchs\AppData\Local\niemiro\Archive\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpWDOScan.cdxml to C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpWDOScan.cdxml.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\Defender.psd1
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\Defender.psd1
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpComputerStatus.cdxml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpComputerStatus.cdxml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpPreference.cdxml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpPreference.cdxml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpScan.cdxml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpScan.cdxml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpSignature.cdxml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpSignature.cdxml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreat.cdxml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreat.cdxml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatCatalog.cdxml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatCatalog.cdxml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatDetection.cdxml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpThreatDetection.cdxml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpWDOScan.cdxml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_windows-defender-management-powershell_31bf3856ad364e35_10.0.18362.449_none_399f5f2632e852c4\MSFT_MpWDOScan.cdxml
Currently storing 9 datablocks.
Finish time: 2020-02-04 13:50:36.081
Script hash: UZ8vN/CB7TdpY6gxVRwDhPVYVtViZrZLOVZanFW4sCg=
----------------------EOF-----------------------[/CODE]
