[SOLVED] Help installing kb4074598
furfur
Active member
Hello,
I have tried and tried to get this update to install but it fails everytime, no matter what I do. I even tried to update to Win10 but that just gets stuck at "[FONT=&quot]Making sure you're ready to install", even with all AV disabled.
SFC /scannow returns no errors or violations.
[/FONT]
Start time: 2018-04-06 12:53:52.669
Finish time: 2018-04-06 13:11:35.857
[FONT=&quot]Thanks!
[/FONT]
Hello and welcome to Sysnative!
Afterwards, please run SURT again and attach CheckSUR.log.
Start time: 2018-04-06 15:07:44.470
SURT total detected corruption count: 1
Finish time: 2018-04-06 15:08:03.578
Binary Version 6.1.7601.22471
Package Version 26.0
2018-04-06 15:17
(f) CBS MUM Corrupt 0x80070026 servicing\Packages\Package_576_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum Line 1: X¿
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 1088
Found 1 errors
CBS MUM Corrupt Total count: 1
Unavailable repair files:
servicing\packages\Package_576_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum
servicing\packages\Package_576_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat
Start time: 2018-04-06 16:33:36.387
Using .zip script file at C:\Users\station4\Downloads\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully copied file C:\Users\station4\AppData\Local\niemiro\Archive\Packages\package_576_for_kb4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\package_576_for_kb4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\station4\AppData\Local\niemiro\Archive\Packages\package_576_for_kb4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\package_576_for_kb4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully restored ownership for C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully restored permissions on C:\Windows\Temp\CheckSur\Servicing\Packages
Finish time: 2018-04-06 16:33:36.965
Script hash: IJiFXEEaeGei27/xLDVOppYORxuRR7oxULtdA58uF9c=
Sorry , I did it wrong the first time.
2018-04-06 16:37
(f) CBS MUM Corrupt 0x80070026 servicing\Packages\Package_576_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum Line 1: X²
(fix) CBS MUM Corrupt CBS File Replaced Package_576_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_576_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab.
Checking Packages
Summary:
Seconds executed: 1133
Found 1 errors
Fixed 1 errors
Fixed: CBS MUM Corrupt. Total count: 1
Fixed: CBS Paired File. Total count: 1
Holymoly! That's great man, thanks soo much! The update installed perfectly.
You're awesome, thanks again.
