Help creating fixlist.txt
JvO
I have a windows server 2016 standard that has problems installing the cumulative updates. In the CBS.log I get the following error: 0x80073701 – STATUS-SXS-ASSEMBLY-MISSING
Searching this forum I was finding similar problems with solutions creating a fixlist.txt from a searchreg.txt created with the Farbar Recovery Scan Tool.
So I have run the FRST searching for "KB4507459" wich I think is the culprit but have no clue on how to create the Fixlist.txt.
Just in case, I have included a portion of my cbs.log from the time I started the installation of the cumulative update up to the point when it fails.
2019-10-11 21:42:39, Error CSI 00006a5e@2019/10/11:19:42:39.406 (F) onecore\base\wcp\componentstore\csd_locking.cpp(200): Error STATUS_SXS_ASSEMBLY_MISSING originated in function CCSDirectTransaction::LockComponent expression: (null)
[gle=0x80004005]
2019-10-11 21:42:39, Info CBS Added C:\Windows\Logs\CBS\CBS.log to WER report.
2019-10-11 21:42:39, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191011050004.log to WER report.
2019-10-11 21:42:39, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191010052611.log to WER report.
2019-10-11 21:42:39, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191009145002.log to WER report.
2019-10-11 21:42:39, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191009021804.log to WER report.
2019-10-11 21:42:39, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191008042650.cab to WER report.
2019-10-11 21:42:39, Info CBS Not able to add pending.xml to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-10-11 21:42:39, Info CBS Not able to add pending.xml.bad to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-10-11 21:42:39, Info CBS Not able to add poqexec.log to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-10-11 21:42:45, Error CSI 00006a5f (F) STATUS_SXS_ASSEMBLY_MISSING #31825286# from CCSDirectTransaction::OperateEnding at index 0 of 1 operations, disposition 2[gle=0xd015000c]
2019-10-11 21:42:45, Error CSI 00006a60 (F) HRESULT_FROM_WIN32(ERROR_SXS_ASSEMBLY_MISSING) #31825030# from Windows::ServicingAPI::CCSITransaction::ICSITransaction_PinDeployment(Flags = 0, a = 3e029d19a0a3584347a724e8fef9a3af, version 10.0.14393.2580, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35}, cb = (null), s = (null), rid = 'Package_1243_for_KB4467691~31bf3856ad364e35~amd64~~10.0.1.3.4467691-3817_neutral', rah = '2', manpath = (null), catpath = (null), ed = 0, disp = 0)[gle=0x80073701]
2019-10-11 21:42:45, Info CBS Failed to pin deployment while resolving Update: Package_1243_for_KB4467691~31bf3856ad364e35~amd64~~10.0.1.3.4467691-3817_neutral from file: (null) [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2019-10-11 21:42:45, Info CBS Failed to bulk stage deployment manifest and pin deployment for package:Package_9848_for_KB4507459~31bf3856ad364e35~amd64~~10.0.1.6 [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2019-10-11 21:42:45, Info CBS CommitPackagesState: Started persisting state of packages
2019-10-11 21:42:45, Info CBS CommitPackagesState: Completed persisting state of packages
2019-10-11 21:42:45, Info CSI 00006a61@2019/10/11:19:42:45.482 CSI Transaction @0x17d4d73c8d0 destroyed
2019-10-11 21:42:45, Info CBS Perf: Resolve chain complete.
2019-10-11 21:42:45, Info CBS Failed to resolve execution chain. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2019-10-11 21:42:45, Error CBS Failed to process single phase execution. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2019-10-11 21:42:45, Info CBS WER: Generating failure report for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~14393.3115.1.6, status: 0x80073701, failure source: Resolve, start state: Resolved, target state: Installed, client id: WindowsUpdateAgent
2019-10-11 21:42:45, Info CBS Not able to query DisableWerReporting flag. Assuming not set... [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-10-11 21:42:45, Info CBS Added C:\Windows\Logs\CBS\CBS.log to WER report.
2019-10-11 21:42:45, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191011050004.log to WER report.
2019-10-11 21:42:45, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191010052611.log to WER report.
2019-10-11 21:42:45, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191009145002.log to WER report.
2019-10-11 21:42:45, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191009021804.log to WER report.
2019-10-11 21:42:45, Info CBS Added C:\Windows\Logs\CBS\CbsPersist_20191008042650.cab to WER report.
2019-10-11 21:42:45, Info CBS Not able to add %windir%\winsxs\poqexec.log to WER report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-10-11 21:42:45, Info CBS Not able to add %windir%\winsxs\pending.xml to WER report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-10-11 21:42:45, Info CBS Not able to add %windir%\winsxs\pending.xml.bad to WER report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-10-11 21:42:53, Info CBS Reboot mark cleared
2019-10-11 21:42:53, Info CBS Winlogon: Simplifying Winlogon CreateSession notifications
2019-10-11 21:42:53, Info CBS Winlogon: Deregistering for CreateSession notifications
2019-10-11 21:42:53, Info CBS FinalCommitPackagesState: Started persisting state of packages
2019-10-11 21:42:53, Info CBS Reporting package change for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~14393.3115.1.6, current: Resolved, pending: Default, start: Resolved, applicable: Installed, target: Installed, limit: Installed, hotpatch status: StillGoing, status: 0x0, failure source: Resolve, reboot required: False, client id: WindowsUpdateAgent, initiated offline: False, execution sequence: 720, first merged sequence: 720, reboot reason: REBOOT_NOT_REQUIRED, RM App session: -1, RM App name: N/A, FileName in use: N/A, release type: Update, release quality: final, OC operation: False, download source: 0, download time (secs): 4294967295, download status: 0x0 (S_OK), Express download: False, Download Size: 0
2019-10-11 21:42:54, Info CBS SQM: Package change report datapoints not populated because SQM is not initialized or not running online.
2019-10-11 21:42:54, Info CBS Reporting package change completion for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~14393.3115.1.6, current: Resolved, original: Resolved, target: Installed, status: 0x80073701, failure source: Resolve, failure details: "(null)", client id: WindowsUpdateAgent, initiated offline: False, execution sequence: 720, first merged sequence: 720, pending decision: InteractiveInstallFailed, primitive execution context: Interactive Flight: False
2019-10-11 21:42:54, Info CBS Resolve time performance datapoint is invalid. [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-10-11 21:42:54, Info CBS Stage time performance datapoint is invalid. [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-10-11 21:42:54, Info CBS Execute time performance datapoint is invalid. [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-10-11 21:42:54, Info CBS FinalCommitPackagesState: Completed persisting state of packages
2019-10-11 21:42:54, Info CBS Enabling LKG boot option
2019-10-11 21:42:58, Info CBS Exec: Processing complete. Session: 30769258_2591896644, Package: Package_for_RollupFix~31bf3856ad364e35~amd64~~14393.3115.1.6 [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
Step#1 - FRST Fix
6. Reboot and retry updates.
  • Thanks
Reactions: JvO
Thanx, that helped! I was able to install the missing update!
Do you have any information on how to create the fixlist.txt?
