Hard Drive (HDD) Diagnostics (Sea Tools for DOS) & SSD Test
EDIT: 1 October 2019
Execute Seatools for DOS from a USB Stick
I checked at the SeaTools site and found that they offer a tool/app, filename = USBbootSetup-SeaToolsBootable.zip that you can download; run the EXE inside the zip file (SeaToolsBootable_RC_2.1.2.usbBootMaker.exe) and create a bootable USB stick for SeaTools with DOS on it.
As with the CD/DVD, you will obviously be booting from the media device that you just created - the USB stick. To successfully boot from the USB stick, you MAY require a BIOS "Firing Order" change to ensure that the system looks to the USB ports first for bootable media - before looking/ defaulting to the hard drive or CD/DVD drive to boot your system.
If you require assistance to change your BIOS settings to ensure that the USB ports are first in line during boot-up, simply post your system manufacturer's name and the EXACT model number of the system. The model number can usually be obtained from the sticker found on the case of a desktop PC or from the label on the bottom of a laptop. It is very important to have the correct model number to ensure that you are provided with the correct instructions.
Here is a listing of the BIOS key sequence by system manufacturer, which will cause your system to boot, then bring you to the BIOS screen. On most systems, you press and/or tap an F-key repeatedly during boot-up to bring up the BIOS menu.
Get access to BIOS settings & Boot Menu: F-keys/Hotkeys by System Manufacturer (OEM)
INSTRUCTIONS FOR CREATING A BOOTABLE USB MEDIA DEVICE
The SeaTools USB creator app is the first selection on this page (under "Downloads") - SeaTools | Seagate Support US
... and is called SeaTools Bootable
Here is the direct link for the ZIP file download (not sure if it will work or not) - https://www.seagate.com/files/old-support-files/seatools/USBbootSetup-SeaToolsBootable.zip
Good luck to you.
Please post if you have any questions.
Regards. . .
jcgriff2
Original post
SeaTools for DOS - Hard Drive Diagnostics
1. Download the SeaTools (for DOS) ISO image file --> SeaTools for DOS - Hard Drive (HDD) Diagnostics (ISO) | Seagate
»Direct ISO File download from the aforementioned page - http://www.seagate.com/files/www-co...tools/_shared/downloads/SeaToolsDOS223ALL.ISO
2. Burn the SeaTools ISO to a CD-R disc with ImgBurn --> The Official ImgBurn Website
»Direct executable installation file download from the aforementioned page - http://download.imgburn.com/SetupImgBurn_2.5.8.0.exe
Installing Imgburn - Unwanted 3rd Party Apps
Be cautious when installing ImgBurn. No data damage or Windows OS damage can occur, but you could end up installing some garbage items on your system that are definitely unwanted.
Like most 3rd party apps these days, the actual ImgBurn program installation may include worthless 3rd party apps that will be installed on your system unless you un-check the box(es) during ImgBurn installation. You do not want or need these useless additional 3rd party apps for ImgBurn to work properly.
ImgBurn Custom Installation Instructions
When installing Imgburn, be sure to select "Custom Installation" on the two screens presented (if such an option/screen presents itself) and un-check the boxes for (to prevent) the installation of unwanted 3rd party apps such as AVG Toolbar & others.
ImgBurn - Select "Write image file to disc" -
imgburn-png.15736
3. Boot your system with the SeaTools CD. Run LONG test. You may need to change the BIOS "firing order" of the drives in BIOS to assure that the DVD drive is read first & prior to any internal hard drives. If you are unsure as to how to do this, simply post requesting assistance. We are more than happy to help you.
4. If SeaTools comes up OK, run HDD manufacturer's diagnostics --> Hard Drive Diagnostics Tools and Utilities (Storage) - TACKtech Corp.
NOTE: You may have to change BIOS settings from AHCI to IDE.
For SSDs - SSD life - tool for solid state drives health and endurance monitoring
SSDs - SeaTools for DOS can now be used for SSDs.
Regards. . .
jcgriff2
For users using Windows 8/8.1, please see: Sysnative Forums - post #63362
This is because SeaTools requires the HDD to be configured in a compatibility mode to work. This is not the default configuration for Windows 8.
In the UEFI, you will need to change the HDD mode from AHCI to IDE. Then boot and run SeaTools. After the test is finished, reboot into the UEFI again and change it back. Then boot into Windows as normal. Windows will not boot in IDE mode, so remember to change it back.
If you have issues with this, let me know. It is hard for me to be more specific, because I do not have a Windows 8, or a UEFI system to test it on!
Stephen
This can sometimes be an issue on Windows 7 systems too.
Other tools:
  1. Opensource CrystalDiskInfo 9.6.1 portable (CrystalDiskInfo9_6_1.zip), 1 March 2025
  2. Opensource GSmartControl 2.0.2, 24 February 2025
    GSmartControl is a graphical user interface for smartctl. It allows you to inspect the hard disk and solid-state drive SMART data to determine its health, as well as run various tests on it.
    See this Sysnative thread by Softwaremaniac - Win 10 Freezing and DISM and SFC won't complete
    Full instructions by softwaremaniac.
    • Download the portable version (gsmartcontrol-2.0.2-win64.zip) of GSmartControl 2.0.2 from SourceForge.net and save it on your Desktop.
    • Check the downloaded file with your antivirus.
    • Extract the zip file to your Desktop. Open the folder gsmartcontrol-2.0.2-win64 which should be located on your Desktop and double-click gsmartcontrol.exe to launch the program.
  3. This is the updated version (8 January 2025) to be used instead of SeaTools for dos (used for this tutorial).
    SeaTools bootable: use this kit to create a bootable USB that uses SeaTools to diagnose hard drives and monitor SSDs.
  4. SeaTools for windows 5.1, 8 January 2025
  5. Paid Hard Disk Sentinel 6.20.4, 22 October 2024 HDD/SSD health and temperature monitoring
    The Beta (test) Version is more updated.
  6. Freeware PassMark DiskCheckup 3.5 (build 1006), 17 April 2024
  7. Freeware HDDScan 4.1, 1 Sep 2019
  8. Freeware HD Tune 2.55, 12 Feb 2008 is an excellent diagnostic tool
  9. Seagate Internal Hard Drive Troubleshooter
  10. Western Digital Corporation (WDC) Lifeguard testing
  11. Kingston SSD Manager - Monitor Drive Health and Usage | Kingston
  12. TACKtech Corp: Hard Drive Diagnostics Tools and Utilities (Storage)
  13. Carrona.org: Hard Drive Diagnostic Procedure
  14. MSDN blog (2009): Support and Q&A for Solid-State Drives
Note: sorted by date.
