I have a NVIDIA GT610 Card I bought from Amazon for a Custom Box build. The screen flickers light-dark-light I read on Toms Hardwware (Tomshardware.com) this is a sign the card is going bad.
Any help here? Thanks, DonB
[GPU Information] <- SIV64X - System Information Viewer V4.47 DONB-PConB
| Bus-Numb-Fun| GPU Description (N) Memory Core Shader Load Volts Temp Fans # [Y]V340.52 (r340_00) - ATI FX990/X990 (V4) Additional Details
[ 1 - 00 - 0 ] GeForce GT 610 500MHz 810MHz 1.62GHz 30% 1.04 77°C 67% 2 Discrete GPU in Power State P0 2GB 64-bit DDR3 Cores 48
PCIe x16@2 (x16@2) GPU-0 (Fermi) P-State V2 7416 2 [Y]Clocks 3 Current Default Minimum Maximum BIOS 75.19.55.00.10
P0 [Y]S0 0 [Y]GPU Core 810 810 270 1620
4 [Y]Memory 500 500 324 1000
7 [_]Shader 1620 1620 1620 1620
0 [_]Voltage 1040 mV
P8 [_]S1 0 [_]GPU Core 270 270 270 270
4 [_]Memory 324 324 324 324
7 [_]Shader 540 540 540 540
0 [_]Voltage 900 mV
Loads V1 72 0 [_]GPU Core 30 % Frame 34 % Video 0 % Bus 0 %
Cooler V4 1368 0 [_]Fan ALL Current 67 Minimum 40 Maximum 100 Policy Continuous
[Y]Current is Default ... 40 ... 100 Policy Continuous
[_]Tachometer Current 0 ... 0 ... 0 Control ADI
Temps V2 68 GPU 77°C (GPU Int)
Status V1 140 0 Voltage 1,040,000 µV
Volts V1 16588 0 0.900 1.040
Pipes 1:1 Partitions 1 TPC 0 SM NA SP NA
NVIDIA NVAPI Library, Version 340.52 C:\Windows\system32\nvapi64.dll V9.18.13.4052
GPU Device Description Current Average Minimum Maximum Current Average Minimum Maximum Samples [Dummy DVI]
GeForce GT 610 Memory 500MHz 433MHz 324MHz - 77°C 68°C 57°C 78°C 184
GPU-0 [ 1 - 00 - 0 ] Core 810MHz 604MHz 270MHz - 1.040 0.987 0.900 - |D|Overclock
Shader Cores 48 1.62GHz 1.21GHz 540MHz - NA - - -
GPU Utilisation @ P0 27 % 20 % 0 % 69 % 65 % 56 % 40 % 68 % |_|Continuous
2GB Frame Buffer 162MB 169MB 161MB 185MB
[ OK ] [ Copy] [Windows] [Machine] [USB Bus] [Network] [Volumes] [ Wi-Fi] [PCI Bus] [Graphics] [GPU Info] [GPU I2C] [GPU SLI] [GPU MAP]
0 [_]Voltage 900 mV
