O obroad Member Joined Sep 29, 2022 Posts 44 Sep 29, 2022 #1 So when sfcfix runs it asks for a Windows disk. If I only have an ISO file not a physical disk can I use that?
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 15,216 Oct 1, 2022 #2 So when sfcfix runs it asks for a Windows disk. Click to expand... Please provide a screenshot of that message.
O obroad Member Joined Sep 29, 2022 Posts 44 Oct 2, 2022 #3 I didn't screenshot it at the time so I'm not sure how I'd re-create the conditions now. Maybe using a VM but then I'd need to deliberately break the install somehow? I might be able to use the drive clone I made when things first started to go bad.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 15,216 Oct 2, 2022 #4 Without a screenshot I can't tell you exactly the answer to your question in the first post but probably the answer is no.
