Hi all,
have had this issue since I got a 3070 last year.
Every game will stutter/pause for a split second when loading new textures/animations. Some textures will take a while to load when the rest of the scene is fine. Borderlands 3 is the most impacted game I have tried, whilst some run perfectly fine (Red dead).
I have tried:
- Reinstalling nearly every version of windows 10
- Nearly all the available Nvidia drivers for my card
- Changing settings in Nvidia control panel
- I've replaced every component in my PC since I got the card, motherboard included.
- I put my friends 1050ti in and the issue remained (?)
- Tightening DRAM timings and using stock settings
- Windows LTSC. My latency was 6us on desktop (Amazing!). Nvidia and chipset drivers only installed, no bloatware at all .But still stuttered in game.
- Undervolting/clocking card.
- Bcdedit's
- Unplugging all peripherals while game running
- Different power settings in Windows
- Enabling and disabling power/CPU settings in BIOS.
- So much more than I can't remember.. But nearly every solution that I've seen online.
Trace log and speccy:
trace
http://speccy.piriform.com/results/gBseYXlXxqcbs6L2Vgb3eJH
I have tried:
- Bcdedit's
trace
- Windows 10 x64 21H1
- Age of system? All within a year old
- Age of OS installation? This one is about a week. I have been obsessing over this for last month trying to fix it, installed multiple versions.
- Have you re-installed the OS? Yes.
- System Manufacturer? Built myself
- Laptop or Desktop? Desktop
- Gigabyte Aorus Elite Wifi x570
- Ryzen 5600x
- G.SKILL Trident Z Neo RGB F4-3600C18D-16GTZN - DOCP profile
- Gigabyte 3070 OC Gaming
- Corsair HX Series HX750 Power Supply 750W
- Is driver verifier enabled or disabled? I haven't used this
- What security software are you using? Standard windows
- Are you using proxy, vpn, ipfilters or similar software? No
- Are you using Disk Image tools? No
- Are you currently under/overclocking? Are there overclocking software installed on your system? Yes, but this issue persists with or without. No difference if it's OC or not.
