Hi there! Here's my problem:
Some days ago my computer had a bad shutdown because of a power outage and when booted up again i got into an infinite startup repair loop. Researching a bit about the topic i was told to run "sfc /scannow" to fix possible file corruptions, but that lead me to an "Windows Resource Protection found corrupt files but was unable to fix some of them" error. I then ran dism in offline mode using my windows 8.1 x64 SP1 iso file (because online mode doesn't work in windows re) but that didn't work either because the file to replace couldn't be retrieved. After a lot of more research and no positive results, i ended up digging in CBS logs to found the CSI payload corruption described in the title. Searched for that on google and got into this thread: https://www.sysnative.com/forums/wi...prncacla-inf-corruptions-windows-8-8-1-a.html. It seems SFCFix is designed to work in a normal desktop enviroment, but unafortunately that's not my case as I can't even enter secure boot.
Explained the problem I would want to ask how to proceed from now on, as i know wich is the corrupted file but i have no idea what to do to replace it for a good one.
Many thanks for your time!!
