Firestarter
- Feb 23, 2015
- 7
I've spent the last couple of months off and on trying to fix this problem. I have tried reformatting but I'm not sure if it was a complete wipe and I would prefer to see if there is any other solution. I get static/crackly audio and framerate lag when playing any type of game and occasionally when watching videos/streams. I would appreciate any help anyone can provide me with or point me in the right direction. Here is the stats from Latencymon.
Here is the Drivers page of Latencymon
Here is the overall conclusion from Latencymon_________________________________________________________________________________________________________CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:21:28 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: JOHNHENRY-PC
Hardware: Gigabyte Technology Co., Ltd., X79-UD3
CPU: GenuineIntel Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Logical processors: 12
Processor groups: 1
RAM: 16305 MB total
CPU SPEED
Reported CPU speed: 3200.0 MHz
Measured CPU speed: 815.0 MHz (approx.)
Highest measured interrupt to process latency (µs): 9197.413511
Average measured interrupt to process latency (µs): 5.542076
Highest measured interrupt to DPC latency (µs): 784.957739
Average measured interrupt to DPC latency (µs): 1.229897
REPORTED ISRs
Highest ISR routine execution time (µs): 314.061875
Driver with highest ISR routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.088798
Driver with highest ISR total time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.215666
ISR count (execution time <250 µs): 10590133
ISR count (execution time 500-999 µs): 39
REPORTED DPCs
Highest DPC routine execution time (µs): 640.510
Driver with highest DPC routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.660777
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0.857524
DPC count (execution time <250 µs): 16110066
DPC count (execution time 500-999 µs): 555
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 1455
Hard pagefault count of hardest hit process: 1032
Highest hard pagefault resolution time (µs): 423541.283438
Total time spent in hard pagefaults (%): 0.153560
Number of processes hit: 6
PER CPU DATA
CPU 0 Interrupt cycle time (s): 47.390911
CPU 0 ISR highest execution time (µs): 110.986250
CPU 0 ISR total execution time (s): 3.566542
CPU 0 ISR count: 2572228
CPU 0 DPC highest execution time (µs): 348.576875
CPU 0 DPC total execution time (s): 10.699287
CPU 0 DPC count: 7492443
CPU 1 Interrupt cycle time (s): 24.922292
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 245.506875
CPU 1 DPC total execution time (s): 0.064776
CPU 1 DPC count: 6374
CPU 2 Interrupt cycle time (s): 41.436525
CPU 2 ISR highest execution time (µs): 55.920
CPU 2 ISR total execution time (s): 0.009514
CPU 2 ISR count: 550
CPU 2 DPC highest execution time (µs): 334.609375
CPU 2 DPC total execution time (s): 7.546517
CPU 2 DPC count: 787864
CPU 3 Interrupt cycle time (s): 24.916360
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 282.076875
CPU 3 DPC total execution time (s): 0.030249
CPU 3 DPC count: 2383
CPU 4 Interrupt cycle time (s): 26.198574
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 306.553125
CPU 4 DPC total execution time (s): 1.241966
CPU 4 DPC count: 154857
CPU 5 Interrupt cycle time (s): 27.076067
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 86.824062
CPU 5 DPC total execution time (s): 0.016931
CPU 5 DPC count: 2138
CPU 6 Interrupt cycle time (s): 28.816368
CPU 6 ISR highest execution time (µs): 157.973750
CPU 6 ISR total execution time (s): 0.267125
CPU 6 ISR count: 46609
CPU 6 DPC highest execution time (µs): 399.406875
CPU 6 DPC total execution time (s): 5.477586
CPU 6 DPC count: 467660
CPU 7 Interrupt cycle time (s): 26.145672
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 61.306875
CPU 7 DPC total execution time (s): 0.011179
CPU 7 DPC count: 1905
CPU 8 Interrupt cycle time (s): 27.529169
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 300.51250
CPU 8 DPC total execution time (s): 2.663886
CPU 8 DPC count: 253068
CPU 9 Interrupt cycle time (s): 158.704314
CPU 9 ISR highest execution time (µs): 314.061875
CPU 9 ISR total execution time (s): 29.514529
CPU 9 ISR count: 7970785
CPU 9 DPC highest execution time (µs): 640.510
CPU 9 DPC total execution time (s): 102.329933
CPU 9 DPC count: 6705431
CPU 10 Interrupt cycle time (s): 26.888719
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 310.564375
CPU 10 DPC total execution time (s): 2.531935
CPU 10 DPC count: 232997
CPU 11 Interrupt cycle time (s): 26.926351
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 306.48750
CPU 11 DPC total execution time (s): 0.021640
CPU 11 DPC count: 3501
