Errors in SFC and SUR tool showing CSI Missing Winning Component Key
Peregrine
Hello,
I was wondering if you could help me out. This is for Win7 Ult SP1 x64. I've had some serious corruptions in my system. After a lot of work I got to the point where my system runs almost flawlessly, but I still have few issues. Looks like SFC only fails in few places, and I'll continue running it later but need this SUR problem fixed. I've completely removed everything related to AVG using Revo Uninstaller, then AVG Removed (twice), then AVG Clear (twice), and when I run SUR tool, I still get the following 16 errors:
Checking Component Store
(f) CSI Missing Winning Component Key 0x00000000 amd64_avg.vc140.crt_f92d94485545da78_14.0.26706.0_none_6d113b85d59413fa
(f) CSI Missing Winning Component Key 0x00000000 amd64_policy.14.0.avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_882c42cee4e7ea43
(f) CSI Missing Winning Component Key 0x00000000 amd64_policy.14.0.avg.vc140.mfc_f92d94485545da78_14.0.26706.0_none_89807f9ce3546d8b
(f) CSI Missing Winning Component Key 0x00000000 x86_avg.vc140.crt_f92d94485545da78_14.0.26706.0_none_b4be725cea103d00
(f) CSI Missing Winning Component Key 0x00000000 amd64_policy.14.0.avg.vc140.crt_f92d94485545da78_14.0.26706.0_none_90ff6566de85f0a8
(f) CSI Missing Winning Component Key 0x00000000 x86_policy.14.0.avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_d7585f6ff4959666
(f) CSI Missing Winning Component Key 0x00000000 x86_policy.14.0.avg.vc140.mfc_f92d94485545da78_14.0.26706.0_none_d12db673f7d09691
(f) CSI Missing Winning Component Key 0x00000000 amd64_avg.vc140.mfc_f92d94485545da78_14.0.26706.0_none_659255bbda6290dd
(f) CSI Missing Winning Component Key 0x00000000 x86_avg.vc140.mfc_f92d94485545da78_14.0.26706.0_none_ad3f8c92eedeb9e3
(f) CSI Missing Winning Component Key 0x00000000 amd64_policy.14.0.avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_8fab2898e0196d60
(f) CSI Missing Winning Component Key 0x00000000 amd64_avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_643e18eddbf60d95
(f) CSI Missing Winning Component Key 0x00000000 x86_avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_abeb4fc4f072369b
(f) CSI Missing Winning Component Key 0x00000000 x86_policy.14.0.avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_cfd979a5f9641349
(f) CSI Missing Winning Component Key 0x00000000 x86_avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_b36a358eeba3b9b8
(f) CSI Missing Winning Component Key 0x00000000 amd64_avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_6bbcfeb7d72790b2
(f) CSI Missing Winning Component Key 0x00000000 x86_policy.14.0.avg.vc140.crt_f92d94485545da78_14.0.26706.0_none_d8ac9c3df30219ae
Summary:
Seconds executed: 253
Found 16 errors
CSI Missing Winning Component Key Total count: 16
Can anyone help me with this?
Thank you
2. Download the attachment fixlist.txt and save it to your desktop.
3. Right-click on FRST64.exe and select "Run as administrator".
4. Press the Fix button.
5. The tool will now process fixlist.txt.
6. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
7. When finished, a log called Fixlog.txt will appear in the same directory the tool is run from.
8. Post the logfile Fixlog.txt as attachment in your next reply.
Thank you very much!
That fixed the SUR (files attached), but I'm still having problems with SFC. Seems there are still some errors, not a lot, but it keeps on failing. Unfortunately the CBS file from the last scan alone is 3MB, which exceeds max size of allowed attachments here. Would you still have any way to help me with this?
Click on the Start button and in the search box, type Command Prompt.
When you see Command Prompt on the list, right-click on it and select Run as administrator.
When command prompt opens, copy and paste the following command into it, then press enter.
This will create a file, cbs.txt on your Desktop.
Upload the file cbs.txt on your desktop via a service such as Filedropper or One Drive or SendSpace and just provide the download link.
  • Download
Just let SFCFix continue processing the fix.
I let it run for over an hour and it shows no progress whatsoever...
If SFCFix only displays the text as in message #7, press the spacebar. SFCFix should then continue and display the text "Processing ..."
If it fails, run sfc /scannow again.
Copy the log file CBS.log to your desktop, see message #4 and attach the file to your next reply.
