[SOLVED] Entry point terminate could not be located
jondeadsnow
Thanks in advance for your help. I have a HP pavilion laptop, 8gb ram, intel core i5 and 2g NVidia card. I've been facing an issue while running certain programms where initially it said certain .dll files were missing so the program wouldn't run. I managed to fix that issue and now it says "The Procedure entry point terminate could not be located in the dynamic link library". After doing some quick searches online I found a method to do an SFC scan. It gave the message that certain files were corrupted and could not be fixed. I then ran the DISM restore health command but it wasn't succesful giving the error code "0x80240021".
I am a complete newbie so I have no idea what to do.
I have attached the DISM and SFC logs below.
Thanks again.
Sorry about that. I think I downloaded the right version now. I have attached the SFCfix text file below.
sorry again for the trouble.
You did this correctly.
Please do the following now:
SFC Scan
I ran the DISM.
C:\Windows\system32>dism /online /cleanup-image /restorehealth
Version: 6.3.9600.17031
Image Version: 6.3.9600.17031
Error: 0x80240021
DISM failed. No operation was performed.
Please do the following:
Retrieve Components Hive
Afterwards, do the following:
Thank you!
Start time: 2019-09-09 22:29:14.422
Using .zip script file at C:\Users\Jonathan\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21180_none_826a5c7c1410ea88
Successfully copied file C:\Users\Jonathan\AppData\Local\niemiro\Archive\WinSxS\amd64_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21180_none_826a5c7c1410ea88\thirdpartynotices.txt to C:\Windows\WinSxS\amd64_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21180_none_826a5c7c1410ea88\thirdpartynotices.txt.
Successfully restored ownership for C:\Windows\WinSxS\amd64_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21180_none_826a5c7c1410ea88
Successfully restored permissions on C:\Windows\WinSxS\amd64_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21180_none_826a5c7c1410ea88
Finish time: 2019-09-09 22:29:15.958
Script hash: OJ098VHIW+wR+M1uIa81S2jA4CGFP8sBCLKFN6XlsKA=
Hey, I made sure that all the C++ packages were installed. I am still getting an "The procedure entry point terminate could not be located in the dynamic link library" error.
I re installed the applications and the error still persists.
