Endless BSOD - help
kirst185
Hi, I have been having the same problem with my machine running Windows 10. The BSOD usually occurs whilst using google chrome and often reoccurs once restarting but with a different stop code listed. I have run the app listed in the post above. The output is attached. I would appreciate your help with this. Thanks
Hi kirsty!
Please, try to remove outbyte pcrepair altogether.
If you bought a license for it, note it down (before you remove it).
If bsods will continue after this, run a memtest.
You can find 4 tutorials in the hardware subforum (in this same sysnative forum).
The one usually recommended is PASSMARK memtest86 (the free version), but I prefer HCIDesign memtest (the free version).
You can try both, obviously.
