DPC WATCHDOG VIOLATION + DRIVER POWER STATE FAILURE BSOD
darks1de
The 1st BSOD I had was the DPC_watchdog_violation:
I proceed to go on Device Manager and locate the IDE ATA/ATAPI Controllers, then change it from iaStorA.sys to storachi.sys. Next, I updated all my current drivers, including my graphics card driver (I now have Nvidia v. 385.41 driver). Also, I did a disk check just to be safe, and it doesn't seem that there is any bad parts on the chkdsk c:. Finally, I saved everything and restarted. Then, the other BSOD message appeared.
Driver_Power_State_Failure BSOD: At this point I'm certain it is my graphics card + drivers somehow being incompatible to each other. According to most guides out there, everyone is recommending to do the above, updating + restarting. I've done a clean update on my graphics drivers. No matter which driver I use for my graphics card, it will eventually crash.
My laptop doesn't seem to crash if I disable the Graphics card, but of course, I can't play any games if I have it disabled.
OS : WINDOWS 10 PRO OEM X64
Original OS : WINDOWS 8
CPU : INTEL CORE I7 4710HQ
VGA : GTX 860M 4GB
Laptop Lenovo Y50
RAM : 8GB
Here's my DUMP BSOD Files.
Hi. . .
The lone dump named your NVIDIA driver -
nvlddmkm.sys Thu Dec 29 07:28:42 2016 (5865017A)
Bugcheck was 0x9f (0x3,,,) - driver is in an inconsistent power state; A device object has been blocking an Irp for too long a time.
NVIDIA is the definite culprit -
1: kd> !irp ffffe58f`67630bf0
Irp is active with 6 stacks 5 is current (= 0xffffe58f67630de0)
No Mdl: No System Buffer: Thread 00000000: Irp stack trace. Pending has been returned
cmd flg cl Device File Completion-Context
[IRP_MJ_POWER(16), IRP_MN_WAIT_WAKE(0)]
0 0 ffffe58f5fa6d060 00000000 fffff8047545d870-ffffe2000f61b890
\Driver\pci dxgkrnl!DpiFdoPowerCompletionRoutine
>[IRP_MJ_POWER(16), IRP_MN_SET_POWER(2)]
0 e1 ffffe58f65c36030 00000000 fffff80460f86930-ffffe58f68d0fc80 Success Error Cancel pending
\Driver\nvlddmkm nt!PopRequestCompletion
Args: 00000000 00000001 00000001 00000000
[N/A(0), N/A(0)]
0 0 00000000 00000000 00000000-ffffe58f68d0fc80
Update that 2016 NVIDIA driver - Driver Reference Table (DRT) | nvlddmkm.sys
See if Lenovo has a BIOS update for your system -
BIOS Version: LENOVO 9ECN40WW(V3.00), 7/22/2015
Make sure this is your system before proceeding with the 22 January 2019 BIOS update - BIOS Update Utility for Windows 10 (64-bit), 8.1 (64-bit), 7 (64-bit) - ThinkPad P50 - US
Regards. . .
jcgriff2
Microsoft (R) Windows Debugger Version 10.0.10075.9 AMD64
Loading Dump File [C:\Users\PalmDesert\AppData\Local\Temp\SAL90C.tmp\030119-78031-01.dmp]
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 10 Kernel Version 17763 MP (8 procs) Free x64
Built by: 17763.1.amd64fre.rs5_release.180914-1434
Machine Name:
Kernel base = 0xfffff804`60e1c000 PsLoadedModuleList = 0xfffff804`61237ad0
Debug session time: Thu Feb 28 21:23:23.501 2019 (UTC - 5:00)
System Uptime: 0 days 2:14:56.324
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
No .natvis files found at C:\Program Files (x86)\Windows Kits\10\Debuggers\x64\Visualizers.
BugCheck 9F, {3, ffffe58f5fa6d060, ffffe2000f6298d0, ffffe58f67630bf0}
Implicit thread is now ffffe58f`5eeb5040
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+1b5410 )
Followup:     MachineOwner
Processing initial command '!analyze -v;r;kv;lmtn;lmtsmn;.bugcheck'
1: kd> !analyze -v;r;kv;lmtn;lmtsmn;.bugcheck
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: ffffe58f5fa6d060, Physical Device Object of the stack
Arg3: ffffe2000f6298d0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe58f67630bf0, The blocked IRP
Debugging Details:
SYSTEM_SKU:  LENOVO_MT_20378_BU_idea_FM_Lenovo Y50-70
SYSTEM_VERSION:  Lenovo Y50-70
BIOS_DATE:  07/22/2015
BASEBOARD_PRODUCT:  Lenovo Y50-70
BASEBOARD_VERSION:  31900059WIN
BUGCHECK_P1: 3
BUGCHECK_P2: ffffe58f5fa6d060
BUGCHECK_P3: ffffe2000f6298d0
BUGCHECK_P4: ffffe58f67630bf0
DRVPOWERSTATE_SUBCODE:  3
FAULTING_THREAD:  5eeb5040
CPU_COUNT: 8
CPU_MHZ: 9be
CPU_VENDOR:  GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 3c
CPU_STEPPING: 3
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
ANALYSIS_VERSION: 10.0.10075.9 amd64fre
LAST_CONTROL_TRANSFER:  from fffff80460f35567 to fffff80460fd5fe6
STACK_TEXT:
ffffe200`0f61ac20 fffff804`60f35567 : ffffe58f`5eeb5040 00000000`00000000 ffff9101`443df200 fffff804`61044457 : nt!KiSwapContext+0x76
ffffe200`0f61ad60 fffff804`60f350d9 : ffffe58f`5ee9d300 00000000`00002c4c 00000000`00000000 fffff804`61044d90 : nt!KiSwapThread+0x297
ffffe200`0f61ae20 fffff804`60f33e60 : 00000000`00000000 fffff804`00000000 ffffd18d`00000000 ffffe200`0f61af31 : nt!KiCommitThreadWait+0x549
ffffe200`0f61aec0 fffff804`77df5410 : ffffe58f`6caf8130 fffff804`00000000 00000000`00000000 00000000`00000100 : nt!KeWaitForSingleObject+0x520
ffffe200`0f61af90 ffffe58f`6caf8130 : fffff804`00000000 00000000`00000000 00000000`00000100 00000000`00000000 : nvlddmkm+0x1b5410
ffffe200`0f61af98 fffff804`00000000 : 00000000`00000000 00000000`00000100 00000000`00000000 00000000`00000000 : 0xffffe58f`6caf8130
ffffe200`0f61afa0 00000000`00000000 : 00000000`00000100 00000000`00000000 00000000`00000000 00000000`00000000 : 0xfffff804`00000000
STACK_COMMAND:  .thread 0xffffe58f5eeb5040 ; kb
FOLLOWUP_IP:
nvlddmkm+1b5410
fffff804`77df5410 ??              ???
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  nvlddmkm+1b5410
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  5865017a
BUCKET_ID_FUNC_OFFSET:  1b5410
FAILURE_BUCKET_ID:  0x9F_3_nvlddmkm!Unknown_Function
PRIMARY_PROBLEM_CLASS:  0x9F_3_nvlddmkm!Unknown_Function
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x9f_3_nvlddmkm!unknown_function
FAILURE_ID_HASH:  {8b257f08-e34e-7c26-3880-084b82f90c48}
rax=ffffe58f5ee7fa20 rbx=ffffe58f67630bf0 rcx=000000000000009f
rdx=0000000000000003 rsi=ffffe58f68d0fcf8 rdi=ffffe58f68d0fc80
rip=fffff80460fcf440 rsp=ffffe2000f629898 rbp=ffff910143d6a200
 r8=ffffe58f5fa6d060  r9=ffffe2000f6298d0 r10=000000000000000f
r11=000000000000000f r12=ffffe2000f629b10 r13=0000000000000007
r14=ffff910143d5a180 r15=000000000000008a
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00000246
nt!KeBugCheckEx:
fffff804`60fcf440 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:ffffe200`0f6298a0=000000000000009f
 # Child-SP          RetAddr           : Args to Child                                                           : Call Site
00 ffffe200`0f629898 fffff804`610ede06 : 00000000`0000009f 00000000`00000003 ffffe58f`5fa6d060 ffffe200`0f6298d0 : nt!KeBugCheckEx
01 ffffe200`0f6298a0 fffff804`610edd12 : ffffe58f`68d0fc80 ffffe58f`68d0fcf8 00000000`0000008a ffff9101`43d5a180 : nt!PopIrpWatchdogBugcheck+0xea
02 ffffe200`0f629910 fffff804`60ed3659 : ffffe58f`68d0fcb8 ffff9101`43d6a200 ffffe58f`68d0fcf8 00000000`00000002 : nt!PopIrpWatchdog+0x22
03 ffffe200`0f629960 fffff804`60ed45a7 : 00000000`0000001a 00000000`00989680 ffff9101`43d6a200 00000000`0000001a : nt!KiProcessExpiredTimerList+0x159
04 ffffe200`0f629a50 fffff804`60fd2e5a : ffffffff`00000000 ffff9101`43d5a180 00000000`00000000 ffff9101`43d6a200 : nt!KiRetireDpcList+0x4a7
05 ffffe200`0f629c60 00000000`00000000 : ffffe200`0f62a000 ffffe200`0f624000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
ffffb24e`e7760000 ffffb24e`e77eb000   win32k   win32k.sys   unavailable (00000000)
ffffb24e`e7800000 ffffb24e`e7a6d000   win32kbase win32kbase.sys unavailable (00000000)
ffffb24e`e7a70000 ffffb24e`e7ab8000   cdd      cdd.dll      unavailable (00000000)
ffffb24e`e87a0000 ffffb24e`e8b32000   win32kfull win32kfull.sys unavailable (00000000)
fffff804`60e1c000 fffff804`6188b000   nt       ntkrnlmp.exe ***** Invalid (A45BF00A)
fffff804`6188c000 fffff804`61923000   hal      hal.dll      ***** Invalid (FBE06E6E)
fffff804`61a00000 fffff804`61a0b000   kd       kd.dll       Fri Feb 09 10:20:45 2035 (7A776DCD)
fffff804`753c0000 fffff804`753ee000   cdrom    cdrom.sys    Sat May 06 17:45:03 2017 (590E43DF)
fffff804`753f0000 fffff804`75405000   filecrypt filecrypt.sys Sun Aug 13 10:30:12 2034 (798A13F4)
fffff804`75410000 fffff804`7541e000   tbs      tbs.sys      Wed Dec 03 00:21:40 2036 (7DE0F3E4)
fffff804`75420000 fffff804`7542a000   Null     Null.SYS     unavailable (00000000)
fffff804`75430000 fffff804`7543a000   Beep     Beep.SYS     ***** Invalid (E2569389)
fffff804`75440000 fffff804`7577f000   dxgkrnl  dxgkrnl.sys  ***** Invalid (B964EF01)
fffff804`75780000 fffff804`75796000   watchdog watchdog.sys ***** Invalid (8D7A0DF0)
fffff804`757a0000 fffff804`757b6000   BasicDisplay BasicDisplay.sys ***** Invalid (D39D4B86)
fffff804`757c0000 fffff804`757d1000   BasicRender BasicRender.sys Sat Jul 21 21:02:48 2012 (500B5138)
fffff804`757e0000 fffff804`757fc000   Npfs     Npfs.SYS     Sat Jul 09 15:56:34 1994 (2E1F00F2)
fffff804`75800000 fffff804`75811000   Msfs     Msfs.SYS     Fri Oct 24 02:27:06 2008 (49016ABA)
fffff804`75820000 fffff804`75847000   tdx      tdx.sys      ***** Invalid (AFDABF6D)
fffff804`75850000 fffff804`75860000   TDI      TDI.SYS      ***** Invalid (E9708B47)
fffff804`75870000 fffff804`758c1000   netbt    netbt.sys    Mon Aug 06 03:08:11 2035 (7B61A55B)
fffff804`758d0000 fffff804`758e3000   afunix   afunix.sys   ***** Invalid (CE69FF46)
fffff804`758f0000 fffff804`75996000   afd      afd.sys      ***** Invalid (E7A7D654)
fffff804`759a0000 fffff804`759e2000   VBoxNetLwf VBoxNetLwf.sys Thu Nov 08 14:35:01 2018 (5BE48FE5)
fffff804`759f0000 fffff804`759fc000   cfywlan1 cfywlan1.sys Thu Oct 22 12:07:48 2015 (562909D4)
fffff804`75a00000 fffff804`75a0e000   cnnctfy3 cnnctfy3.sys Tue Sep 01 16:42:49 2015 (55E60DC9)
fffff804`75a10000 fffff804`75a2a000   vwififlt vwififlt.sys ***** Invalid (B1239F86)
fffff804`75a30000 fffff804`75a5b000   pacer    pacer.sys    ***** Invalid (BD6E6BA5)
fffff804`75a60000 fffff804`75a74000   netbios  netbios.sys  ***** Invalid (BA5B5FB4)
fffff804`75a80000 fffff804`75afa000   rdbss    rdbss.sys    ***** Invalid (EEC03A75)
fffff804`75b00000 fffff804`75b94000   csc      csc.sys      Thu May 23 03:54:40 2030 (71977CC0)
fffff804`75ba0000 fffff804`75bd3000   VBoxUSBMon VBoxUSBMon.sys Thu Nov 08 14:35:01 2018 (5BE48FE5)
fffff804`75be0000 fffff804`75c4b000   fastfat  fastfat.SYS  ***** Invalid (82EE518A)
fffff804`75c50000 fffff804`75c64000   bam      bam.sys      Fri Nov 13 20:53:16 1981 (1653310C)
fffff804`75c70000 fffff804`75cbe000   ahcache  ahcache.sys  Mon Jan 09 15:47:24 1995 (2F11A0DC)
fffff804`75cc0000 fffff804`76234000   dump_iaStorA dump_iaStorA.sys Wed Feb 17 08:18:44 2016 (56C47334)
fffff804`76240000 fffff804`7633a000   VBoxDrv  VBoxDrv.sys  Thu Nov 08 14:35:38 2018 (5BE4900A)
fffff804`76340000 fffff804`76352000   nsiproxy nsiproxy.sys Mon Sep 04 03:50:23 1972 (050877BF)
fffff804`76360000 fffff804`7636d000   npsvctrig npsvctrig.sys Mon Feb 23 01:11:04 2037 (7E4D1A78)
fffff804`76370000 fffff804`76380000   mssmbios mssmbios.sys ***** Invalid (A51D1A67)
fffff804`76390000 fffff804`7639a000   gpuenergydrv gpuenergydrv.sys ***** Invalid (DA1C403F)
fffff804`763a0000 fffff804`763cc000   dfsc     dfsc.sys     ***** Invalid (E60CDDBC)
fffff804`763d0000 fffff804`763ee000   winhvr   winhvr.sys   ***** Invalid (BDDA6167)
fffff804`763f0000 fffff804`763fd000   kdnic    kdnic.sys    Tue Sep 12 05:16:49 1972 (05131801)
fffff804`76400000 fffff804`764e6000   Rt630x64 Rt630x64.sys Thu Jan 07 02:44:09 2016 (568E1749)
fffff804`764f0000 fffff804`765b1000   RtsPer   RtsPer.sys   Thu Dec 10 22:10:40 2015 (566A3EB0)
fffff804`765c0000 fffff804`765e1000   flashud  flashud.sys  Fri Mar 06 04:57:27 2009 (49B0F387)
fffff804`765f0000 fffff804`76611000   i8042prt i8042prt.sys ***** Invalid (FB942A34)
fffff804`76620000 fffff804`766a8000   SynTP    SynTP.sys    Fri Mar 07 15:18:04 2014 (531A297C)
fffff804`766b0000 fffff804`766be000   USBD     USBD.SYS     ***** Invalid (C7E3B3E8)
fffff804`766c0000 fffff804`766d3000   mouclass mouclass.sys ***** Invalid (80F98B92)
fffff804`766e0000 fffff804`766ed000   Apkbfiltr Apkbfiltr.sys Sun Jul 19 22:13:25 2015 (55AC5945)
fffff804`766f0000 fffff804`76703000   kbdclass kbdclass.sys ***** Invalid (DB4B5540)
fffff804`76710000 fffff804`76728000   AcpiVpc  AcpiVpc.sys  Tue Sep 24 22:29:03 2013 (52424A6F)
fffff804`76730000 fffff804`7673f000   CmBatt   CmBatt.sys   ***** Invalid (DCC60961)
fffff804`76740000 fffff804`76750000   BATTC    BATTC.SYS    Thu Jun 17 17:32:25 2010 (4C1A9469)
fffff804`76760000 fffff804`7676e000   Smb_driver_Intel Smb_driver_Intel.sys Wed Dec 02 16:14:26 2015 (565F5F32)
fffff804`76770000 fffff804`7677c000   wmiacpi  wmiacpi.sys  ***** Invalid (F2622D42)
fffff804`76780000 fffff804`767be000   intelppm intelppm.sys Wed Feb 08 18:16:35 2012 (4F330253)
fffff804`767c0000 fffff804`767cd000   UEFI     UEFI.sys     Wed Sep 17 07:19:54 2014 (54196E5A)
fffff804`767d0000 fffff804`767dd000   NdisVirtualBus NdisVirtualBus.sys Thu Mar 27 17:31:46 1997 (333AE742)
fffff804`767e0000 fffff804`767ec000   swenum   swenum.sys   ***** Invalid (8B90F92A)
fffff804`767f0000 fffff804`767fe000   ScpVBus  ScpVBus.sys  Sun May 05 17:31:26 2013 (5186CFAE)
fffff804`76800000 fffff804`7680e000   rdpbus   rdpbus.sys   Thu Jun 28 00:49:12 2035 (7B2E1A48)
fffff804`76810000 fffff804`76898000   usbhub   usbhub.sys   Mon Jun 09 02:01:34 1997 (339B9C3E)
fffff804`76920000 fffff804`7692f000   ksthunk  ksthunk.sys  ***** Invalid (D43D6B7C)
fffff804`76930000 fffff804`769c3000   UsbHub3  UsbHub3.sys  Sat Jan 23 04:05:51 2010 (4B5ABBEF)
fffff804`769d0000 fffff804`76a1e000   srvnet   srvnet.sys   Thu Sep 04 21:29:37 2036 (7D6B6801)
fffff804`76a20000 fffff804`76ae4000   srv2     srv2.sys     ***** Invalid (A4440FCC)
fffff804`76af0000 fffff804`76f17000   athw8x   athw8x.sys   Thu Jan 28 04:52:54 2016 (56A9E4F6)
fffff804`76f30000 fffff804`76f81000   mrxsmb10 mrxsmb10.sys ***** Invalid (9EA3B66D)
fffff804`76f90000 fffff804`76fb7000   Ndu      Ndu.sys      Wed Feb 23 18:31:19 1983 (18BABC47)
fffff804`77200000 fffff804`779c4000   igdkmd64 igdkmd64.sys Thu Aug 16 13:03:04 2018 (5B75AE48)
fffff804`779d0000 fffff804`779ef000   HDAudBus HDAudBus.sys Fri Aug 17 18:16:38 1979 (121B41C6)
fffff804`779f0000 fffff804`77a55000   portcls  portcls.sys  ***** Invalid (8DFE43A2)
fffff804`77a60000 fffff804`77a81000   drmk     drmk.sys     Sun Jun 11 00:38:03 2000 (394317AB)
fffff804`77a90000 fffff804`77b06000   ks       ks.sys       Mon May 03 21:15:30 2027 (6BD926B2)
fffff804`77b10000 fffff804`77b88000   USBXHCI  USBXHCI.SYS  ***** Invalid (DD7F1F39)
fffff804`77b90000 fffff804`77bcf000   ucx01000 ucx01000.sys Sat Jan 03 10:23:30 2037 (7E0A5F72)
fffff804`77bd0000 fffff804`77c00000   TeeDriverW8x64 TeeDriverW8x64.sys Wed Feb 03 17:41:13 2016 (56B28209)
fffff804`77c10000 fffff804`77c2c000   usbehci  usbehci.sys  ***** Invalid (B398C408)
fffff804`77c40000 fffff804`78a18000   nvlddmkm nvlddmkm.sys Thu Dec 29 07:28:42 2016 (5865017A)
fffff804`78a20000 fffff804`78a9b000   USBPORT  USBPORT.SYS  Sat May 29 20:01:47 1999 (37507FEB)
fffff804`78aa0000 fffff804`78b76000   peauth   peauth.sys   Sun Oct 25 14:26:37 1998 (36336D5D)
fffff804`78c00000 fffff804`78d39000   HTTP     HTTP.sys     ***** Invalid (C141036D)
fffff804`78d40000 fffff804`78d65000   bowser   bowser.sys   Sat Jul 13 23:21:06 1996 (31E867A2)
fffff804`78d70000 fffff804`78d8a000   mpsdrv   mpsdrv.sys   ***** Invalid (8C4ECA64)
fffff804`78d90000 fffff804`78e19000   mrxsmb   mrxsmb.sys   ***** Invalid (8D1D01BD)
fffff804`78e20000 fffff804`78e66000   mrxsmb20 mrxsmb20.sys ***** Invalid (937BEDAD)
fffff804`78e70000 fffff804`78f48000   dxgmms2  dxgmms2.sys  ***** Invalid (DE16C166)
fffff804`78f50000 fffff804`78f66000   monitor  monitor.sys  Fri Jan 28 12:41:04 2005 (41FA7930)
fffff804`78f70000 fffff804`78f98000   luafv    luafv.sys    ***** Invalid (A3C4F026)
fffff804`78fa0000 fffff804`78fb3000   HIDPARSE HIDPARSE.SYS Sun Dec 27 00:38:28 2015 (567F7954)
fffff804`78fc0000 fffff804`78fed000   wcifs    wcifs.sys    ***** Invalid (A9AC8912)
fffff804`78ff0000 fffff804`79066000   cldflt   cldflt.sys   ***** Invalid (BACCC63E)
fffff804`79070000 fffff804`7908b000   storqosflt storqosflt.sys ***** Invalid (8CA43D00)
fffff804`79090000 fffff804`790a8000   lltdio   lltdio.sys   ***** Invalid (F5108909)
fffff804`790b0000 fffff804`790ca000   mslldp   mslldp.sys   ***** Invalid (A36249FA)
fffff804`790d0000 fffff804`790eb000   rspndr   rspndr.sys   ***** Invalid (C42F95A5)
fffff804`790f0000 fffff804`7910c000   wanarp   wanarp.sys   Sat Aug 31 06:38:32 1974 (08C5C028)
fffff804`79130000 fffff804`79144000   mmcss    mmcss.sys    ***** Invalid (D143BB7E)
fffff804`79160000 fffff804`79653000   RTKVHD64 RTKVHD64.sys Wed Apr 06 06:47:11 2016 (5704E92F)
fffff804`79660000 fffff804`7967e000   WinUSB   WinUSB.SYS   Mon Sep 07 20:29:34 1992 (2AABF3EE)
fffff804`79690000 fffff804`7969f000   dump_diskdump dump_diskdump.sys ***** Invalid (A0767573)
fffff804`796c0000 fffff804`796dd000   dump_dumpfve dump_dumpfve.sys Fri Dec 11 15:20:41 2015 (566B3019)
fffff804`796e0000 fffff804`7976c000   nwifi    nwifi.sys    Fri Sep 10 17:00:46 2032 (75ECF27E)
fffff804`79770000 fffff804`79788000   ndisuio  ndisuio.sys  Sat Apr 21 15:59:03 1979 (117F9087)
fffff804`79790000 fffff804`797bb000   winquic  winquic.sys  ***** Invalid (BFE89A0C)
fffff804`797c0000 fffff804`797f4000   idmwfp   idmwfp.sys   Wed Feb 28 14:33:36 2018 (5A970410)
fffff804`79e00000 fffff804`79e0e000   vwifibus vwifibus.sys Fri Mar 25 00:51:11 2022 (623D4A3F)
fffff804`79e10000 fffff804`79e22000   vwifimp  vwifimp.sys  Thu Apr 29 20:19:44 1982 (172F45A0)
fffff804`79e60000 fffff804`79e91000   usbccgp  usbccgp.sys  ***** Invalid (82D4CB5C)
fffff804`79ea0000 fffff804`79eb2000   hidusb   hidusb.sys   Sun Jul 18 13:59:02 1971 (02E73966)
fffff804`79ec0000 fffff804`79efb000   HIDCLASS HIDCLASS.SYS Sun Sep 30 14:58:36 1979 (1255155C)
fffff804`79f00000 fffff804`79f11000   kbdhid   kbdhid.sys   Sun Nov 19 05:23:12 2023 (6559E210)
fffff804`79f20000 fffff804`79f2f000   mouhid   mouhid.sys   Thu Jan 18 04:52:01 2007 (45AF4341)
fffff804`79f30000 fffff804`79f65000   usbaudio usbaudio.sys ***** Invalid (82E282F2)
fffff804`79f70000 fffff804`7a006000   srv      srv.sys      ***** Invalid (DB9F4C2B)
fffff804`7a010000 fffff804`7a024000   tcpipreg tcpipreg.sys Sun Jun 12 03:39:48 2005 (42ABE6C4)
fffff804`7a030000 fffff804`7a043000   condrv   condrv.sys   Sun Mar 17 02:10:57 1996 (314BACF1)
fffff804`7a050000 fffff804`7a06c000   rassstp  rassstp.sys  Sun Jul 18 01:45:37 2027 (6C3C4681)
fffff804`7a070000 fffff804`7a088000   NDProxy  NDProxy.sys  Fri Feb 17 16:09:40 2017 (58A76694)
fffff804`7a090000 fffff804`7a0b7000   AgileVpn AgileVpn.sys Wed Nov 05 00:08:44 2014 (5459B0DC)
fffff804`7a0c0000 fffff804`7a0e1000   rasl2tp  rasl2tp.sys  ***** Invalid (CA2A942B)
fffff804`7a0f0000 fffff804`7a110000   raspptp  raspptp.sys  Thu Sep 04 08:29:23 1997 (340EA9A3)
fffff804`7a120000 fffff804`7a13c000   raspppoe raspppoe.sys ***** Invalid (A6BA0271)
fffff804`7a140000 fffff804`7a14f000   ndistapi ndistapi.sys ***** Invalid (D2B2EDC9)
fffff804`7a150000 fffff804`7a18b000   ndiswan  ndiswan.sys  Tue Jun 23 22:43:25 1981 (1596B64D)
fffff804`7a190000 fffff804`7a1a2000   WdNisDrv WdNisDrv.sys ***** Invalid (91197011)
fffff804`7a1b0000 fffff804`7a1bb000   semav6msr64 semav6msr64.sys Mon Jan 22 12:35:46 2018 (5A6620F2)
fffff80e`fa600000 fffff80e`fa60b000   BOOTVID  BOOTVID.dll  Fri Nov 24 18:09:33 1995 (30B650AD)
fffff80e`fa610000 fffff80e`fa680000   FLTMGR   FLTMGR.SYS   Thu Jul 24 00:42:54 1975 (0A74874E)
fffff80e`fa690000 fffff80e`fa799000   clipsp   clipsp.sys   Thu Nov 29 20:37:56 2018 (5C009474)
fffff80e`fa7a0000 fffff80e`fa7ae000   cmimcext cmimcext.sys Thu Aug 19 18:55:44 2010 (4C6DB670)
fffff80e`fa7b0000 fffff80e`fa7bc000   ntosext  ntosext.sys  Fri Mar 03 22:05:50 2028 (6D6B5A0E)
fffff80e`fa7c0000 fffff80e`fa893000   CI       CI.dll       ***** Invalid (F2318608)
fffff80e`fa8a0000 fffff80e`fa957000   cng      cng.sys      ***** Invalid (A7D172D6)
fffff80e`fa960000 fffff80e`faa31000   Wdf01000 Wdf01000.sys ***** Invalid (AF1CEDD2)
fffff80e`faa40000 fffff80e`faa53000   WDFLDR   WDFLDR.SYS   Thu Jan 31 16:00:20 2008 (47A236E4)
fffff80e`faa60000 fffff80e`faa70000   WppRecorder WppRecorder.sys ***** Invalid (E5178B49)
fffff80e`faa80000 fffff80e`faa8f000   SleepStudyHelper SleepStudyHelper.sys ***** Invalid (D42ABCCC)
fffff80e`faa90000 fffff80e`faab4000   acpiex   acpiex.sys   Mon Jun 16 22:07:59 1975 (0A439B7F)
fffff80e`faac0000 fffff80e`fab11000   mssecflt mssecflt.sys Fri Jun 07 08:17:10 2013 (51B1CF46)
fffff80e`fab20000 fffff80e`fab3a000   SgrmAgent SgrmAgent.sys ***** Invalid (F7CA286D)
fffff80e`fab40000 fffff80e`fac08000   ACPI     ACPI.sys     ***** Invalid (A49A6357)
fffff80e`fac10000 fffff80e`fac1c000   WMILIB   WMILIB.SYS   Tue Apr 19 22:19:11 2033 (7710989F)
fffff80e`fac40000 fffff80e`fac83000   intelpep intelpep.sys ***** Invalid (83F72A94)
fffff80e`fac90000 fffff80e`faca6000   WindowsTrustedRT WindowsTrustedRT.sys ***** Invalid (BD0B79F0)
fffff80e`facb0000 fffff80e`facbb000   WindowsTrustedRTProxy WindowsTrustedRTProxy.sys Tue May 14 12:37:30 2013 (5192684A)
fffff80e`facc0000 fffff80e`facd4000   pcw      pcw.sys      ***** Invalid (C6C870F7)
fffff80e`face0000 fffff80e`faceb000   msisadrv msisadrv.sys Sun Nov 07 01:38:33 2004 (418DC2E9)
fffff80e`facf0000 fffff80e`fad5b000   pci      pci.sys      Sat Mar 30 03:50:00 1991 (27F44328)
fffff80e`fad60000 fffff80e`fad72000   vdrvroot vdrvroot.sys ***** Invalid (8ED5F3A9)
fffff80e`fad80000 fffff80e`fadae000   pdc      pdc.sys      ***** Invalid (E48D33A9)
fffff80e`fadb0000 fffff80e`fadc9000   CEA      CEA.sys      ***** Invalid (9B4697B8)
fffff80e`fadd0000 fffff80e`fadff000   partmgr  partmgr.sys  Mon Jun 19 19:20:15 1995 (2FE6062F)
fffff80e`fae00000 fffff80e`faea3000   spaceport spaceport.sys Sat Oct 15 02:22:49 1983 (19EE4A39)
fffff80e`faeb0000 fffff80e`faec9000   volmgr   volmgr.sys   ***** Invalid (91784A41)
fffff80e`faed0000 fffff80e`faf33000   volmgrx  volmgrx.sys  Tue Dec 25 16:43:09 2012 (50DA1DED)
fffff80e`faf40000 fffff80e`faf5f000   mountmgr mountmgr.sys ***** Invalid (A8481DD2)
fffff80e`faf60000 fffff80e`fb028000   fvevol   fvevol.sys   Wed Sep 15 11:15:15 1993 (2C973183)
fffff80e`fb030000 fffff80e`fb09d000   volsnap  volsnap.sys  ***** Invalid (AC1C69A4)
fffff80e`fb0a0000 fffff80e`fb0c5000   mup      mup.sys      ***** Invalid (D5074BA1)
fffff80e`fb0d0000 fffff80e`fb0e1000   iorate   iorate.sys   ***** Invalid (A096CD2D)
fffff80e`fb0f0000 fffff80e`fb10c000   disk     disk.sys     ***** Invalid (EB969297)
fffff80e`fb110000 fffff80e`fb17f000   CLASSPNP CLASSPNP.SYS Thu May 11 08:48:53 1995 (2FB207B5)
fffff80e`fb1a0000 fffff80e`fb1bc000   crashdmp crashdmp.sys ***** Invalid (FEF3C415)
fffff80e`fb1c0000 fffff80e`fb244000   Vid      Vid.sys      ***** Invalid (F42473AC)
fffff80e`fb250000 fffff80e`fb261000   CompositeBus CompositeBus.sys ***** Invalid (DD86440A)
fffff80e`fb270000 fffff80e`fb285000   umbus    umbus.sys    ***** Invalid (83197D71)
fffff80e`fb290000 fffff80e`fb2a5000   CAD      CAD.sys      Fri Sep 06 00:05:41 2019 (5D71DB15)
fffff80e`fb2f0000 fffff80e`fb47e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Wed Dec 26 23:46:12 2001 (3C2AA794)
fffff80e`fb480000 fffff80e`fb4e2000   msrpc    msrpc.sys    ***** Invalid (824F01ED)
fffff80e`fb4f0000 fffff80e`fb51b000   ksecdd   ksecdd.sys   ***** Invalid (C0930B22)
fffff80e`fb520000 fffff80e`fb531000   werkernel werkernel.sys Sat Aug 14 07:55:58 1971 (030A7CCE)
fffff80e`fb540000 fffff80e`fb5aa000   CLFS     CLFS.SYS     Fri Aug 19 17:07:32 2011 (4E4ED094)
fffff80e`fb5b0000 fffff80e`fb5d7000   tm       tm.sys       ***** Invalid (F1AC5A2F)
fffff80e`fb5e0000 fffff80e`fb5f8000   PSHED    PSHED.dll    Tue Nov 07 10:06:38 2034 (79FB7D7E)
fffff80e`fb600000 fffff80e`fb654000   WdFilter WdFilter.sys Tue May 03 03:26:50 2022 (6270D93A)
fffff80e`fb660000 fffff80e`fb8ed000   Ntfs     Ntfs.sys     Fri May 05 16:56:23 2006 (445BBBF7)
fffff80e`fb8f0000 fffff80e`fb8fd000   Fs_Rec   Fs_Rec.sys   ***** Invalid (CFF89B5E)
fffff80e`fb900000 fffff80e`fba53000   ndis     ndis.sys     Tue Jan 16 01:38:02 2024 (65A6244A)
fffff80e`fba60000 fffff80e`fbaf5000   NETIO    NETIO.SYS    ***** Invalid (C0E588AF)
fffff80e`fbb00000 fffff80e`fbb32000   ksecpkg  ksecpkg.sys  ***** Invalid (CD0C90B8)
fffff80e`fbb40000 fffff80e`fbe1b000   tcpip    tcpip.sys    Tue Feb 07 05:38:50 2023 (63E22A3A)
fffff80e`fbe20000 fffff80e`fbe98000   fwpkclnt fwpkclnt.sys ***** Invalid (DF926DC9)
fffff80e`fbea0000 fffff80e`fbed0000   wfplwfs  wfplwfs.sys  ***** Invalid (8AE4C0AC)
fffff80e`fbee0000 fffff80e`fbeeb000   volume   volume.sys   ***** Invalid (CB3F72CF)
fffff80e`fbef0000 fffff80e`fbf3f000   rdyboost rdyboost.sys Sun Aug 26 18:38:42 2018 (5B832BF2)
fffff80e`fbf50000 fffff80e`fc4c4000   iaStorA  iaStorA.sys  Wed Feb 17 08:18:44 2016 (56C47334)
fffff80e`fc4d0000 fffff80e`fc56b000   storport storport.sys Sun Dec 23 08:22:26 2007 (476E6112)
fffff80e`fc590000 fffff80e`fc5aa000   fileinfo fileinfo.sys ***** Invalid (85B4F747)
fffff80e`fc5b0000 fffff80e`fc5ee000   Wof      Wof.sys      Mon Nov 14 18:36:29 1988 (237F6DFD)
Unloaded modules:
fffff804`7a1c0000 fffff804`7a1f6000   usbaudio.sys
    Checksum:  00000000
    ImageSize:  00036000
fffff804`76f20000 fffff804`76f2f000   vwifibus.sys
    Checksum:  00000000
    ImageSize:  0000F000
fffff804`76af0000 fffff804`76f18000   athw8x.sys
    Checksum:  00000000
    ImageSize:  00428000
fffff804`79110000 fffff804`79123000   vwifimp.sys
    Checksum:  00000000
    ImageSize:  00013000
fffff804`79f30000 fffff804`79f66000   usbaudio.sys
    Checksum:  00000000
    ImageSize:  00036000
    Checksum:  00000000
    ImageSize:  00036000
fffff804`79e50000 fffff804`79e5b000   drmkaud.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff804`79e40000 fffff804`79e4d000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff804`79e30000 fffff804`79e3e000   MSTEE.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff804`79e10000 fffff804`79e21000   MSKSSRV.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff804`79e00000 fffff804`79e0d000   MSPCLOCK.sys
    Checksum:  00000000
    ImageSize:  0000D000
    Checksum:  00000000
    ImageSize:  00036000
fffff804`79e50000 fffff804`79e5e000   WpdUpFltr.sy
    Checksum:  00000000
    ImageSize:  0000E000
fffff804`79e00000 fffff804`79e4d000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  0004D000
fffff804`7a1c0000 fffff804`7a1e6000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  00026000
fffff80e`fc570000 fffff80e`fc58d000   EhStorClass.
    Checksum:  00000000
    ImageSize:  0001D000
fffff804`768a0000 fffff804`76918000   IntcDAud.sys
    Checksum:  00000000
    ImageSize:  00078000
fffff80e`fbf40000 fffff80e`fbf50000   dump_storpor
    Checksum:  00000000
    ImageSize:  00010000
fffff804`74e00000 fffff804`75375000   dump_iaStorA
    Checksum:  00000000
    ImageSize:  00575000
fffff804`753a0000 fffff804`753be000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  0001E000
fffff804`763d0000 fffff804`763ec000   dam.sys
    Checksum:  00000000
    ImageSize:  0001C000
fffff80e`fac20000 fffff80e`fac31000   WdBoot.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff80e`fbf40000 fffff80e`fbf50000   hwpolicy.sys
    Checksum:  00000000
    ImageSize:  00010000
Unloaded modules:
    Checksum:  00000000
    ImageSize:  00036000
    Checksum:  00000000
    ImageSize:  0000F000
    Checksum:  00000000
    ImageSize:  00428000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00036000
    Checksum:  00000000
    ImageSize:  00036000
    Checksum:  00000000
    ImageSize:  0000B000
    Checksum:  00000000
    ImageSize:  0000D000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  0000D000
    Checksum:  00000000
    ImageSize:  00036000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0004D000
    Checksum:  00000000
    ImageSize:  00026000
    Checksum:  00000000
    ImageSize:  0001D000
    Checksum:  00000000
    ImageSize:  00078000
    Checksum:  00000000
    ImageSize:  00010000
    Checksum:  00000000
    ImageSize:  00575000
    Checksum:  00000000
    ImageSize:  0001E000
    Checksum:  00000000
    ImageSize:  0001C000
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  00010000
Bugcheck code 0000009F
Arguments 00000000`00000003 ffffe58f`5fa6d060 ffffe200`0f6298d0 ffffe58f`67630bf0
 [N/A(0), N/A(0)]
            0  0 00000000 00000000 00000000-00000000
 [N/A(0), N/A(0)]
 [N/A(0), N/A(0)]
 [N/A(0), N/A(0)]
1: kd> .bugcheck
The BIOS update that you recommend was for Thinkpad P50, but my laptop version Y50. is that alright?
Sry for my bad english.
i update the latest nvidia driver 419.17 and my laptop still got the BSOD. my laptop works normally when i disabled the nvidia in device manager.
The latest BIOS Update for Lenovo y50-70 was 3.03 23 oct 2015 should i update it ? Currently my bios 3.00
Please send full kernel memory dump (memory.dmp). And yes. You can try to update BIOS. Maybe it will help
Yes on BIOS.
The version in your last post is v3.03; the one you have installed is v3.00
As @MrPepka said - upload the latest zipped dump.
Go to \windows\minidump - look at dates. Get the latest; copy to Documents or Desktop and zip it up and attach to your next post.
You cannot zip in the \windows directory.
Regards. . .
jcgriff2
Regards. . .
jcgriff2
He cannot upload file memory.dmp (full kernel memory dump) in the \windows directory? From a full kernel memory dump we could read the branch of the driver from the graphics card because maybe this driver is not guilty
Oh... Full Kernel - you are correct. My apologies.
Get the memory dump from \windows\memory.dmp copy out; zip up and upload to Google Docs or other site and provide us with a link.
Thanks,
jcgriff2
