hi.... i need help with my problem of Dpc high latency....
i think that ndis.sys is the main problem....
System Manufacturer? assembled by me (MB: MSI B350 tomahawk, GPU:RX580 8gb sapphire SPECIAL EDITION, NETWORK: Netis WF-2113 [RTIL8192SE/CE???], RAM: G.Skill Ripjaws 8 GBx1 2800 clocked at 2666MHz, WD 1TB, no DVD drive, CORSAIR CX550M 550W)
Laptop or Desktop? DESKTOP
Exact model number (if laptop, check label on bottom) NONE
OS ? (Windows 10, 8.1, 8, 7, Vista) Windows 10
x86 (32bit) or x64 (64bit)? x64
Service pack? -~1800
What was original installed OS on system? NONE
Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? Installed with "KMS"
Age of system? (hardware) 2 weeks
Age of OS installation? 2 weeks
Have you re-installed the OS? no
CPU Ryzen 5 1600 @3,6Ghz overclocked 1.2 voltage (stable), amd cool'N quietenabled, oc mode 4
RAM (brand, model, which slots are you using?) Slot 2 as described in the MB manual RAM: G.Skill Ripjaws 8 GBx1 2800 clocked at 2666MHz 17-17-17-37
Video Card GPU:RX580 8gb sapphire SPECIAL EDITION
MotherBoard - (if NOT a laptop) MB: MSI B350 tomahawk
Power Supply - brand & wattage (if laptop, skip this one) CORSAIR CX550M 550W
What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) Windows defender :noidea::rofl12:
Are you using proxy, vpn, ipfilters or similar software? TEAMVIEWER VPN (NOT IN USE) TUNNGLE (NOT IN USE) VMWARE (NOT IN USE)
Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) NO
Are you currently under/overclocking? Are there overclocking software installed on your system? YES only the CPU Ryzen 5 1600 @3,6Ghz overclocked 1.2 voltage (stable), amd cool'N quietenabled, oc mode 4 low temps and RPMs
SOMETIME I LOSE my connection (connection reset chrome or network changed)
SYS INFO: http://speccy.piriform.com/results/JBx0fFGm1YSJXVyJlg181j1
FILES NEEDED FOR THE DIAGNOSYS: details+trace .zip - Google Drive
THANKS A LOT IN ADVANCE
