DPC latency spikes causing audio stuttering
Garcia98
Hi, lately I've been experiencing random audio stutters when using Chrome and multitasking, doing some research I've found out that they're related to high DPC latency spikes. I have a Dell XPS 15 9550, I've tried reinstalling all the drivers from Dell's website and updating the BIOS but the stutters are still there, any help would be appreciated.
  • System Manufacturer? Dell
  • Laptop or Desktop? Laptop
  • Exact model number (if laptop, check label on bottom) XPS 15 9550 (i7, FHD)
  • OS ? (Windows 10, 8.1, 8, 7, Vista) Windows 10
  • x86 (32bit) or x64 (64bit)? x64
  • Service pack? Build 16299
  • What was original installed OS on system? Windows 10
  • Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? Windows 10 Education, full retail I guess
  • Age of system? (hardware) 1 year and a half
  • Age of OS installation? 7 months
  • Have you re-installed the OS? Yes
  • CPU: i7 6700HQ
  • RAM (brand, EXACT model, what slots are you using?) SK Hynix, HMA41GS6AFR8N-TF, 2 slots out of 2
  • Video Card: integrated HD 530, dedicated GTX 960M
  • MotherBoard - (if NOT a laptop) NA
  • Power Supply - brand & wattage (if laptop, skip this one) NA
  • Is driver verifier enabled or disabled? Disabled
  • What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) Avast
  • Are you using proxy, vpn, ipfilters or similar software? No
  • Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) No
  • Are you currently under/overclocking? Are there overclocking software installed on your system? No
Speccy: http://speccy.piriform.com/results/DZM8OvdiRLOVNLH74lX0zfz
Zip with trace.etl, msinfo32.nfo and DxDiag.txt: logs.zip - Google Drive
Ive been having annoying Audio Popping and after narrowing it down I downloaded LatencyMon. The results looked terrible so does anyone have an idea what could be going on? Also I couldnt figure out a good way to post results so here they are.
