Hello everybody, I'd like to ask for help on finding the cause of mouse delay and short stutters in games, because for fps games accurate and fast mouse movements are the biggest advantage over enemies.
I've done clean windows 10 install yesterday (formatted both SSD and HDD). Haven't installed a single program besides steam and 2 games. Windows update installed everything it needs. Haven't installed any drivers from motherboard manually and I can really say that Microsoft drivers made significant improvement on how the mouse behaves in game such as cs go, over the ones from asrock. However, Im not sure if my pc is optimized for best performance without the custom drivers made specially for my motherboard.
My computer ->
CPU: Intel i5 4690
GPU: GTX 1060 3gb
RAM: DDR3 Kingston HyperX blue 2x4 1333mhz cl9
MOBO: ASROCK H97M Pro 4
HDD: WD BLUE 3.5 1TB 7200RPM
SSD: Corsair Force LS 60GB
PSU: Cooler Master Thunder M 620w
CPU Cooler: Cooler Master Hyper evo 212
Mouse: Logitech g402
Monitor: Dell p2314h 1920x1080@60hz
Both processor and video card do not reach over 45 Celsius while gaming.
Things done to solve the problem:
1. Disabled xbox dvr
2. Switched between balanced - performance mode in battery settings.
3. Newest NVidia drivers
4. Ran latency mon test: Imgur: The most awesome images on the Internet
Summary _________________________________________________________________________________________________________
CONCLUSION
LatencyMon has been analyzing your system for 0:17:34 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-BNDSOFC
OS version: Windows 10 , 10.0, build: 14393 (x64)
Hardware: ASRock, H97M Pro4
CPU: GenuineIntel Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
Logical processors: 4
Processor groups: 1
RAM: 8127 MB total
CPU SPEED
Reported CPU speed: 3499 MHz
Highest measured interrupt to process latency (µs): 936,791864
Average measured interrupt to process latency (µs): 2,623720
Highest measured interrupt to DPC latency (µs): 916,59860
Average measured interrupt to DPC latency (µs): 0,917977
REPORTED ISRs
Highest ISR routine execution time (µs): 196,412975
Highest reported total ISR routine time (%): 0,179504
Total time spent in ISRs (%) 0,223668
ISR count (execution time <250 µs): 1150640
REPORTED DPCs
Highest DPC routine execution time (µs): 867,317805
Highest reported total DPC routine time (%): 0,073889
Total time spent in DPCs (%) 0,307659
DPC count (execution time <250 µs): 3990422
DPC count (execution time 500-999 µs): 37
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 9640
Hard pagefault count of hardest hit process: 2392
Highest hard pagefault resolution time (µs): 196781,727922
Total time spent in hard pagefaults (%): 0,247774
Number of processes hit: 32
PER CPU DATA
CPU 0 Interrupt cycle time (s): 38,413287
CPU 0 ISR highest execution time (µs): 196,412975
CPU 0 ISR total execution time (s): 9,416753
CPU 0 ISR count: 1148344
CPU 0 DPC highest execution time (µs): 867,317805
CPU 0 DPC total execution time (s): 11,751447
CPU 0 DPC count: 3745557
CPU 1 Interrupt cycle time (s): 12,160050
CPU 1 ISR highest execution time (µs): 129,933124
CPU 1 ISR total execution time (s): 0,013212
CPU 1 ISR count: 2069
CPU 1 DPC highest execution time (µs): 455,830237
CPU 1 DPC total execution time (s): 0,416407
CPU 1 DPC count: 80144
CPU 2 Interrupt cycle time (s): 10,810138
CPU 2 ISR highest execution time (µs): 16,331523
CPU 2 ISR total execution time (s): 0,000848
CPU 2 ISR count: 227
CPU 2 DPC highest execution time (µs): 523,629608
CPU 2 DPC total execution time (s): 0,380425
CPU 2 DPC count: 73708
CPU 3 Interrupt cycle time (s): 25,135746
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 509,720777
CPU 3 DPC total execution time (s): 0,423984
CPU 3 DPC count: 91050
My computer ->
CPU: Intel i5 4690
GPU: GTX 1060 3gb
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 8127 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 3 ISR count: 0
