DPC latency issues, cracking, stuttering and more
Alonzorion
So story so far goes, I've had 5 systems over the passed 2 years with almost entirely different parts between each build each with better specs than the previous, and we're talking motherboard, GPU, CPU, power unit, etc... however every single one of them has had exactly the same issue and I'm literally out of ideas about what could be wrong at this stage. This is a plague on my life.
The issue includes gradually worsening latency issues... we're talking system lag, sound popping, and game lag on pretty much anything, old games, brand new games, occasional freeze ups and micro stutter, and this all on a INTEL Skylake Core i7 6700K OC 4.5Ghz, ASUS Z170-P with a MSI GTX 980TI.
So, the only things I can think of that have been reoccurring with all 5 systems are the monitor (4K Samsung), the speakers, MY HOME?, my capture card, an old Elgato I use paired with my PS3, my external storage devices... and some of the programs I use. This includes general stuff like Skype, Steam, Audacity, Mirrilis Action, Vegas Pro, GIMP, OBS all of which I've purged many many times either uninstalling them or flat out doing a clean system reinstall, but this rarely seemed to fix any problems.
If you have any questions, please feel free to ask, I'm about to start on my 6th and would really rather it didn't have similar issues, I'm losing a lot of money because of this and a LOT of time from research and getting different components repaired, lol. :(
Following recommendations from this thread: https://www.sysnative.com/forums/wi...-latency-wdf01000-sys-ndis-sys.html#post97961 I've done an xperf trace and uploaded it here: Dropbox - CPU.7z unfortunately, I don't understand the results it's produced and would appreciate some direction. :)
Hi Alonzorion. :welcome:
    • System Manufacturer?
    • Laptop or Desktop?
    • x86 (32bit) or x64 (64bit)?
    • Service pack?
    • Age of system? (hardware)
    • Age of OS installation?
    • CPU
    • RAM (brand, model, which slots are you using?)
    • Video Card
  • System information log
    You should run only one of the following commands, the one you prefer.
    msinfo32 /nfo "c:\users\YourWinAccountFolder\desktop\MsInfo.nfo"
      or
      msinfo32 /nfo "c:\users\%username%\desktop\MsInfo.nfo"
      or
      msinfo32 /nfo "%userprofile%\desktop\MsInfo.nfo"
    (Then upload it here)
    1. Download Speccy portable - actual version 1.29.714 (click), unzip/decompress it and put it on your desktop.
    5. (Or attach the log here, if you prefer to not publish it for some reason)
  • Download and install the Windows Performance Toolkit on dev.windows.com - Windows Software Development Kit (SDK) for Windows 10 - sdksetup.exe 1.12MB (click) if you are using windows 10 or Download and install the Windows Performance Toolkit - Windows Assessment and Deployment Kit (Windows ADK) for Windows 8.1 Update - adksetup.exe 1.36MB (click)if you are using windows 8.1 (steps are almost identical...):
    Then open an elevated command prompt (right-click on the windows start button on bottom-left corner, left-click Command Prompt (Admin)) and launch these commands:
    You can also read the original tutorial/guide and its following posts for more informations:How to Diagnose and Fix High DPC Latency Issues with WPA (Windows Vista/7/8) (click) (by Niemiro)
