i do have realtek onboard sound, latest drivers installed and effects disabled. don't know about comms.
yes i believe i have the KILLER ETHERNET thing, i seen that in the uninstall bit. i use avira free.
isn't 'dxgkrnl.sys 5.154759' abnormally high, and would cause problems?
i haven't yet disabled the network/wifi adapter to see if that helps. the only problem is the problem can vanish for an extended period then come back with a vengeance, making it hard to troubleshoot.
should i uninstall KILLER ETHERNET? what is it?
I've been having similar troubles to you, and they have been eliminating itself one by one. The main issue is Windows 10 immature engine and that most companies don't have correctly working drivers. In previous windows, these problems were rare.
In my own thread, I posted that Nvidia (DXGKRNL.SYS) is aware of this dpc latency issue and will address it in a future patch. However, it seems Nvidia doesn't cause enough of an issue to overload the system with audio glitches unless pushed hard.
Killer Ethernet: The hardware itself is good, but its concept is totally ridiculous. There has been a number of reviews and tests that killer manager doesn't actually get your more bandwidth and speed. At best, it does nothing. But at worst, it actually chokes your internet. So I decided to use the "driver only" killer internet from MSI. I don't have the manager installed anymore and it helped tremendously. I'm really glad I didn't waste money on MSI gaming 9 ACK, which really is just another $100 on the second level Killer Ethernet upgrade. It's bad enough at default as it is!
Also check your mouse software. Steelseries "breathing" effect I found was noted for my usb disconnects and sudden CPU spikes when that event occurred.
And yes in the Audio Communications tab, check "DO NOTHING."
Then check what other software processes u have cluttering up the system.
Gary has been helping me quite a bit here, and I hope that together we can liberate our computers of this Windows 10 Latency madness. If we google this, we can see that all the same things happen in Win 10. Storport.sys, usbport.sys..nvidia driver, ndis.sys. Really, WIN 10 is still in beta!
If all else fails,we can revert to Win 8.1 I guess
