I recently build a new computer:
AMD FX-6300 Black Ed
ASUS M5a97 R2.0
EVGA GTX750TI SC 2GB
It is almost one month into using this computer and I have been experiencing crackling audio even when I switch tab while youtube is playing. I also sometime experience video lag when I play game. This is frustrating consider how new the computer is. I have figured it might have been DCP latency problem so I went ahead with some testings.
Please help me with this problem. I am very confused and lost as to what should I do. The crackling audio is really annoying especially when I tam coding while playing music in the background. I feel like I have wasted my money building my first pc. Thank you
ASUS M5a97 R2.0
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:08:31 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: RHOS-PC
Hardware: ASUSTeK COMPUTER INC., M5A97 R2.0
CPU: AuthenticAMD AMD FX(tm)-6300 Six-Core Processor
Logical processors: 6
Processor groups: 1
RAM: 8091 MB total
CPU SPEED
Reported CPU speed: 3511.0 MHz
Measured CPU speed: 3114.0 MHz (approx.)
Highest measured interrupt to process latency (µs): 16148.963281
Average measured interrupt to process latency (µs): 6.363534
Highest measured interrupt to DPC latency (µs): 11204.611657
Average measured interrupt to DPC latency (µs): 2.359079
REPORTED ISRs
Highest ISR routine execution time (µs): 12719.152093
Highest reported total ISR routine time (%): 0.221660
Total time spent in ISRs (%) 0.304890
ISR count (execution time <250 µs): 637652
ISR count (execution time 500-999 µs): 3116
ISR count (execution time 1000-1999 µs): 54
ISR count (execution time 2000-3999 µs): 66
REPORTED DPCs
Highest DPC routine execution time (µs): 11235.355169
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 347.25 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.173264
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0.476574
DPC count (execution time <250 µs): 3335973
DPC count (execution time 500-999 µs): 294
DPC count (execution time 1000-1999 µs): 10
DPC count (execution time 2000-3999 µs): 5
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 184
Hard pagefault count of hardest hit process: 134
Highest hard pagefault resolution time (µs): 500021.610652
Total time spent in hard pagefaults (%): 0.038051
Number of processes hit: 4
PER CPU DATA
CPU 0 Interrupt cycle time (s): 17.062709
CPU 0 ISR highest execution time (µs): 10247.318428
CPU 0 ISR total execution time (s): 2.162976
CPU 0 ISR count: 386901
CPU 0 DPC highest execution time (µs): 11179.050983
CPU 0 DPC total execution time (s): 5.252387
CPU 0 DPC count: 2477153
CPU 1 Interrupt cycle time (s): 7.741915
CPU 1 ISR highest execution time (µs): 12719.152093
CPU 1 ISR total execution time (s): 0.748094
CPU 1 ISR count: 28105
CPU 1 DPC highest execution time (µs): 2663.474509
CPU 1 DPC total execution time (s): 1.110779
CPU 1 DPC count: 96275
CPU 2 Interrupt cycle time (s): 7.884514
CPU 2 ISR highest execution time (µs): 11224.534036
CPU 2 ISR total execution time (s): 0.781581
CPU 2 ISR count: 29279
CPU 2 DPC highest execution time (µs): 11197.197380
CPU 2 DPC total execution time (s): 1.327273
CPU 2 DPC count: 131391
CPU 3 Interrupt cycle time (s): 7.37840
CPU 3 ISR highest execution time (µs): 10509.147821
CPU 3 ISR total execution time (s): 0.848642
CPU 3 ISR count: 29432
CPU 3 DPC highest execution time (µs): 2664.943606
CPU 3 DPC total execution time (s): 1.081424
CPU 3 DPC count: 89985
CPU 4 Interrupt cycle time (s): 7.706209
CPU 4 ISR highest execution time (µs): 10833.351182
CPU 4 ISR total execution time (s): 0.954264
CPU 4 ISR count: 35268
CPU 4 DPC highest execution time (µs): 11235.355169
CPU 4 DPC total execution time (s): 1.527436
CPU 4 DPC count: 192367
CPU 5 Interrupt cycle time (s): 13.120431
CPU 5 ISR highest execution time (µs): 11164.050128
CPU 5 ISR total execution time (s): 3.854615
CPU 5 ISR count: 131972
CPU 5 DPC highest execution time (µs): 11102.134435
CPU 5 DPC total execution time (s): 4.315962
CPU 5 DPC count: 349120
