[SOLVED] DPC Latency causing Pops and clipping when streaming audio. FIX: CLEAN INSTALL
Spookye
Hi all, sorry to bother with this, I've seen and tried all old posts but looks like they don't work for me, or it's just me... Now the thing is, my PC is a bit old, probably soon, I'll buy a new one, but still I'd like to get rid of this problem...
I'm attaching LatencyMon pics so that You can see Yourselves.
Plus I paste the report:
________________________________________________________________________________________________________
CONCLUSION
Your
system appears to be having trouble handling real-time audio and
other tasks. You are likely to experience buffer underruns appearing
as drop outs, clicks or pops. One or more DPC routines that belong to
a driver running in your system appear to be executing for too long.
Also one or more ISR routines that belong to a driver running in your
system appear to be executing for too long. One problem may be
related to power management, disable CPU throttling settings in
Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon
has been analyzing your system for 0:10:31 (h:mm:ss) on
all processors.
SYSTEM
INFORMATION
Computer
name:
SPOOKYE-PC
OS version:
Windows 7 Service Pack 1, 6.1, build: 7601 (x64)
Hardware:
Maximus Formula, , ASUSTeK Computer INC.
CPU:
GenuineIntel Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHZ
Logical processors:
4
Processor groups:
1
RAM:
3327 MB total
CPU
SPEED
Reported
CPU speed:
2504 MHz
Highest measured interrupt to process latency (µs):
201207,616101
Average measured interrupt to process latency
(µs): 93,806458
Highest measured interrupt to DPC latency (µs):
201204,345423
Average measured interrupt to DPC latency
(µs): 89,956948
REPORTED ISRs
Highest ISR routine execution time (µs):
1574,343850
Driver with highest ISR routine execution time:
dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%):
0,234222
Driver with highest ISR total time:
Total time spent in ISRs (%)
0,350161
ISR count (execution time <250 µs):
1243171
ISR count (execution time 250-500 µs):
0
ISR count (execution time 500-999 µs):
4
ISR count (execution time 1000-1999 µs):
2
ISR count (execution time 2000-3999 µs):
0
ISR count (execution time >=4000 µs):
0
REPORTED
DPCs
Highest DPC routine execution time (µs):
201123,638978
Driver with highest DPC routine execution time:
storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%):
1,415382
Driver with highest DPC total execution time:
Total time spent in DPCs (%)
1,767173
DPC count (execution time <250 µs):
1371583
DPC count (execution time 250-500 µs):
0
DPC count (execution time 500-999 µs):
73
DPC count (execution time 1000-1999 µs):
2
DPC count (execution time 2000-3999 µs):
0
DPC count (execution time >=4000 µs):
0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count:
iexplore.exe
Total number of hard pagefaults
1672
Hard pagefault count of hardest hit process:
625
Highest hard pagefault resolution time (µs):
683678,046725
Total time spent in hard pagefaults (%):
0,671775
Number of processes hit:
31
PER CPU DATA
CPU
0 Interrupt cycle time (s):
42,023367
CPU 0 ISR highest execution time (µs):
1574,343850
CPU 0 ISR total execution time (s):
2,376719
CPU 0 ISR count:
370540
CPU 0 DPC highest execution time (µs):
201123,638978
CPU 0 DPC total execution time (s):
38,535445
CPU 0 DPC count:
638904
CPU
1 Interrupt cycle time (s):
5,682420
CPU 1 ISR highest execution time (µs):
535,986422
CPU 1 ISR total execution time (s):
2,102999
CPU 1 ISR count:
290995
CPU 1 DPC highest execution time (µs):
195467,731629
CPU 1 DPC total execution time (s):
2,036764
CPU 1 DPC count:
227105
CPU
2 Interrupt cycle time (s):
6,203167
CPU 2 ISR highest execution time (µs):
933,327476
CPU 2 ISR total execution time (s):
2,292904
CPU 2 ISR count:
291957
CPU 2 DPC highest execution time (µs):
200979,908147
CPU 2 DPC total execution time (s):
2,177041
CPU 2 DPC count:
256079
CPU
3 Interrupt cycle time (s):
5,516974
CPU 3 ISR highest execution time (µs):
119,128594
CPU 3 ISR total execution time (s):
2,065544
CPU 3 ISR count:
289685
CPU 3 DPC highest execution time (µs):
100422,064696
CPU 3 DPC total execution time (s):
1,854765
CPU 3 DPC count:
249890
Bios is updated to the latest release...
Hope someone will sort me out.
Thanxx in advance
Fabio
Ps: if more info is needed just let me know
Re: DPC Latency causing Pops and clipping when streaming audio
Is your BIOS updated and is the GPU drivers updated?
Update/reinstall the chipset drivers.
No other way to solve than a clean install, now latency's gone.
Thanxx to everybody for Your support.
Cheers
