Hello,
Running Windows 10 x64 with the latest drivers, BIOS update etc. Model is Lenovo S540 Core i5, 8GB RAM, ATI 8670M Graphics + Intel HD Integrated Graphics, 500GB HDD.
I've owned the machine for about May 2014. This has been a long running issue (See previous post: https://forums.lenovo.com/t5/ThinkPad-S-Series-ThinkPad-Yoga/Bluetooth-Audio-Stuttering/m-p/2045346#...)
Audio is fine using wired headphones and from the speakers. However, when using Bluetooth headphones I get stuttering and lag. This is the same case with a Microsoft Wireless Bluetooth Mouse.
So far I've tested
Really out of ideas
. Called Lenovo last year to see if they could take a look, they had a daft response saying they can only help if the earphones are Lenovo branded. Useless.
Only thing I can think of now is to replace the WiFi and Bluetooth modules because this Intel 7260 one is crap.
Ran a couple of latency checker programs. See results:
Would appreciate any suggestions.
Thank you for your help in advance.
So far I've tested
- Sony Bluetooth Over Ear Headphones (worked fine till around Spring 2015)
- BackBeat Go Bluetooth earphones (worked as well fine before)
- Tried disabling WiFi
- Tried disabling LAN
- Tried disabling other components
- Use a Netgear USB for WiFi ATM - issue persists
- Did verifier earlier and no BSOD
- Tried in 3 different houses, Sky, Virgin and some other broadband. Same result
- Tried checking for phone interference - e.g. turned off printer, moved away metal, turned phone on airplane mode
Really out of ideas
