dpc latency and audio crackle
djandyw
Hi everyone i realy need some advice on fixing this issue with dpc latency. I can't use my computer right now because of the dpc latency the audio won't stop skipping here is my report from latency mon
I'm new to this dpc latency issue so any advice on troubleshooting it would be great. I even reformatted my computer and it's still crackling and skipping my audio.
CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:00:44 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-UK20R46
Hardware: MS-7A20, MSI, X99A GAMING PRO CARBON (MS-7A20)
CPU: GenuineIntel Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
Logical processors: 12
Processor groups: 1
RAM: 32671 MB total
CPU SPEED
Reported CPU speed: 340 MHz
Highest measured interrupt to process latency (µs): 466.220685
Average measured interrupt to process latency (µs): 7.542309
Highest measured interrupt to DPC latency (µs): 463.208923
Average measured interrupt to DPC latency (µs): 3.786540
REPORTED ISRs
Highest ISR routine execution time (µs): 134.430
Highest reported total ISR routine time (%): 0.093051
Total time spent in ISRs (%) 0.097497
ISR count (execution time <250 µs): 75523
REPORTED DPCs
Highest DPC routine execution time (µs): 1126.487353
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 378.66 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.097787
Driver with highest DPC total execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Total time spent in DPCs (%) 0.377450
DPC count (execution time <250 µs): 1106915
DPC count (execution time 500-999 µs): 6
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: thunderbird.exe
Total number of hard pagefaults 199
Hard pagefault count of hardest hit process: 133
Highest hard pagefault resolution time (µs): 27153.552059
Total time spent in hard pagefaults (%): 0.028790
Number of processes hit: 12
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2.960393
CPU 0 ISR highest execution time (µs): 134.430
CPU 0 ISR total execution time (s): 0.459670
CPU 0 ISR count: 42762
CPU 0 DPC highest execution time (µs): 1126.487353
CPU 0 DPC total execution time (s): 1.171505
CPU 0 DPC count: 660617
CPU 1 Interrupt cycle time (s): 0.570877
CPU 1 ISR highest execution time (µs): 88.272059
CPU 1 ISR total execution time (s): 0.046609
CPU 1 ISR count: 11711
CPU 1 DPC highest execution time (µs): 134.100882
CPU 1 DPC total execution time (s): 0.141989
CPU 1 DPC count: 34630
CPU 2 Interrupt cycle time (s): 1.025451
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 432.191765
CPU 2 DPC total execution time (s): 0.490478
CPU 2 DPC count: 353723
CPU 3 Interrupt cycle time (s): 0.410361
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 104.563529
CPU 3 DPC total execution time (s): 0.028547
CPU 3 DPC count: 9098
CPU 4 Interrupt cycle time (s): 0.350164
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 89.293529
CPU 4 DPC total execution time (s): 0.014542
CPU 4 DPC count: 7616
CPU 5 Interrupt cycle time (s): 0.327007
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 125.080
CPU 5 DPC total execution time (s): 0.021133
CPU 5 DPC count: 6288
CPU 6 Interrupt cycle time (s): 0.372520
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 113.990
CPU 6 DPC total execution time (s): 0.034791
CPU 6 DPC count: 7596
CPU 7 Interrupt cycle time (s): 0.3370
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 98.286471
CPU 7 DPC total execution time (s): 0.017832
CPU 7 DPC count: 4325
CPU 8 Interrupt cycle time (s): 0.332420
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 119.220
CPU 8 DPC total execution time (s): 0.025047
CPU 8 DPC count: 6641
CPU 9 Interrupt cycle time (s): 0.308851
CPU 9 ISR highest execution time (µs): 65.189118
CPU 9 ISR total execution time (s): 0.008683
CPU 9 ISR count: 21050
CPU 9 DPC highest execution time (µs): 48.906471
CPU 9 DPC total execution time (s): 0.007978
CPU 9 DPC count: 3399
CPU 10 Interrupt cycle time (s): 0.463647
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 117.703235
CPU 10 DPC total execution time (s): 0.030198
CPU 10 DPC count: 10438
CPU 11 Interrupt cycle time (s): 0.354711
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 60.953824
CPU 11 DPC total execution time (s): 0.009575
CPU 11 DPC count: 2551
Preamble
Would you try these steps?
  • Left-click on Start, type directly msconfig, press enter.
    Is the radio button on normal startup?
  • Advanced disk cleanup with cleanmgr:
    • Open an elevated command prompt
    • Type cleanmgr /sageset:1 and press enter.
    • Select all the options, or leave unticked the ones you prefer.
    • Type cleanmgr /sagerun:1 and press enter
    • Let it work until it finishes.
  • Launch this command from an elevated command prompt:
    dism /online /cleanup-image /checkhealth
    Do you get my same result?
    If yes, go to the next point.
    If no:
  • Launch this command from an elevated command prompt and let it work until it finishes (it could last from 10 to 60 minutes):
    If you get the following message:
    Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log
    Read Windows Update Forum Posting Instructions (click) and provide the necessary (and missing) informations to the experts. I.e., you should:
    • export and zip/compress the entire CBS folder on your desktop
    • open a new topic in the windows update sub-forum (in sysnative.com)
    • attach that zipped file to that new topic
    If the CBS compressed folder will be too large, you can check the second post on that thread (to use the sfcfix tool with a script) or you can use a (possibly fast) web service like MS OneDrive, Google Drive, DropBox, Box, Mega, Apple iCloud, Amazon Cloud Drive, and so forth...
    Instead if you get the following messages, go to the next step:
    Windows Resource Protection found corrupt files and successfully repaired them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log
  • Defragment your system drive (using windows default defragmenter). Steps:
    • Type defrag c: /h and press enter
    • Wait until it finishes
  • Check your system partition, then post the result here. Steps:
    • Open an elevated command prompt.
    • Type chkdsk c: /b and press enter.
    • You'll get:
      Cannot lock current drive.
    • Type Y and press enter.
    • Then restart/reboot and wait until it finishes this check.
    • To find chkdsk result:
      • Copy/paste this command and press enter:
        wevtutil qe application /c:1 /rd:true  /f:text /q:"*[System[Provider[(@Name='Microsoft-Windows-Wininit')]]]" > "%userprofile%\desktop\ChkDskLOG.txt" & notepad "%userprofile%\desktop\ChkDskLOG.txt"
      • It should create chkdsklog.txt on your desktop and open it: paste its content here.
      • If the command won't work, type eventvwr, press enter, in the event viewer window double-left-click Windows Logs to expand it, left-click Application, double-left-click the information event with source wininit, copy its content and post it here.
If the problem persists:
    • System Manufacturer?
    • Laptop or Desktop?
    • x86 (32bit) or x64 (64bit)?
    • Service pack?
    • Age of system? (hardware)
    • Age of OS installation?
    • CPU
    • RAM (brand, model, which slots are you using?)
    • Video Card
    1. Download Speccy portable - current version 1.30.730 (click), unzip/decompress it and put it on your desktop.
      (Or generate a log in your pc, if you prefer to not publish the snapshot for some reason)
      (Or upload here the generated log, in case you didn't publish the snapshot)
  • Facultative System information log (if previous point fails for some obscure reason)
    The following command should generate a log, named MsInfo.nfo, on your desktop, after some time (few seconds or minutes).
    Upload it here when windows finished its creation.
    It obviously should be run from an elevated command prompt:
    msinfo32 /nfo msinfo32 /nfo "%userprofile%\desktop\MsInfo.nfo"
  • Download and install the Windows Performance Toolkit on dev.windows.com - Windows Software Development Kit (SDK) for Windows 10 - sdksetup.exe 1.12MB (click):
    Then open an elevated command prompt and launch these commands:
    You can also read the original tutorial/guide and its following posts for more information:
    How to Diagnose and Fix High DPC Latency Issues with WPA (Windows Vista/7/8) (click) (by Niemiro)
