[SOLVED] Dism will not /restorehealth
uGeeko
I am trying to run dism to /restorehealth on a server but it can not complete.
SFC /SCANNOW - Below Error
PS C:\Windows\system32> sfc /scannow
Verification 100% complete.
For online repairs, details are included in the CBS log file located at
windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. For offline
repairs, details are included in the log file provided by the /OFFLOGFILE flag.
Dism /online /cleanup-image /restorehealth - Requires a source file
Dism /online /cleanup-image /restorehealth /Source:WIM:d:\\sources\\Install.wim:2 /limitaccess - Below error
PS C:\Windows\system32> Dism /online /cleanup-image /restorehealth /Source:WIM:d:\\sources\\Install.wim:2 /limitaccess
Version: 10.0.17763.3406
Image Version: 10.0.17763.4010
[===========================98.8%========================= ]
Error: 0x800f081f
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see Configure a Windows Repair Source.
Step 1. Download
Hi, This fixed the issues for this server thanks.
On a side note, i have 43 Servers with DISM repair issues, is there a way i can check the issues myself and repair them instead of creating 43 threads?
Do all other servers have the same problem like this case as we can see in the excerpt below?
2024-04-19 10:45:57, Info                  CBS    (p)    CSI Payload Corrupt    (n)            amd64_microsoft-windows-t..enseserver-tlsbrand_31bf3856ad364e35_10.0.17763.1075_none_9c481b71554a77d4\tls_branding_config.xml
2024-04-19 10:45:57, Info                  CBS    Repair failed: Missing replacement payload.
Hi, I have just checked 4 of them, and they have the following. It may be different for a number of other ones though.
(p) CSI Payload Corrupt amd64_netfx4-servicemodel_mof_files_b03f5f7f11d50a3a_4.0.15744.1136_none_6c16bd5ff4e90e6d\ServiceModel.mof
You're welcome. If you have problems finding corrupt components let us know. (y)
