[SOLVED] DISM stuck at 40, SFC Found corrupt files, could not fix some of them
Firebright
I've been having some problems with the sfc /scannow checker in Command Prompt. When it runs, I get the error that while corrupt files were found, it was unable to fix some of them. Running DISM works until 40%, where it gets stuck, even overnight. Reading other posts I've heard this could be because the corrupt files are ones needed to run DISM in the first place, (Thus the freeze). I've attached my CBS log. Any help would be much appreciated. Thanks!
Hi Firebright :)
My name is Aura and I'll be assisting you with your issue. I'll put a fix together tonight, since I do not have access to that specific file at work.
Sorry for the delay. Here, follow the instructions below please.
SFCFix - Fix Time
SFCFix.zip
Good :) Let's run SFC again to see if the replacement is accepted.
System File Checker (SFC)
    Run as Administrator
It looks good! My CBS log was too large to attach, but the problem seems to be gone. Thanks for your help, Aura!
No problem Firebright, you're welcome :)
