carpetafhf
- Dec 14, 2023
- 2
I have a windows 2012 R2 server that had several problems on the component store. I downloaded manually specific patches and now the command "dism /online /cleanup-image /restorehealth" shows that all problems were corrected. However, if I run the command "sfc /scannow" it still reports that there are damaged files and it can't repair them.
In CBS log it says that there is a hash mismatch:
\SystemRoot\WinSxS\amd64_netfx4-servicemodel_mof_files_b03f5f7f11d50a3a_4.0.9680.17530_none_8ea9510f9ca52af2\ServiceModel.mof do not match actual file [l:32{16}]"ServiceModel.mof"
But I'm not able to find a correct file to solve the error. I've attached the file ComponentsScanner.txt, and the Logs folder can be download from this link:
Logs.zip
Let me know if you need anything else.
Thanks for your help
Logs.zip
