[SOLVED] DISM errors and problems patching my system
Remy
Goodmorning Sysnative,
I have some problems with updating my system. I see there are some DISM errors.
Can you please help me fix the errors and patching my system again?
See the attachment with the latest CSB log.
Kind regards,
Remy
  • Open Windows Explorer and browse to the C:\Windows\Logs folder.
  • Right-click on the CBS folder and choose Send to > Compressed (zipped) folder.
  • Now the message will appear, "Windows cannot create the Compressed (zipped) Folder here. Do you want it to be placed on the desktop instead?"
  • Click on the Yes button here.
  • Attach the file CBS.zip to your next reply.
Hi and good morning,
Upload your COMPONENTS hive.
Export CBS (Component Based Servicing) hive
  • Click on the Start button and type regedit
  • Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
  • Right-click on the saved file and choose Send > Compressed (zipped) Folder.
This files contains the CBS folder instead of the zipped Component Based Servicing hive.
2023-02-07 09:39:46, Error                 CSI    00000009 (F) HRESULT_FROM_WIN32(14098) #2104712# from Windows::ServicingAPI::CCSITransactionAnalysis_ICSIInventory::EnumComponentsDeployments(flags = (ICSIINVENTORY_ENUMCOMPONENTSDEPLOYMENTS_FLAG_INCLUDE_PINNED|ICSIINVENTORY_ENUMCOMPONENTSDEPLOYMENTS_FLAG_INCLUDE_INSTALLED|ICSIINVENTORY_ENUMCOMPONENTSDEPLOYMENTS_FLAG_ASSEMBLY_NOT_FOUND_RETURNS_NULL), cComponents = 1)
[gle=0x80073712]
2023-02-07 09:39:46, Info                  CBS    Failed to EnumerateComponentDeployment, component: wow64_microsoft-windows-com-base-qfe-ole32_31bf3856ad364e35_10.0.17763.2989_none_03c5ace0f8ac5854 [HRESULT = 0x80073712 - ERROR_SXS_COMPONENT_STORE_CORRUPT]
2023-02-07 09:39:46, Info                  CBS    Failed to load component owners on component: wow64_microsoft-windows-com-base-qfe-ole32_31bf3856ad364e35_0.0.0.0_none_366ae2df2739cfeb, version: 10.0.17763.2989 [HRESULT = 0x80073712 - ERROR_SXS_COMPONENT_STORE_CORRUPT]
No problem at all.
Step 1. Download
See the attachment. Dism restore command is finished. I try to update the machine now.
I'l let you know the results.
Sadly the Windows updates failed again with error 0x80073712.
I uploaded the CSB logs in the attachment again.
Unfortunately, the script for SFCFix failed, please perform the following steps.
Step 1. Download the
  • Press the Fix button.
Step 2. Download
ComponentsScanner and save it to your desktop.
  • Right-click ComponentsScanner.exe and select "Run as administrator", click Yes on the UAC (User Account Control) prompt which appears.
  • Follow the on-screen instructions.
  • Once complete, a report will be saved to your desktop called ComponentsScanner.txt.
  • Post the logfile ComponentsScanner.txt as attachment into your next reply.
Could you please provide a new copy of the COMPONENTS hive.
Strange, in post #12 ComponentsScanner reported an corrupted key, but the upload Components hive looks good.
So I would suggest to attempt to update again and see what happens this time.
Windows updates are installed succesfully. So thats good!
If i run DISM checkhealth, i still get an "the component store is repairable" message.
I uploaded the latest CSB logs in the attachment.
Let's run the following DISM command again and post the result. If it fails attach a new copy of the CBS log.
The restore operation is completed succesfully. The system is healthy again.
Thanks for helping me!
