Okay, the fix with the compressed .MANIFEST files didn't work.
Following fix contains 11 uncompressed .MANIFEST files.
I'd like to see the result of that first.
- Download the attachment SFCFix.zip and save it on your desktop.
- Save any work you have open, and close all programs.
- Drag the SFCFix.zip file over the SFCFix.exe executable and release it.
- SFCFix will launch, let it complete.
- Once done, a file will appear on your desktop, called SFCFix.txt.
- Attach that file to your next reply.
Restart the machine.
Run the command
in a elevated commandprompt and report the result.
If it fails attach the file cbs.log again to your next reply.
