B belillo Member Joined Dec 13, 2018 Posts 13 Jan 15, 2019 #21 Hi, attached updated CheckSUR.log Thanks Attachments CheckSUR.log 7.2 KB · Views: 3
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Jan 18, 2019 #22 Step#1 - FRST Fix NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system 1. Please download Farbar Recovery Scan Tool and save it to your Desktop. Note: You need to run the 64-bit Version so please ensure you download that one. 2. Download attached file and save it to the Desktop. Note. It's important that both files, FRST64 and fixlist.txt are in the same location or the fix will not work (in this case...the desktop). 3. Run FRST64 by Right-Clicking on the file and choosing Run as administrator. 4. Press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. 5. When finished FRST64 will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply. Afterwards, run SURT again and attach CheckSUR.log. Attachments Fixlist.txt 1 KB · Views: 3
B belillo Member Joined Dec 13, 2018 Posts 13 Jan 18, 2019 #23 Hi, attached CheckSUR.log and Fixlog.txt Regards. Attachments CheckSUR.log 7.2 KB · Views: 3 Fixlog.txt 1.4 KB · Views: 1
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Jan 18, 2019 #24 Is KB4034664 installed?
