E excalibre Member Joined May 12, 2015 Posts 24 May 19, 2015 #21 Thanks, Fingers crossed lol SFCFix version 2.4.3.0 by niemiro. Start time: 2015-05-20 02:59:45.791 Microsoft Windows 7 Service Pack 1 - amd64 Using .txt script file at D:\Liam Willetts\Downloads\SFCScript.txt [0] RegistryScript:: Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. RegistryScript:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.3.0 by niemiro has completed. Currently storing 13 datablocks. Finish time: 2015-05-20 02:59:45.909 Script hash: ruBdGrEPjClRx6dwxaHD+fdLFOr+JE7/ta4N/SyaaK4= ----------------------EOF----------------------- ================================= Checking System Update Readiness. Binary Version 6.1.7601.22471 Package Version 26.0 2015-05-20 03:00 Checking Windows Servicing Packages Checking Package Manifests and Catalogs Checking Package Watchlist Checking Component Watchlist Checking Packages Checking Component Store (f) CSI Catalog Missing 0x00000002 87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232.cat 364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9 Missing catalog or invalid CatalogThumprint (fix) CSI Catalog Missing CSI File Replaced Deleted CatalogThumbprint (f) CSI C Mark Deployment Missing 0x00000000 c!96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180 amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18467_none_6616bcea60c32011 Summary: Seconds executed: 219 Found 2 errors Fixed 1 errors CSI Catalog Missing Total count: 1 Fixed: CSI Catalog Missing. Total count: 1 CSI C Mark Deployment Missing Total count: 1
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States May 19, 2015 #22 Darn. One more time please. I made an adjustment. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCScript.txt, and save this to your Desktop. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCScript.txt. Drag the file SFCScript.txt onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Step#2 - System Update Readiness Tool (SUR) 1. Download and run the following file. 2. When it asks you if you wish to install, please answer yes. Note: It could take 15 minutes or more to run. Please don't cancel. 3. You will get an Installation Complete screen when it's done running. 4. Please attach the log from the following location. C:\Windows\Logs\CBS\CheckSUR.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link. Items for your next post 1. SFCFix log 2. CheckSUR log Attachments SFCScript.txt 854 bytes · Views: 45
E excalibre Member Joined May 12, 2015 Posts 24 May 20, 2015 #23 Ok here we go. SFCFix version 2.4.3.0 by niemiro. Start time: 2015-05-20 07:59:00.336 Microsoft Windows 7 Service Pack 1 - amd64 Using .txt script file at D:\Liam Willetts\Downloads\SFCScript.txt [0] RegistryScript:: Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Failed to import registry key HKEY_LOCAL_MACHINE\14167\CanonicalData\Catalogs\87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232. A root key cannot be created under this hive. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. RegistryScript:: directive failed to complete successfully. Failed to process all directives successfully. SFCFix version 2.4.3.0 by niemiro has completed. Currently storing 13 datablocks. Finish time: 2015-05-20 07:59:00.458 Script hash: CV/IqytmnPi4aY+ZMf5BnDpwzedJXTjFOi/b2whgceg= ----------------------EOF----------------------- ================================= Checking System Update Readiness. Binary Version 6.1.7601.22471 Package Version 26.0 2015-05-20 08:00 Checking Windows Servicing Packages Checking Package Manifests and Catalogs Checking Package Watchlist Checking Component Watchlist Checking Packages Checking Component Store (f) CSI Catalog Missing 0x00000002 87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232.cat 364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9 Missing catalog or invalid CatalogThumprint (fix) CSI Catalog Missing CSI File Replaced Deleted CatalogThumbprint (f) CSI C Mark Deployment Missing 0x00000000 c!96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180 amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18467_none_6616bcea60c32011 Summary: Seconds executed: 268 Found 2 errors Fixed 1 errors CSI Catalog Missing Total count: 1 Fixed: CSI Catalog Missing. Total count: 1 CSI C Mark Deployment Missing Total count: 1
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States May 20, 2015 #24 There was an error in my last script so it wasn't a good test. I apologize. Please try again with this adjusted script. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCScript.txt, and save this to your Desktop. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCScript.txt. Drag the file SFCScript.txt onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Step#2 - System Update Readiness Tool (SUR) 1. Download and run the following file. 2. When it asks you if you wish to install, please answer yes. Note: It could take 15 minutes or more to run. Please don't cancel. 3. You will get an Installation Complete screen when it's done running. 4. Please attach the log from the following location. C:\Windows\Logs\CBS\CheckSUR.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link. Items for your next post 1. SFCFix log 2. CheckSUR log Attachments SFCScript.txt 864 bytes · Views: 27
E excalibre Member Joined May 12, 2015 Posts 24 May 22, 2015 #25 Hi Sorry bin away for a couple of days. Logs below. SFCFix version 2.4.3.0 by niemiro. Start time: 2015-05-22 15:08:41.557 Microsoft Windows 7 Service Pack 1 - amd64 Using .txt script file at D:\Liam Willetts\Downloads\SFCScript.txt [0] RegistryScript:: Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232. Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232. RegistryScript:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.3.0 by niemiro has completed. Currently storing 13 datablocks. Finish time: 2015-05-22 15:08:41.697 Script hash: sdm3fYCU1D2J7O0ZmImAR5yHznqrA/lSoiLIpEZDxN4= ----------------------EOF----------------------- ================================= Checking System Update Readiness. Binary Version 6.1.7601.22471 Package Version 26.0 2015-05-22 15:09 Checking Windows Servicing Packages Checking Package Manifests and Catalogs Checking Package Watchlist Checking Component Watchlist Checking Packages Checking Component Store (f) CSI Catalog Missing 0x00000002 87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232.cat 364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9 Missing catalog or invalid CatalogThumprint (fix) CSI Catalog Missing CSI File Replaced Deleted CatalogThumbprint (f) CSI C Mark Deployment Missing 0x00000000 c!96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180 amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18467_none_6616bcea60c32011 Summary: Seconds executed: 219 Found 2 errors Fixed 1 errors CSI Catalog Missing Total count: 1 Fixed: CSI Catalog Missing. Total count: 1 CSI C Mark Deployment Missing Total count: 1
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States May 22, 2015 #26 No problem. That last ones a bugger but I want to fix it. Please do the following. 1. Go to C:\Windows\System32\Config and copy the COMPONENTS hive to your desktop. If you get an in-use error, then reboot your machine and try again immediately after the reboot. 2. Zip and upload this file to me. Thank you.
E excalibre Member Joined May 12, 2015 Posts 24 May 22, 2015 #27 Thanks, As requested https://www.dropbox.com/s/kkty1rh9y13aemw/components.zip?dl=0
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States May 22, 2015 #28 Thank you very much. I think I found the needle in the haystack. Please do the following. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCScript.txt, and save this to your Desktop. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCScript.txt. Drag the file SFCScript.txt onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Step#2 - System Update Readiness Tool (SUR) 1. Download and run the following file. 2. When it asks you if you wish to install, please answer yes. Note: It could take 15 minutes or more to run. Please don't cancel. 3. You will get an Installation Complete screen when it's done running. 4. Please attach the log from the following location. C:\Windows\Logs\CBS\CheckSUR.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link. Items for your next post 1. SFCFix log 2. CheckSUR log Attachments SFCScript.txt 1.3 KB · Views: 27
E excalibre Member Joined May 12, 2015 Posts 24 May 22, 2015 #29 Ok here's the new logs. SFCFix version 2.4.3.0 by niemiro. Start time: 2015-05-23 02:02:11.317 Microsoft Windows 7 Service Pack 1 - amd64 Using .txt script file at D:\Liam Willetts\Downloads\SFCScript.txt [0] RegistryScript:: Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components. Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232. Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180. Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232. RegistryScript:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.3.0 by niemiro has completed. Currently storing 15 datablocks. Finish time: 2015-05-23 02:02:11.697 Script hash: UsKqVEe/K+FiZZJg0ajnLt/lRRv4lwcS7b592sIwuJI= ----------------------EOF----------------------- ================================= Checking System Update Readiness. Binary Version 6.1.7601.22471 Package Version 26.0 2015-05-23 02:03 Checking Windows Servicing Packages Checking Package Manifests and Catalogs Checking Package Watchlist Checking Component Watchlist Checking Packages Checking Component Store (f) CSI Catalog Missing 0x00000002 87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232.cat 364d7da7926..bccdee4900d_31bf3856ad364e35_6.1.7601.18467_9a8a6aca952ef8b9 Missing catalog or invalid CatalogThumprint (fix) CSI Catalog Missing CSI File Replaced Deleted CatalogThumbprint (f) CSI Manifest Missing 0x00000002 amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180.manifest amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180 (f) CSI C Mark Deployment Missing 0x00000000 c!96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180 amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180 (f) CSI C Mark Deployment Missing 0x00000000 c!96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180 amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18467_none_6616bcea60c32011 Summary: Seconds executed: 337 Found 4 errors Fixed 1 errors CSI Manifest Missing Total count: 1 CSI Catalog Missing Total count: 1 Fixed: CSI Catalog Missing. Total count: 1 CSI C Mark Deployment Missing Total count: 2 Unavailable repair files: winsxs\manifests\amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180.manifest
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States May 22, 2015 #30 OK good. Now let's replace the missing manifest file. Step#1 - Fix Missing File Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Please download the attached file, Packs.zip and save this to your Desktop. Right-click on the file and select Extract All... Tick the box labelled Show extracted files when complete then click Extract A window will open showing two folders, Manifests and Packages Open the Manifests folder and copy the files into the following folder (if there are any files). If the Manifests folder doesn't exist within Winsxs you will need to create it. C:\Windows\Temp\CheckSur\Winsxs\Manifests We won't do anything with the Packages folder Run the System Update Readiness Tool (SURT) again. When the SURT finishes installing, zip up and attach the following log file: C:\Windows\Logs\CBS\CheckSUR.log Attachments Packs.zip 896 bytes · Views: 22
E excalibre Member Joined May 12, 2015 Posts 24 May 22, 2015 #31 ok done. ================================= Checking System Update Readiness. Binary Version 6.1.7601.22471 Package Version 26.0 2015-05-23 02:24 Checking Windows Servicing Packages Checking Package Manifests and Catalogs Checking Package Watchlist Checking Component Watchlist Checking Packages Checking Component Store (f) CSI Manifest Missing 0x00000002 amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180.manifest amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180 (fix) CSI Manifest Missing CSI File Replaced File: amd64_96cbb10a7e32bbe30f1908e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_none_5d113214f1d04180.manifest From: C:\windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab (f) CSI Missing Deployment Key 0x00000000 96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180 HKLM\Components\CanonicalData\Deployments Summary: Seconds executed: 114 Found 2 errors Fixed 1 errors CSI Manifest Missing Total count: 1 Fixed: CSI Manifest Missing. Total count: 1 CSI Missing Deployment Key Total count: 1
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States May 22, 2015 #32 Good, that's fixed. Now let's add the missing deployment key. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCScript.txt, and save this to your Desktop. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCScript.txt. Drag the file SFCScript.txt onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Step#2 - System Update Readiness Tool (SUR) 1. Download and run the following file. 2. When it asks you if you wish to install, please answer yes. Note: It could take 15 minutes or more to run. Please don't cancel. 3. You will get an Installation Complete screen when it's done running. 4. Please attach the log from the following location. C:\Windows\Logs\CBS\CheckSUR.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link. Items for your next post 1. SFCFix log 2. CheckSUR log Attachments SFCScript.txt 1 KB · Views: 39
E excalibre Member Joined May 12, 2015 Posts 24 May 22, 2015 #33 I think you cracked it. SFCFix version 2.4.3.0 by niemiro. Start time: 2015-05-23 02:39:51.698 Microsoft Windows 7 Service Pack 1 - amd64 Using .txt script file at D:\Liam Willetts\Downloads\SFCScript.txt [0] RegistryScript:: Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments. Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180. Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments. RegistryScript:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.3.0 by niemiro has completed. Currently storing 16 datablocks. Finish time: 2015-05-23 02:39:51.747 Script hash: HcNN/sZ6/dHfrtZ5pWWmiy2UNCfU3/sHdv/TqP7t1vA= ----------------------EOF----------------------- ================================= Checking System Update Readiness. Binary Version 6.1.7601.22471 Package Version 26.0 2015-05-23 02:40 Checking Windows Servicing Packages Checking Package Manifests and Catalogs Checking Package Watchlist Checking Component Watchlist Checking Packages Checking Component Store (f) CSI Catalog Missing 0x00000002 87cc76ddfb55126ac35403ccaa8720d7af24e32aed91c2e0eeb277874a328232.cat 96cbb10a7e3..8e5aeb60e48_31bf3856ad364e35_6.1.7601.18467_5d113214f1d04180 Missing catalog or invalid CatalogThumprint (fix) CSI Catalog Missing CSI File Replaced Deleted CatalogThumbprint Summary: Seconds executed: 111 Found 1 errors Fixed 1 errors CSI Catalog Missing Total count: 1 Fixed: CSI Catalog Missing. Total count: 1
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States May 22, 2015 #34 :dance: Resolved!!!!!!!!!!!!!!!! Anything else you need assistance with or was this it?
E excalibre Member Joined May 12, 2015 Posts 24 May 22, 2015 #35 No my friend, that's was it lol :grin1: Thanks so much 4 all your time, patience and hard work helping me out. Have a great weekend. All the best. Excalibre :thumbsup2:
