Stuff_and_Thangs
Well-known member
- Aug 15, 2014
- 49
Discussion about this from previous thread can be found here: https://www.sysnative.com/forums/wi...dows-update-kb2267602-failed-2.html#post80716
Note, however, that software based RAM diagnostic tools are good, but not conclusive. So you might try running with just a single RAM module to see if it fails. Repeat process with remaining modules, hopefully identifying the bad stick through a process of elimination. Just be sure to unplug the computer from the wall and touch bare metal of the case interior BEFORE reaching in to discharge any destructive static in your body.
The fact your memory test showed no errors is good. But sadly, RAM can test good by these software based testers and still not work when put into use. If the tester reports errors, the RAM is bad. But if no errors reported, it might still be bad. So to conclusively test, you need to run with just one stick of RAM at a time, and see of problems develop. If no problems, swap sticks again until you [hopefully] find a bad stick.You lost me there.
You would have to open the errors (click on the + sign) for more info. Be sure to check the timestamps though as most of your entries are a days back and most likely no longer applicable. But do not most errors on one-off and self correcting and can happen if your network hiccoughs, you fat finger your password, or any number of temporary circumstances. .
The Windows tool is very unreliable, whereas MemTest86+ is a much more well tested and reliable solution. I do not recommend the built in tool because it has a high rate of not detecting ram faults.I don't see where you tested your RAM as requested. You need to do that! You can use MemTest as suggested, or Windows 7 and Windows 8 users can use the built in Windows Memory Diagnostics Tool. Regardless the tool, you should get no errors after several passes.
I'm not sure on how to remove RAM. I've never done anything on the inside of a computer before, except remove something following instructions given by an employee of DigitalStorm.Note, however, that software based RAM diagnostic tools are good, but not conclusive. So you might try running with just a single RAM module to see if it fails. Repeat process with remaining modules, hopefully identifying the bad stick through a process of elimination. Just be sure to unplug the computer from the wall and touch bare metal of the case interior BEFORE reaching in to discharge any destructive static in your body.
