Creation of system image problems and SFC corruptions
Archadius
Montréal
After looking for answers for my system's problems, ended up finding this forum and decided to give it a try!
I've been trying to create a system image with no success. After looking for some troubleshooting online, one of the recommendations was to run SFC and look for corrupted system files.
After running it, 3 corrupted files were identified. I've also ran SFCFix - find attached the result. CBS files follow shortly.
I would like some help on how to replace these corrupted files manually!
Thanks in advance for your attention on this! Hope this solves my issue with the system image creation.
Cheers,
It's not showing up here but I've uploaded the CBS files using the process described here in the forum for large logfiles
Hi Archadius,
Do you still need assistance with this issue?
Alright follow the instructions below please.
SFCFix - Fix Time
SFCFix.zip
Thanks again!
Does it look good?
SFCFix version 3.0.0.0 by niemiro.Start time: 2016-08-10 01:25:47.012
Using .zip script file at C:\Users\Wagner M\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-ddores_31bf3856ad364e35_6.1.7600.16385_none_1e9c329c9fe0187e\DDORes.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.17514_none_763763505e93084b\PINTLGB.IMD
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-autochk_31bf3856ad364e35_6.1.7601.17514_none_4019f2b8d860ad30\autochk.exe
Successfully copied file C:\Users\Wagner M\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-ddores_31bf3856ad364e35_6.1.7600.16385_none_1e9c329c9fe0187e\DDORes.dll to C:\Windows\winsxs\x86_microsoft-windows-ddores_31bf3856ad364e35_6.1.7600.16385_none_1e9c329c9fe0187e\DDORes.dll.
Successfully copied file C:\Users\Wagner M\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.17514_none_763763505e93084b\PINTLGB.IMD to C:\Windows\winsxs\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.17514_none_763763505e93084b\PINTLGB.IMD.
Successfully copied file C:\Users\Wagner M\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-autochk_31bf3856ad364e35_6.1.7601.17514_none_4019f2b8d860ad30\autochk.exe to C:\Windows\winsxs\amd64_microsoft-windows-autochk_31bf3856ad364e35_6.1.7601.17514_none_4019f2b8d860ad30\autochk.exe.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-ddores_31bf3856ad364e35_6.1.7600.16385_none_1e9c329c9fe0187e\DDORes.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-ddores_31bf3856ad364e35_6.1.7600.16385_none_1e9c329c9fe0187e\DDORes.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.17514_none_763763505e93084b\PINTLGB.IMD
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.17514_none_763763505e93084b\PINTLGB.IMD
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-autochk_31bf3856ad364e35_6.1.7601.17514_none_4019f2b8d860ad30\autochk.exe
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-autochk_31bf3856ad364e35_6.1.7601.17514_none_4019f2b8d860ad30\autochk.exe
Finish time: 2016-08-10 01:25:49.384
Script hash: yXKOT5SkHWeGbDQaZUpG6XnN5DZ51qashS6z4tarm5M=
Yup, now we'll run SFC to see if the replacements were accepted.
System File Checker (SFC)
    Run as Administrator
  • On Windows 8.1 and Windows 10, right click on the Windows logo in the bottom-left corner and select Command Prompt (Admin);
