Hi all,
was digging this problem from morning. Trying as far reinstalling Wifi drivers from Lenovo support page and swap to windows referenced one.I did virus scanning using Makwarebyte.
Finally Im here with log from latencyMon. Hope someone can take a look on it and put some light.
EDIT : switching off Wifi stop cracking but this is not a solution
_________________________________________________________________________________________________________CONCLUSION
LatencyMon has been analyzing your system for 0:09:03 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: HARCEL
OS version: Windows 10 , 10.0, build: 15063 (x64)
Hardware: 23259H1, LENOVO
CPU: GenuineIntel Intel(R) Core(TM) i5-3320M CPU @ 2.60GHz
Logical processors: 4
Processor groups: 1
RAM: 7887 MB total
CPU SPEED
Reported CPU speed: 2594 MHz
Highest measured interrupt to process latency (µs): 92218.226144
Average measured interrupt to process latency (µs): 5.724580
Highest measured interrupt to DPC latency (µs): 92118.357079
Average measured interrupt to DPC latency (µs): 2.897222
REPORTED ISRs
Highest ISR routine execution time (µs): 138.518504
Driver with highest ISR routine execution time: i8042prt.sys - i8042 Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.084999
Driver with highest ISR total time: i8042prt.sys - i8042 Port Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.130649
ISR count (execution time <250 µs): 214497
REPORTED DPCs
Highest DPC routine execution time (µs): 92241.964148
Highest reported total DPC routine time (%): 0.610591
Driver with highest DPC total execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Total time spent in DPCs (%) 0.925004
DPC count (execution time <250 µs): 1738932
DPC count (execution time 500-999 µs): 526
DPC count (execution time 1000-1999 µs): 18
DPC count (execution time 2000-3999 µs): 3
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Highest hard pagefault resolution time (µs): 0.0
Total time spent in hard pagefaults (%): 0.0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 22.318776
CPU 0 ISR highest execution time (µs): 138.518504
CPU 0 ISR total execution time (s): 2.832833
CPU 0 ISR count: 213964
CPU 0 DPC highest execution time (µs): 92241.964148
CPU 0 DPC total execution time (s): 11.483009
CPU 0 DPC count: 1592114
CPU 1 Interrupt cycle time (s): 6.413550
CPU 1 ISR highest execution time (µs): 62.599460
CPU 1 ISR total execution time (s): 0.008139
CPU 1 ISR count: 533
CPU 1 DPC highest execution time (µs): 91915.697764
CPU 1 DPC total execution time (s): 1.879645
CPU 1 DPC count: 40835
CPU 2 Interrupt cycle time (s): 9.493686
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 92232.804549
CPU 2 DPC total execution time (s): 4.957043
CPU 2 DPC count: 51808
CPU 3 Interrupt cycle time (s): 7.080234
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 92174.730146
CPU 3 DPC total execution time (s): 1.794520
CPU 3 DPC count: 54897
SYSTEM INFORMATION
Processor groups: 1
RAM: 7887 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 0
CPU 3 ISR count: 0
