cracking/dropout audio problem.. (DPC?)
Jaewoong
Hello. I am first to this forum..
I have an audio problem. it is cracking.
I searched the Internet and tried several solutions suggested : updated GPU driver and sound driver, and command "verifier /reset"
There were some changes on LatencyMon, but the sound is still cracking.
Please help me..
Hi Jaewoong. :welcome:
    • System Manufacturer?
    • Laptop or Desktop?
    • x86 (32bit) or x64 (64bit)?
    • Service pack?
    • Age of system? (hardware)
    • Age of OS installation?
    • CPU
    • Video Card
  • System information log
    You should run only one of the following commands, the one you prefer.
    msinfo32 /nfo "c:\users\YourWinAccountFolder\desktop\MsInfo.nfo"
    or
    msinfo32 /nfo "c:\users\%username%\desktop\MsInfo.nfo"
    or
    msinfo32 /nfo "%userprofile%\desktop\MsInfo.nfo"
    (Then upload it here)
    1. Download Speccy portable - actual version 1.29.714 (click), unzip/decompress it and put it on your desktop.
    5. (Or attach the log here, if you prefer to not publish it for some reason)
  • Download and install the Windows Performance Toolkit - Windows Assessment and Deployment Kit (Windows ADK) for Windows 8.1 Update - adksetup.exe 1.36MB (click):
    Then open an elevated command prompt (right-click on the windows start button on bottom-left corner, left-click Command Prompt (Admin)) and launch these commands:
    You can also read the original tutorial/guide and its following posts for more informations:
    How to Diagnose and Fix High DPC Latency Issues with WPA (Windows Vista/7/8) (click) (by Niemiro)
The most visible problem is you are using two or three firewalls:
  • windows firewall service is running
  • Kaspersky Internet Security includes a firewall module
  • MyFirewall 4.0 Service exists on your machine, even if it's stopped
Remove MyFirewall 4.0 completely, if you are not using it, and re-check windows firewall status (it should be enabled either windows firewall or Kaspersky firewall).
Is nProtect (nossvc.exe, nosstarter.npe) another antivirus? If yes, uninstall it (or use that instead of Kaspersky... I.e., use only one antivirus).
Try to update (or reinstall?) the driver(s) for your network adapter.
If your NIC is realtek RTL8168, it should be this: realtek.com.tw - Win8/8.1 setup for RTL8168 (click)
That should work also for RTL8168B, RTL8168C, RTL8168E, and other models... See next link:
realtek.com.tw - General download webpage to download drivers for RTL8111B/RTL8168B/RTL8111/RTL8168/RTL8111C/RTL8111CP/RTL8111D(L)/RTL8168C/RTL8111DP/RTL8111E
RTL8168E/RTL8111F/RTL8411/RTL8111G/RTL8111GUS/RTL8411B(N)/RTL8118AS
